Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Apr 22, 2015 at 3:29 AM
    #6401
    EBORSETI22
    EBORSETI22 Well-Known Member
    Evan
    New England
    '11 TRD Offroad
    TRD Exhaust Bed Mat Tinted Windows Tonneau Cover Cubby Bed Lights Reverse Lights Anytime Fog Mod Full OME Lift - 887s, LR UCAs, Dakars with D29XXL AAL MB TKO 17" Wheels 255/80r17 ST Maxx CMC Volant CAI with Scoop NFab Running Boards "Raptor" Grille Lights Ditch Lights 30" LED Hidden Light Bar On Board Air
    Thanks! Just need to step up to 285s at some point and then I'll likey!
  2. Apr 22, 2015 at 5:38 PM
    #6402
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
    So you just put the 1/4" spacer on the driver side? I'm a little confused on what you said. I thought it would need to go on driver and passenger side.
  3. Apr 22, 2015 at 5:44 PM
    #6403
    millertime89
    millertime89 Flatlander
    Erik
    Saskatchewan
    06 TRD Sport DCLB 4x4
    Yes sir
    He's talking about fixing the "taco lean" on his truck. Not all, but a good amount of tacoma's get "taco lean" because most of the weight of all of the engine components are on the drivers side of the truck, this makes the truck "lean" slightly. Guys put a 1/4" spacer to counter the "lean" on the drivers side so it looks level and doesn't lean.
  4. Apr 22, 2015 at 5:46 PM
    #6404
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    He used the OME trim packer on the driver's side ( which goes below the coil perch ) but still had taco lean so he added a 1/4" top plate spacer as well
    at least that's how I read it
  5. Apr 22, 2015 at 7:45 PM
    #6405
    YotaBum
    YotaBum Not So Well-Known Member
    Alex
    North Georgia
    2015 TRD Sport DCSB
    Blacked Out-887-Dakars-LR UCA-FJ Trail Team wheels-285 BFG KO2
    I read it as you used the 887 and 1/4" top plate spacers on both sides... I understand now.
    I have a set of 887s and Dakars in the garage. Just waiting on my 90021s to get here so I can install them. I picked up the trim spacer, but hope I don't end up needing the 1/4" top plate on the drivers side as well.
    Guess I'll find out here shortly!
    Your truck looks good! Can't wait to get mine on.
    Appreciate the clarification...
  6. Apr 23, 2015 at 6:56 AM
    #6406
    Tatonka777
    Tatonka777 Active Member
    Marty
    Washington State
    '21 TRD Sport ordered
    I am getting conflicting information. :confused:
    I emailed Wheelers yesterday and got this response.
    From Wheelers: "So the main difference between the nitrochargers and the nitrocharger sports is the valving. The sport shocks are valved firmer to give a more sport oriented ride."
    Does anyone have any real world data on the difference between these shocks?
    Update: Just received the attached pdf's and email on the Nitrocharger Sport from ARB.
    From ARB: "The nitrocharger is going to be a bit more of a softer ride then the sport due to the single valve design. The sports were designed to give a comfortable but performance feel on and off road."
    Hope this helps. :thumbsup:
  7. Apr 23, 2015 at 9:47 AM
    #6407
    EBORSETI22
    Evan
    New England
    '11 TRD Offroad
    Yea so what Oz said was correct - My Driver side had both the trim packer (under the coil perch), and then still had the lean, so I added the 1/4" spacer to it.
    On the passenger side, I have no spacer, and no trim packer, just the shock and coil, normally assembled.
    Before you assemble your coils, you might want to look at how your truck sits with the stock suspension and a full tank of gas. Mine had a slight lean, noticeable to only those who know about it. When I installed the lift, it actually made the lean more noticeable, not sure why (whether optical illusion or not). Would have saved me a hundred bucks because I had to have them disassemble the shock/coilover and add it in...pain in the ass, but hey its over and it looks good!
    Best of luck with yours!
    -Evan
  8. Apr 23, 2015 at 12:50 PM
    #6408
    YotaBum
    Alex
    North Georgia
    2015 TRD Sport DCSB
    Yep, I was informed that the 90000s are recommended for folks running winches and plate bumpers up front because they are a little firmer than the 90021s.
    The 90021s are recommended for folks that are running stock bumpers and little additional front end weight.
    Guys at ARB said that the 90021 will be closer to the Nitrcharger than the 90000. But they said they are supposedly a much better shock... And have a longer warranty.
  9. Apr 23, 2015 at 1:14 PM
    #6409
    OZ-T
    Peter North
    British Columbia
    Probably wouldn't be as conflicting if you had included my response
  10. Apr 24, 2015 at 9:53 AM
    #6410
    Tatonka777
    Marty
    Washington State
    I see my error. I was wanting a comparison between regular NitroChargers and NitroCharger Sports. I see now this was a difference between the 90000 and 90021.
  11. Apr 25, 2015 at 7:14 AM
    #6411
    Madjik_Man
    Colorado Front Range
    1998 TRD 4x4 V6. OME 881 in front, Dakar in rear, nitrosport shocks all around.
    So it seems like I have squeaking coming from the front suspension. I tested the bumper and I can't make it squeak by hand. I tested the factory skids and I can't make it squeak by hand...
    But when I'm driving I get an annoying squeak which seems to be "bump" related, meaning when I hit certain types of bumps (not the jarring kind, just little ones in road imperfections, dirt alley ways, etc) something is squeaky.
    Thought I'd ask if there's something common with the OME suspensions up front that I could check out.
    And yes, every bolt is tightened to specs.
  12. Apr 25, 2015 at 9:48 AM
    #6412
    Jiveydude
    Jiveydude Well-Known Member
    Micah
    OH
    04Taco
    Stuff and things that make it better.
    Do you still have your sway bar on?
  13. Apr 25, 2015 at 10:48 AM
    #6413
    Madjik_Man
    I do.
  14. Apr 25, 2015 at 1:51 PM
    #6414
    Jiveydude
    Micah
    OH
    04Taco
    I had a squeak coming from the frame mount of the sway until I took it off, and another from the upper control arm, lubed it up and it went away.
  15. Apr 25, 2015 at 2:54 PM
    #6415
    Madjik_Man
    Thanks, I'll check those both out.
    Appreciate the insight.
  16. Apr 28, 2015 at 6:17 AM
    #6416
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    How's your cv angles with the 887's and no weight on the front?
  17. Apr 28, 2015 at 11:39 AM
    #6417
    EBORSETI22
    Evan
    New England
    '11 TRD Offroad
    From what the dealer told me "everything looks good" I take it there are no issues...that's really the best answer I have for you haha
  18. Apr 28, 2015 at 2:29 PM
    #6418
    la0d0g
    running for the hills
    For crawling not hauling
    :bananadead: Dealer. Yes this is a solid source for taco suspension information :D
  19. Apr 28, 2015 at 5:59 PM
    #6419
    EBORSETI22
    Evan
    New England
    '11 TRD Offroad
    Yes yes ...... Fair enough haha
  20. Apr 29, 2015 at 2:52 AM
    #6420
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Haha that's what I'm saying!
