Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Jul 8, 2015 at 7:44 PM
    #6881
    UTdez23
    UTdez23 Half Baked Dez Cruiser
    Jesse
    SLC, UT
    09 4x4 SR5 DCLB
    Bilstein 5100's front & rear, Eibach 620 lb Coils, Dakar Leaf Packs, Rear Diff Breather Mod, All Pro Sliders, RCI IFS Skid
    Question about Dakar leaf packs.. Will these work well with the rear bilstein 5100's? I currently have stock 3-leaf sets with Wheelers 3-leaf 1.5" lift heavy duty AAL's on top. Works great but looking for a more heavy duty set up and a bit of additional lift. Will the rear bilsteins "travel" accordingly with this higher lift? I know I've heard of them sometimes over traveling with higher rear leafs.. Also, I have a shell and carry various gear consistently (gas can, hi-lift, emergency gear, etc.), so weight in the back is about 250-300 lbs average consistent. Thanks in advance..
  2. Jul 8, 2015 at 7:53 PM
    #6882
    Anzy
    Anzy Well-Known Member
    Eric
    Pennsylvania
    Thanks!
    Honestly......I'm really not sure. I had a Ready Lift spacer lift on before this. And it definitely sits higher in the front than that. It's gotta be close to 3", but I didn't take any actual measurements.
  3. Jul 8, 2015 at 8:09 PM
    #6883
    300AACTaco
    300AACTaco Well-Known Member
    Alaska
    Black '15 DCSB TRD Off Road 4x4
    ARB Old Man Emu 90000s and 60091s OME 886s, Trim Packer, Icon Tubular Uniball UCAs, CMC, Invisible Sway Bar, Dakar Rear Leaf Packs, Timbren Rear Bumpstops, All Pro U-bolt flip up kit, Method Race Wheels NV 16X8 4.5BS, Cooper ST Maxx LT285/75/16, DEPO Black Tail Lights, Weathertech Floormats, Cascadia Vehicle Tents Mt. Shasta in Earth Tone Green, Custom Green Tree Fabrication Bed Rack, N-Fab Spare Tire Bed Mount
    That's alright! I didn't take any of mine either but I'm sure my 887s got me around 3" as well
  4. Jul 8, 2015 at 8:40 PM
    #6884
    la0d0g
    running for the hills
    For crawling not hauling
    Answered this last page. Get some extenders for more droop and you're good to go.
  5. Jul 8, 2015 at 8:42 PM
    #6885
    UTdez23
    Jesse
    SLC, UT
    09 4x4 SR5 DCLB
    Right on, sorry didn't search more prior to posting. Thanks for the insight, I'll check those extenders out.
    la0d0g[QUOTED] likes this.
  6. Jul 8, 2015 at 8:51 PM
    #6886
    Sigi
    Sigi Well-Known Member
    Sigi
    Sfv ca
    06 tacoma 4x4 trd offroad
    Help!! :) .I'm have been running 886 now for about 1 year and they still feel pretty stiff. When I'm off-roading I feel the front bounce a lot . Will 885 be better ? (I have an arb front bumper,warn 9.5xp-s winch, full skids and sliders) thanks !
  7. Jul 8, 2015 at 8:58 PM
    #6887
    la0d0g
    ^^ 885s have a spring rate that's almost 70lbs less so yes it'll feel more cushy but you will probably sag a bit more.
  8. Jul 8, 2015 at 8:58 PM
    #6888
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Get 887's
  9. Jul 8, 2015 at 9:00 PM
    #6889
    Dirtboyz
    Dirtboyz Well-Known Member
    Spanaway, WA
    DCSB trd sport 4x4
    Front bilstein 5100 with OME 884 w/trim pack, 17" fuel trophy wheels wrapped with 32" toyot open country m/t, bakflip fibermax tonneau cover, Avec 30" led light bar behind lower grille, marathon seat covers in max 5 camo pattern, trimmed front and rear mud flaps, more to come.
    Why not try the wheelers super bump stops firsts if you haven't already pt them on. I here it's a night and day different from oem bump stops.
  10. Jul 9, 2015 at 3:04 AM
    #6890
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
    Yeah I hear the same about the wheelers super bumps also.
