Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Apr 14, 2015 at 4:23 AM
    #6261
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
    Anyone?
  2. Apr 14, 2015 at 4:41 AM
    #6262
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    just wondering so i know which 1 i will remove when the time comes
  3. Apr 14, 2015 at 5:09 AM
    #6263
    EBORSETI22
    EBORSETI22 Well-Known Member
    Evan
    New England
    '11 TRD Offroad
    TRD Exhaust Bed Mat Tinted Windows Tonneau Cover Cubby Bed Lights Reverse Lights Anytime Fog Mod Full OME Lift - 887s, LR UCAs, Dakars with D29XXL AAL MB TKO 17" Wheels 255/80r17 ST Maxx CMC Volant CAI with Scoop NFab Running Boards "Raptor" Grille Lights Ditch Lights 30" LED Hidden Light Bar On Board Air
    I had the lean with just the trim packer installed, then added the 1/4" top plate spacer to the driver side.
    That removed the lean for me
  4. Apr 14, 2015 at 5:55 AM
    #6264
    Nazupag524
    Nazupag524 Well-Known Member
    Jeremy
    Elizabeth, CO
    07 DCSB 4x4
    Heavy ass pig sitting on 35s
    Does removing the overload spring reduce load cap? If not maybe I'll put the 3rd leaf back in and take the overload out.
  5. Apr 14, 2015 at 7:58 AM
    #6265
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    It's more than just about the thickness
    Removing the 3rd will soften the ride and lower the height but at the cost of some capacity
    Removing the upper overload lowers the height by about 1/2" but the ride and capacity stay the same
  6. Apr 14, 2015 at 9:00 AM
    #6266
    14 Tacoma
    14 Tacoma ColeMcMathisaDouche
    Clinton
    IL
    2014 TRD Sport
    Cheap ebay bumper, plus others
    Think I finally have everything needed. Just ordered some LR UCA's and a CB drop.
    '14 Access Cab TRD Sport
    Going with
    884/90021, driver side trim packer
    Have spacers on the way, not sold on installing them
    2" AAL, with the rear OME shocks, Nitro's?
    Sticking with stock wheels and 265/65/17's for the moment until I decide everyhing will work.
    Not sure how fast HeadStrong ships, so will probably be next week before I get the UCA's as I'm in IL and just ordered this morning. By that point morel mushrooms will be up and my next 4-5 weekends will be occupied.
    Hoping late May I'll do the install... nit worried about doing it, more worried about after the install with vibrations and such.
    Wouldn't mind going the full 3" with front spacers but not sure I wamt to put the extra angle/pressure on the cv knuckles
  7. Apr 14, 2015 at 11:04 AM
    #6267
    BenTheMan
    BenTheMan Well-Known Member
    Ben
    Portland
    2012 TRD Sport 4x4 AC
    Truck Nutz
    I would get the ECGS bushing to replace the needle bearing in your driver side CV axle. I got vibes as soon as I lifted mine this last weekend. It will be much easier to do it while you already have everything removed.
  8. Apr 14, 2015 at 11:20 AM
    #6268
    303tacoma
    Rebecca
    Thanks how much height do you lose with the 3rd leaf removed???
  9. Apr 14, 2015 at 11:29 AM
    #6269
    Mr Salty
    Mr Salty "Give up the good to go for the great"
    Hermmy
    SoCal (Bro Capital of the world)
    White SR5 Pre-runner
    Lots of chrome
    Per ARB with the 3rd leaf removed it will drop you about 13mm (if i remember correctly), which is close to 0.5"
    I removed my top overload and the drop was a little more. Capacity is still there, just flexes significantly better on up travel when offroad. I think I was one of the first, on here at least, to remove the top overload and have had the packs like this for about 2 years now with no complaints or issues.
  10. Apr 14, 2015 at 11:41 AM
    #6270
    14 Tacoma
    Clinton
    IL
    2014 TRD Sport
    You're talking the 8" bushing? Special tools necessary?
    Stupid phone won't let me.copy and paste the link since it updated to lollipop last night.
  11. Apr 14, 2015 at 11:45 AM
    #6271
    la0d0g
    running for the hills
    For crawling not hauling
    Even with the spacers you won't get 3" out of 884s, I was at like 1.75" when I had them (no spacers). With the setup you're getting I would be really shocked if you had any vibrations, its just not that much of a change.
    Skip the spacers, stick with the 265s and you'll be rocking. I loved that setup, almost as much as I love my setup now :)
    Edit:
    Pic with 884s cause i like them pictars
  12. Apr 14, 2015 at 11:51 AM
    #6272
    14 Tacoma
    Clinton
    IL
    2014 TRD Sport
    How much more weight do you have being a dual cab? I'm only an access cab and that does make a difference in all my researching. Haven't researched cab weight differences though.
  13. Apr 14, 2015 at 11:59 AM
    #6273
    la0d0g
    Not enough to bump you up 1.25"
    I just looked to see if I could find the weight of the two but both were list as gross 5,500 lbs. I'm going to keep looking for it.
  14. Apr 14, 2015 at 12:05 PM
    #6274
    la0d0g
    Toyota.com has them listed as:
    2015 Access Cab V6 curb weight (lbs) 4140
    2015 Double Cab V6 curb weight (lbs) 4220
    Pretty sure 80lbs isn't going to make too much of a difference on a 588 #/in spring.
    http://www.toyota.com/tacoma/features.html#!/weights_capacities/7554/7594/7597
  15. Apr 14, 2015 at 12:05 PM
    #6275
    14 Tacoma
    Clinton
    IL
    2014 TRD Sport
    Also, was yours factory rear height in the pic or did you lift it as well?
    Now you have me thinking all over again lol, ugh. I thought the 884x were supposed to be cycled at the factory to eliminate sag and maintain consistent heights.
  16. Apr 14, 2015 at 12:08 PM
    #6276
    la0d0g
    See above for weights.
    And the new springs don't sag but that doesn't change the fact that its a 385 mm spring.
    That pic was with the factory 4 pack.
  17. Apr 14, 2015 at 12:16 PM
    #6277
    14 Tacoma
    Clinton
    IL
    2014 TRD Sport
    I'm confused more than ever now, sounds like I may have wasted $400 on he UCA's and carrier drop.
    Think I'm going to cancel the order and hold off until I can get this sorted out.
    Definitely going against what i thought was a consensus.
  18. Apr 14, 2015 at 12:22 PM
    #6278
    OZ-T
    Peter North
    British Columbia
    884's will get 2 - 2-1/2 inches on an AC
  19. Apr 14, 2015 at 12:23 PM
    #6279
    la0d0g
    What are you trying to achieve? Clear 265s and gain a little lift?
  20. Apr 14, 2015 at 12:30 PM
    #6280
    la0d0g
    That's only if you get the special ones :rolleyes:
