Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Jun 1, 2015 at 4:01 PM
    #6621
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Shouldn't really need to trim with 255's , assuming stock wheels without spacers
  2. Jun 1, 2015 at 6:39 PM
    #6622
    Base Camp
    Base Camp Instagram: @willismtc
    Willis
    Roanoke, VA
    '14 Base Model 4x4
    Most people go with 255s because of that very fact. My 255/85/16 STMaxx with steelies stuff nicely.
  3. Jun 1, 2015 at 9:29 PM
    #6623
    Oggy
    Oggy Well-Known Member
    David
    Phoenix, Az
    2010 TRD Off Road
    First time post on this thread but long time reader, I have an access cab and going to need new shocks soon. So figured I'd spend a little extra and lift my truck while I'm at it and use it as an excuse. I've heard that 885 coils are for double cabs and 884 coils are recommended for access cabs, is this true?
    I wanna do 885 coils, 5100 all the way around and Dakar leaf springs 2" in the back.
  4. Jun 1, 2015 at 10:18 PM
    #6624
    gefrorenertau
    gefrorenertau Speak German - will travel.
    SoCO
    '13 4Runner SR5
    Correct, stock wheels, no spacing.
    Which means you didn't have to do any trimming even at that size?
    Thanks for the help guys.
  5. Jun 1, 2015 at 11:43 PM
    #6625
    Chepo
    Chepo Tankoma!
    Chepo
    Mexico City
    '11 TRD Sport
    Lots...
    What do you think???
    886's with trim packer
  6. Jun 2, 2015 at 1:03 AM
    #6626
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    Dakars will give you closer to 3". Sometimes 2.5, sometimes 3.5.
    https://www.tacomaworld.com/threads/2nd-gen-ome-dakar-hub-to-fender-measurements.173193/
    If you only want 2" consider a different leaf pack, or the cheap route, a 2" Add A Leaf to go with your stock leaf pack.
  7. Jun 2, 2015 at 3:23 AM
    #6627
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
    Does anyone know how much the 885's will lower with about a 90lb bumper plus a winch added? Or 887's? I would go with 886 but just don't really want a harsh ride...
  8. Jun 2, 2015 at 4:22 PM
    #6628
    Captain Stabbin
    Captain Stabbin Well-Known Member
    Justin
    SOMD
    2010 DCSB
    I bounce it offa stuff.
    I've got a CBI Moab (125 lbs) and a Superwinch Tigershark 9500 on 885's. I didn't squat very much at all, if any (no measurements, sorry), and the ride feels more smooth and planted than with the 885s and stock bumper.
  9. Jun 3, 2015 at 3:14 AM
    #6629
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Ok thanks!
  10. Jun 3, 2015 at 4:09 AM
    #6630
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    About how many inches did you gain going with the 885's and the front bumper w/ winch? I assume about 2"-2.5"?
  11. Jun 3, 2015 at 9:20 AM
    #6631
    Dilleytech
    Dilleytech Well-Known Member
    Jakob
    White salmon, Washington
    07 AC SR5 4x4
    Front ARB bumper, LR UCA's, OME 885/90021 struts, Ome shocks rear, general springs HD leaf pack.
    So I pulled the trigger on my Ome front lift. I have a arb bumper and skid plate with no plans for winch. I went with 885/3/8"spacer/trim packer/90021/ and LR uca(hoping for 2-2.5" of front lift). For the rear I went with General springs HD springs and Ome 90061. (Expecting 1.5-2" of lift in rear).
    So you guys think for 1-5~2 inches in the rear should I have gotten shims? Or would they be a pain to add later on if I experience problems?
  12. Jun 3, 2015 at 10:21 AM
    #6632
    Base Camp
    Willis
    Roanoke, VA
    '14 Base Model 4x4
    Just removed front flaps. Check the backspacing on your wheels. It may also provide limitations. However I can't speak to yours since I am not familiar with them. I will say that I doubt you will have to do much trimming if any with 255s regardless.
  13. Jun 3, 2015 at 10:27 AM
    #6633
    Base Camp
    Willis
    Roanoke, VA
    '14 Base Model 4x4
    I'm not an expert but I believe you may be ok without shims up to the 2.5-3 range. You will have to check your driveline after install to be sure.
    It's only a pain to install if your center pins are not long enough to go through the shim. Then you have to install a collar to allow it to seat properly. Once you have the collar installed you can change out shims easily.
  14. Jun 3, 2015 at 10:52 AM
    #6634
    Dilleytech
    Jakob
    07 AC SR5 4x4
    Well aslong as I can drive on it without destroying something I'm not to worried I guess. Then repair as soon as possible.
  15. Jun 3, 2015 at 11:01 AM
    #6635
    raggedphoto
    raggedphoto Well-Known Member
    Oregon
    DCSB 07 Desert Sand Mica
    For long haul vs short crawl
    Looks awesome! how is the ride with the 886 coil? Winch?
  16. Jun 3, 2015 at 11:16 AM
    #6636
    Chepo
    Chepo Tankoma!
    Chepo
    Mexico City
    '11 TRD Sport
    Lots...
    Thanks!!!
    I'm waiting for the winch... It should be here next week...
    The ride is very stiff!!! I think that it will be better with the winch and of course I need to get used to it!
  17. Jun 3, 2015 at 11:23 AM
    #6637
    raggedphoto
    Oregon
    Hmm okay thanks. I am on the fence about the 886 vs 887. About to order in the next couple weeks, I have a relentless steel bumper and sliders coming and will add a winch shortly after. Not so much worried about keeping a full 3" lift as the ride becoming spongy with all the added weight. *sigh
  18. Jun 3, 2015 at 11:53 AM
    #6638
    Bman4X5
    Bman4X5 There is no substitute for square inches.
    Bruce
    Upland CA
    '15 AC/OR
    Bilstein, Dakar/Icon, Prinsu, CBI, Pelfreybilt, Tepui
    I got 2" in the rear and have NO vibes. I suspect you'll be ok.
  19. Jun 3, 2015 at 1:29 PM
    #6639
    la0d0g
    running for the hills
    For crawling not hauling
    Go with 886s. I have an aluminum Relentless and winch with 886s and only have about 2.5" of lift. With the steal bumper you'll want the beefier coils.
  20. Jun 3, 2015 at 5:13 PM
    #6640
    raggedphoto
    Oregon
    Thanks, thats what I am leaning toward, just scared you know. Hopefully in the next month I'll be posting some pics!
