Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Jul 21, 2015 at 3:47 PM
    #7061
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
    Ok thanks Oz.
  2. Jul 21, 2015 at 4:20 PM
    #7062
    frizbal
    frizbal Well-Known Member
    Sean
    Tulsa, Oklahoma
    2012 TRD Off-Road
  3. Jul 22, 2015 at 1:09 AM
    #7063
    Dirtboyz
    Dirtboyz Well-Known Member
    Spanaway, WA
    DCSB trd sport 4x4
    Front bilstein 5100 with OME 884 w/trim pack, 17" fuel trophy wheels wrapped with 32" toyot open country m/t, bakflip fibermax tonneau cover, Avec 30" led light bar behind lower grille, marathon seat covers in max 5 camo pattern, trimmed front and rear mud flaps, more to come.
    Whatever you think. I can't speak for others but I am over it. OZ, if you don't mind would you give me your knowledge on my prior question? I installed rear 5100's the other day and I know the specs say 20lbs for the top nut but can't really judge that based on the rubber bushing until you bottom the bushing out which I know is not correct. Where is a good medium to torque the nut to for proper install. As of right now I have the top nut tighten to where the rubber bushing is flush with the top washer. The bushing isn't budging out at all and I have around about 1/4 of the thread showing above the nut. Is this correct for install or should I back the nut out a bit or tighten it more which I don't believe that is that case?
  4. Jul 22, 2015 at 2:48 AM
    #7064
    Dirtboyz
    Spanaway, WA
    DCSB trd sport 4x4
    I got the same result because the OME coils compensate for the lift. With the 5100's you have set the shocks at 1.75 setting to get close to level. This is achieved by the shock compressing the coil to give you the height. With having the OME 884 coils you achieve the height difference with the coil not the shock so therefore returning the shock back to the zero setting. Hope this makes sense. You basically get the same amount of lift just using different technique/components. That why I said it was a smother ride with having the OME 884 with the 5100 set at 0 over having the oem coils compressed with the 5100. Someone will correct me if I'm wrong but having the oem with 5100 set at 1.75 puts more stress on coils and shocks versus having the lift solely lifted by just the coil(884). In short the 884 compensate with height being that they are taller coils than oem so there is no need to stretch them out like you do with the oem coils with 5100's. Hope this answers your question without confusing you ha
  5. Jul 22, 2015 at 3:14 AM
    #7065
    Dirtboyz
    Spanaway, WA
    DCSB trd sport 4x4
    Yea you definitely do not want to preload the OME coils at all.
  6. Jul 22, 2015 at 6:19 AM
    #7066
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    So do the 886's flex/stuff good? I see a lot if people with the 885's and 887's on here and they look like they're front tires are stuffing very good in the wheel well. Do the 886's do the same cause I haven't seen many with the 886's flexing.
  7. Jul 22, 2015 at 7:46 AM
    #7067
    SixthSnail
    SixthSnail I have no idea what I'm doing
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    Okay now I've gotten an answer to set them at 0 and one to set them at 1.75! Haha which is better?
  8. Jul 22, 2015 at 7:58 AM
    #7068
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    1.75 with OEM ( Toyota ) stock coils , 0 with the OME 884 coils
  9. Jul 22, 2015 at 8:17 AM
    #7069
    SixthSnail
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    And 0 with 887 correct? and that will put me at the same height as stock coils with them set at 2.5?
  10. Jul 22, 2015 at 8:21 AM
    #7070
    Normantaco
    Normantaco Well-Known Member
    Pensacola, Fl
    16 4Runner SR5
    Setting 0 with any OME coil (884,885,886,887, etc). Preloaded settings for stock(toyota) coils to achieve lift.
  11. Jul 22, 2015 at 8:26 AM
    #7071
    OZ-T
    Peter North
    British Columbia
    Yes at 0
    No , 887's will get closer to 3" with no additional front weight
  12. Jul 22, 2015 at 8:27 AM
    #7072
    SixthSnail
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    Awesome so they should get me similar since I have the steel bumper! Thanks a ton!
  13. Jul 22, 2015 at 8:33 AM
    #7073
    SixthSnail
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
  14. Jul 22, 2015 at 8:34 AM
    #7074
    OZ-T
    Peter North
    British Columbia
    How much does your bumper weigh ?
  15. Jul 22, 2015 at 8:35 AM
    #7075
    SixthSnail
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    90 pounds.
  16. Jul 22, 2015 at 8:35 AM
    #7076
    OZ-T
    Peter North
    British Columbia
  17. Jul 22, 2015 at 8:39 AM
    #7077
    SixthSnail
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    So with the 90 pound bumper I should go 887s? Probably gonna need some new UCAs huh?
  18. Jul 22, 2015 at 8:49 AM
    #7078
    OZ-T
    Peter North
    British Columbia
    I think you'll be fine with 887's , they just won't provide a full 3" with the weight of the bumper
    I would get UCA's , yes
  19. Jul 22, 2015 at 8:51 AM
    #7079
    SixthSnail
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    Sweet thanks for all of your help!
  20. Jul 22, 2015 at 8:55 AM
    #7080
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    Question about additional weight and which OME spring. I am a 15 access cab 4x4, I have 150+/- lbs constant crap in the truck and tool box, and 150+/- lbs in steel sliders on the truck. I am shooting for 2" front lift, will get dakars out back. Will the 884's get me there, or should I go 885's? I do not want to get close to 2.5", to avoid UCA's at this time. Right now my front hub to fenders are both at 20". Also debating on OME nitros, or billy 5100 front / 5125 rear.
