Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. May 12, 2015 at 3:12 PM
    #6501
    Chepo
    Chepo Tankoma!
    Chepo
    Mexico City
    '11 TRD Sport
    Lots...
    So, last week (when I asked about the two leaf packs with (-)) I installed the rear lift and I was surprised on the quality of the ride!
    Didn't have any issues during the install, other than the opening the lower shock mount of the axle just a bit so the shock bushings could fit...
    Didn't have any vibrations and didn't install the drop for the rear driveshaft...
    here is a pic:
    Later this week I'll install the front shocks with 886s!!!
  2. May 12, 2015 at 3:18 PM
    #6502
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    There's a real simple way to install the front shocks. Raise the truck up high enough, drop off two bolts for the LCA attachment at the wheel, swing the LCA out of the way, slide the oem coliover assembly out, and the new one in. No disconnecting sway bars, or steering connections.
  3. May 12, 2015 at 3:21 PM
    #6503
    Bman4X5
    Bman4X5 There is no substitute for square inches.
    Bruce
    Upland CA
    '15 AC/OR
    Bilstein, Dakar/Icon, Prinsu, CBI, Pelfreybilt, Tepui
    True. I installed Dakars with 3rd leaf removed and have had no vibe issues. YMMV
  4. May 12, 2015 at 3:22 PM
    #6504
    Chepo
    Chepo Tankoma!
    Chepo
    Mexico City
    '11 TRD Sport
    Lots...
    Thanks!
    That's the procedure I'm going to do... Actually there's a video on youtube (well 2 parts):
    Part 1:
    https://www.youtube.com/watch?v=5E6u7dC7EHg&list=PL0fLxXbbNEMPd3lFDsKOcZSv6iwJQhPXi&index=10
    Part 2:
    https://www.youtube.com/watch?v=jo0FJSi-KYs&list=PL0fLxXbbNEMPd3lFDsKOcZSv6iwJQhPXi&index=11
    Pistol Pete likes this.
  5. May 12, 2015 at 8:23 PM
    #6505
    JC0352
    JC0352 Well-Known Member
    Beau
    NW Louisiana
    '14 DC Off Road 4x4
    Thanks again to you both! Pretty much covers every concern I had.
  6. May 13, 2015 at 11:18 AM
    #6506
    DarkZealot
    DarkZealot Name’s Barf
    Travis
    Huntington Beach, CA
    2015 DCLB 4x4 Taco
    Icon coilovers, Total Chaos UCA, OME Dakar springs, SCS F5 3.5bs Gunmetal wheels, 285/75/16 BFG T/A KO2
    Anyone else installing the dakar's notice that the e-brake cable on the passenger side gets really tight at around full droop? That's a little scary...
  7. May 13, 2015 at 8:24 PM
    #6507
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Yes. It's even worse by 2" or so for the guys who have done the shackle flip kit.
    DarkZealot[QUOTED] likes this.
  8. May 13, 2015 at 8:48 PM
    #6508
    Brjw
    Brjw Well-Known Member
    Brian
    Forest Grove, Oregon
    Bend the e brake cable bracket a bit. My rear shocks are more than 2" longer than the ome shocks. I've bent the brackets enough the while it is still tight, it's much more reasonable.
    DarkZealot and Crom like this.
  9. May 14, 2015 at 1:01 PM
    #6509
    DarkZealot
    Travis
    2015 DCLB 4x4 Taco
    Thanks Brian, I will probably do that instead of just unbolting the bracket :)
  10. May 14, 2015 at 1:07 PM
    #6510
    Seantoobs
    Seantoobs Well-Known Member
    2011 4x4 Tundra and 1985 Toyota Extra cab
    5100's on Tundra and the Whole enchilada with extra guac on the 85
    I just cut mine off
  11. May 14, 2015 at 1:25 PM
    #6511
    DarkZealot
    Travis
    2015 DCLB 4x4 Taco
    I would except I think it's there for a reason (so the ebrake cable doesn't get snagged on a rock or tree branch as vehicle is moving). It could be worse, I just ripped my front axle boot to shreds by not making sure my sway bar end link was securely connected to the spindle on a truck with less than 1000 miles on it :sadviolin:
  12. May 14, 2015 at 9:24 PM
    #6512
    Jefferson10
    Jefferson10 Well-Known Member
    San Luis Obispo
    11' TRD Off Road 4x4
    AFE ProDry Drop in Filter, Wet Okole Seat Covers (front and Back),Truck Champ side steps (Black), Debadged, BFG KO2 265/75/16, OME 90021 w/ 885 in front, OME 60091 with Wheelers Progressive AAL pack (1.5") in rear
    Hey guys. I just bought a set of 90000 fronts with the 886, and 60091 for the rears for my DCSB 4x4. I got a killer deal on them (less than 5000 miles) so I went for it. I plan on getting AAL from totyec for the rear lift. After browsing through everything it kinda looks like the 886 is going to get the 2.5" lift i'm looking for to level it out, but it's going to be a stiffer ride? Also, i got the rear diff drop with everything, and the spacer for the taco lean. Do you think i'll be able to go w/o the diff drop, or is it more of a per install basis? Just trying to get my ducks in a row before install.