  11. Jul 9, 2015 at 3:05 AM
    #6891
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Let us know what you do cause I'm thinking of going with 886's when I get my lift. I'm also going with arb bumper and a winch.
  12. Jul 11, 2015 at 7:37 AM
    #6892
    Base Camp
    Base Camp Instagram: @willismtc
    Willis
    Roanoke, VA
    '14 Base Model 4x4
    x2. Try this first. Not happy?
  13. Jul 11, 2015 at 7:40 AM
    #6893
    Base Camp
    Willis
    Roanoke, VA
    '14 Base Model 4x4
    ...and a build page and... possibly an avatar? ;)
  14. Jul 11, 2015 at 8:36 AM
    #6894
    Dilleytech
    Dilleytech Well-Known Member
    Jakob
    White salmon, Washington
    07 AC SR5 4x4
    Front ARB bumper, LR UCA's, OME 885/90021 struts, Ome shocks rear, general springs HD leaf pack.
    Correct me if I'm wrong but don't bump stops just make it softer when you bottom out your suspension? Sounds like his problem is springs that are to stiff to his likeing?
  15. Jul 11, 2015 at 11:02 AM
    #6895
    badphish14
    badphish14 Well-Known Member
    Long Island
    '12 TRD OFF ROAD
    About to pull the trigger for my lift. 885 up front with "older" nitro shocks all around and wheelers progressive add a leaf pack and trim pack to correct driver lean.
    This should put me around 2-2 1/2 right?
    Access cab with sliders, RTT and going to add a small bar in the front.
  16. Jul 11, 2015 at 11:42 AM
    #6896
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    Maybe I'm just not understanding you correctly and the other people were, it's just that when you say bounce it is usually caused by the lack of dampening. How much bounce? Like I said bounce should be controlled by your shocks and struts. Did you give your struts a visual inspection to see if any oil was leaking? If in case you just mean stiffness or softness of the springs than yes, if the 886 is too stiff you can go and change it to the 885 or the 887 to keep more of the lift.
    Sounds to me that your thinking about better dampening though, in which case that means stepping up to coilovers
  17. Jul 11, 2015 at 12:14 PM
    #6897
    Dilleytech
    Jakob
    07 AC SR5 4x4
    I got 2" with 885 and a arb bumper and no sliders on my AC. Also with the 1/4" trim packer I still had 1/2" of taco lean in the front. So I would say about 2 1/4 front lift would be my guess.
  18. Jul 11, 2015 at 1:56 PM
    #6898
    Dirtboyz
    Spanaway, WA
    DCSB trd sport 4x4
    I was throwing that out there because in the since if he might be bottoming out the stock bump stops are not as forgiving as the wheelers ones. So in saying that the wheelers bump stops would soften the compact on the LCA which in a sense would reduce the bouncing when/if making impact with the LCA. From what I've read on the super bumps compared to oem is night and day difference. When hitting the oem bump stop is like hitting ur LCA in a sense. I didn't pay no mind to this either until I got up under and looked at my oem bump stops. Feel just like hard ass rubber. I was just giving some cheap advice to try out but I can understand the other posters side to with the damping issue. If the struts are not a good damping strut that could be the issue as well. Was just giving my 2 pennies. It was just a thought. I have 884 with billy 5100 and I can tell if I hit a pot hole or bump it feels kind of rough and I know the 5100 are a good damping shock so I am taking a chance on a cheap upgrade with the wheelers dampers to see if it makes a difference. Not saying it will but if anything they are only 55 bones so why not. Just another mod under my belt lol!
  19. Jul 11, 2015 at 2:30 PM
    #6899
    Dilleytech
    Jakob
    07 AC SR5 4x4
    Ya that makes sense.
  20. Jul 11, 2015 at 3:18 PM
    #6900
    Dilleytech
    Jakob
    07 AC SR5 4x4
    Does anyone know what the max reasonable amount of spacer lift one could add above 885 Ome coils? I was planning to add 1/4" on passenger side and 3/8" on the driver to help with the taco lean. But would 3/8" and 1/2" be a mistake? Just trying to gain another 3/4".
