Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Jun 21, 2015 at 12:39 PM
    #6781
    Festus
    Festus a guy
    Festus
    Jefferson
    05 TRD DCSB
    I think when you get aligned they will adjust your caster and you should have no more rubbing. 265/70 should be no problem.
  2. Jun 21, 2015 at 2:15 PM
    #6782
    FireRoad Bomber
    FireRoad Bomber New Member
    Travis
    San Antonio
    13 PreRunner
    I have a ? Are the OME 9000 and springs a better/smother setup then Bilstein 5100's and Eibach's ? I am asking Because I have a Toytec 3in setup and hate it. I would love to go with OME if I could get 3in out of them. But it is a 2wd prerunner so most of my driving offroad is service roads at a moderate rate of speed. Thanks for your input.
  3. Jun 21, 2015 at 4:15 PM
    #6783
    Captain Stabbin
    Captain Stabbin Well-Known Member
    Justin
    SOMD
    2010 DCSB
    I bounce it offa stuff.
    Yeah go with OME shocks. They stay cooler than other shocks in this travel range, which is beneficial for your application, and are smoother than 5100s.
    Edit: eibach makes a spring and does not make a shock, iirc.
  4. Jun 22, 2015 at 6:33 AM
    #6784
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
    I'm considering a front bumper with my OME lift when I order it what front bumpers would y'all recommend? I'm looking at ones with full hoops. What's y'all's input on which bumper to go with..
  5. Jun 22, 2015 at 7:58 AM
    #6785
    badphish14
    badphish14 Well-Known Member
    Long Island
    '12 TRD OFF ROAD
    After reading through this and stalking this thread I think I finally figured out what I want.
    If I go with wheelers:
    NitroCharger front and rear shocks, 2885 front coil springs, CS047R Dakar rear leaf springs w/ Wheeler’s polyurethane bushings, 95PF5 front trim packer for driver side strut, FK29 driveline bearing drop kit and Wheeler’s u-bolts!
    On a 2012 OF with bed rack, RTT and sliders, should put me around 2 1/2"?
    I'm not really looking for that magic number 3 so under isn't an issue. No plans for bumper of winch. Just looking for a little lift and better ride.
  6. Jun 22, 2015 at 8:29 AM
    #6786
    Dilleytech
    Dilleytech Well-Known Member
    Jakob
    White salmon, Washington
    07 AC SR5 4x4
    Front ARB bumper, LR UCA's, OME 885/90021 struts, Ome shocks rear, general springs HD leaf pack.
    A week after my 885 lift with no extras on the truck besides my arb bumper mine settled from 3" down to 2" in the front.. with your sliders and no front bumper 2.5 might be accurate. I would say get the 3* shims while your at it..
  7. Jun 22, 2015 at 9:30 AM
    #6787
    Larry
    Larry CARL
    CARL
    Potential set-up:
    OME shocks front & rear (orig. or sport Nitro's).
    OME 883 or 884 coils.
    taco-lean shim.
    Dakars with leaf removed or Wheelers?
    265 tires on my stock 16" steelie rims.
    This should net me about 1.5" of lift. With no need for additional suspension modifications.
    I'm not looking to run the Baja 1000 or do any rock climbing. But a little better stance. Better ride. And better performance in the woods and at the farm, without breaking the bank or destroying the on pavement ride would be perfect.
    I'm open to opinions...suggestions...thoughts...
  8. Jun 22, 2015 at 10:22 AM
    #6788
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    883's / wheelers with a leaf removed
    Larry likes this.
  9. Jun 22, 2015 at 10:57 AM
    #6789
    Larry
    Larry CARL
    CARL
    And I'd still have some rake to absorb a load or tow a boat?
  10. Jun 22, 2015 at 11:59 AM
    #6790
    OZ-T
    Peter North
    British Columbia
    Should go up about 1 1/2" front and rear , so factory rake , just 1 1/2" higher
  11. Jun 22, 2015 at 12:00 PM
    #6791
    Larry
    Larry CARL
    CARL
    Thanks. That's perfect. :thumbsup:
  12. Jun 22, 2015 at 12:04 PM
    #6792
    Larry
    Larry CARL
    CARL
    To clarify...
    the Wheelers 8-leaf with one removed. Or the Wheelers 5-leaf with one removed? TIA
  13. Jun 22, 2015 at 12:06 PM
    #6793
    badphish14
    Long Island
    '12 TRD OFF ROAD
    This is pretty much what I'm looking for to.
    If I bump up the coils from 883 to 884 or 885 would I still be level with wheelers add a leaf?
  14. Jun 22, 2015 at 3:37 PM
    #6794
    TacoCasita
    TacoCasita Active Member
    Robert
    CenterPoint, Indiana
    15 Taco DC LB Sport 4X
    Front tow hook, bed tie downs, soon: OME lift, new tires, 17" Method Mesh wheels.
    Anyone? Anyone? Bueller? Bueller?
    This is what the bottom of the shock looks like. The sock with the least amount of thread showing is longer.
    I'm trying to finish gathering the parts to put my lift on and this is driving me insane,OCD.
    Are there any instructions anywhere for how to assemble these coils?
  15. Jun 22, 2015 at 3:43 PM
    #6795
    OZ-T
    Peter North
    British Columbia
    5 leaf HD pack
    Larry[QUOTED] likes this.
  16. Jun 22, 2015 at 3:44 PM
    #6796
    OZ-T
    Peter North
    British Columbia
    The OME trim packer goes at the bottom as pictured
  17. Jun 22, 2015 at 3:48 PM
    #6797
    TacoCasita
    Robert
    Yes. The trim packer is on right. I just can't figure out why there is a lack of theads on that shock? Is it because of the trim packer or did it not get tightened down enough?
  18. Jun 22, 2015 at 3:52 PM
    #6798
    OZ-T
    Peter North
    British Columbia
    If the trim packer side shows less threads it's likely the added thickness of the trim packer
  19. Jun 22, 2015 at 3:56 PM
    #6799
    Quang
    Quang Austin is weird!
    quang
    PFLUGERVILLE/ Hutto
    2015 tacom trd off road
    OME 3” lifts OME Dakar leafs Allpro upper control arm Front and rear steel bumpers from relentless fab Some amazon light bar Allpro skid plate
    what lube do i use for the bushing in the dakar leafs when installing?
  20. Jun 22, 2015 at 3:58 PM
    #6800
    Quang
    quang
    PFLUGERVILLE/ Hutto
    and would i need UCAs with OME 3'' with dakar leafs?