  13. May 15, 2015 at 6:56 AM
    #6513
    YotaBum
    YotaBum Not So Well-Known Member
    Alex
    North Georgia
    2015 TRD Sport DCSB
    Blacked Out-887-Dakars-LR UCA-FJ Trail Team wheels-285 BFG KO2
    From what I've read, skip the diff drop.
    And yes with 886s and 9000s with no extra weight up front, it will probably be a pretty stiff ride. ARB's website recommends that front combo for Tacomas with plate bumper and winch set ups.
  14. May 15, 2015 at 7:30 AM
    #6514
    Flowin
    Flowin Well-Known Member
    Acworth, Georgia
    2014 DCSB TRD OFF ROAD
    OME 3" lift, 265/75/16 KO2s, 35% tint
    Is it possible to just get 1.5-2 inch out of the dakars and how? I currently run 885X with 5100s in the front and have 1.5inch lift in the back...it sits almost level with a 0.5" rake I would like to keep it that way or have 1" rake but not more. I only run 265/75/16 duratracs and they would looks lost otherwise lol
    I have the feeling, even though I don't transport much my stock leaves (3+1) are flat after only 20k mls...at least it "looks" like it when looking under the truck...
  15. May 15, 2015 at 6:00 PM
    #6515
    Jefferson10
    San Luis Obispo
    Being on the budget i am, do you think i'll have issues keeping the Stock UCA?
  16. May 15, 2015 at 6:22 PM
    #6516
    YotaBum
    Alex
    North Georgia
    2015 TRD Sport DCSB
    I'm not sure. You could always get everything installed and aligned and then see if you need them.
    I ordered my lift back on April 1st (887s and 90021s up front dakars and 60091 in back) and Low Range sent me the wrong shocks front and rear. Took a couple weeks to get it all squared away and while I was waiting, I went ahead and ordered LR ucas.
    Finally got everything in 2 weeks ago and I tore/strained some muscles in my leg and foot. Killing me finally having everything in the garage and having to wait until I heal to install it!
  17. May 15, 2015 at 6:32 PM
    #6517
    Jefferson10
    San Luis Obispo
    I'm thinking I wont get around to install until 4th of July... maybe sooner if i get time (and a buddies garage). I'm thinking i'll test my luck with the stiff ride and stock UCA's. Just have to order the rear AAL. Who would be better for the AAL and any other misc. fittings? Toytec or wheelers? I know there's a discount for Toytec (like 5%???), is there one for Wheelers?
  18. May 15, 2015 at 6:37 PM
    #6518
    YotaBum
    Alex
    North Georgia
    2015 TRD Sport DCSB
    I'd recommend Dan at Wheeler's... Seems like an awesome guy and answered a ton of questions for me while I was looking at lifts.
    I ordered my lift through Low Range Off Road due to a 10% off promo with free shipping they were running for tax refund season.
    I was going to go with Dan until I stumbled on that deal.
  19. May 17, 2015 at 7:20 PM
    #6519
    moto932
    moto932 What's the matter, Colonel Sandurz? CHICKEN?
    Eric
    Dayton, Ohio
    04 TRD Off Road
    Basically stock. OME 882s, HD Dakars and nitrochrgers, TG front bumper, custom rear bumper, 4Xinnovations sliders, RAT skids, Softopper, 255/85/16 ST MAXX's on 16" steelies, 1" B.O.R.A. wheel spacers Scangaugae II, deck plate mod, grey wire mod,ECGS bushing, diff breather relocation, alarm mod, defrost w/o compressor mod, de-badged, sockmonkey beside decals.
    what kind of lift could i expect out of 883's on my first gen with with a trail gear front bumper?
  20. May 17, 2015 at 8:29 PM
    #6520
    millertime89
    millertime89 Flatlander
    Erik
    Saskatchewan
    06 TRD Sport DCLB 4x4
    Yes sir
    Installed my OME 887's, 90021's, N182's, and LR UCA's last weekend and am really pleased so far!
    Hoseman and samiam like this.
