Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Aug 10, 2015 at 8:49 AM
    #7301
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    That only makes sense if you're constantly riding around with the regular leaf pack engaging the overload
  2. Aug 10, 2015 at 8:51 AM
    #7302
    OZ-T
    Peter North
    British Columbia
    So what you're saying is the 12" of regular pack riding on the upper overload would somehow ride different than 12" of the regular pack riding on an overload 1/2" lower ?
    How would that effect the way the regular leaf set behaves ?
  3. Aug 10, 2015 at 8:53 AM
    #7303
    tyfoon11
    tyfoon11 Raguel
    J
    Where bald eagles roam, Ca
    garden shed
    cool, so in theory you could put a + on driver side and a - on passenger to correct lean. my taco lean is bothering the crap outta me
  4. Aug 10, 2015 at 9:16 AM
    #7304
    Mr Salty
    Mr Salty "Give up the good to go for the great"
    Hermmy
    SoCal (Bro Capital of the world)
    White SR5 Pre-runner
    Lots of chrome
    The first stage rests on the first over load which rests on the second overload. During very minimal up travel the first five leafs flatten out over the first overload. This overload doesn't allow for very much flex since its further supported by the shorter over load underneath it. This translates to a stiffer ride at minimal flex.
    I get the purpose of the overload and I get why you would question me, but again my response is based on personal experience.
    To me the improvement made sense based on what the pack was doing and how quickly the overloads engaged and is why I ditched the longer overload. The end result aligned with what I thought would happen, a slight improvement in on road ride and better flex when in the dirt.
  5. Aug 10, 2015 at 10:16 AM
    #7305
    OZ-T
    Peter North
    British Columbia
    Not arguing , just wondering why you didn't remove the 3rd
  6. Aug 10, 2015 at 10:26 AM
    #7306
    frizbal
    frizbal Well-Known Member
    Sean
    Tulsa, Oklahoma
    2012 TRD Off-Road
    :eek:
    Trying to improve your self image? :rofl:
  7. Aug 10, 2015 at 10:33 AM
    #7307
    Mr Salty
    Hermmy
    Lots of chrome
    For my use (on road and off) removing the longer overload was the better option, I tried both. I like the initial resistance from the first five and I like the flex of the single overload vs. the two when off-roading.
    I've played with these packs quite a bit and this setup is just my personal preference.
  8. Aug 10, 2015 at 10:35 AM
    #7308
    OZ-T
    Peter North
    British Columbia
    Do you find the regular pack going into negative arch with heavy loads ?
  9. Aug 10, 2015 at 10:36 AM
    #7309
    Mr Salty
    Hermmy
    Lots of chrome
    I understood why he was questioning me so no beef here.
  10. Aug 10, 2015 at 10:41 AM
    #7310
    frizbal
    Sean
    Tulsa, Oklahoma
    2012 TRD Off-Road
    I'm just giving him shit. Always look forward to his responses, sarcastic and helpful alike.
  11. Aug 10, 2015 at 10:45 AM
    #7311
    Mr Salty
    Hermmy
    Lots of chrome
    When offroading I carry about 250 lbs (rough estimate) of weight and the packs support this weight easy with no frowning. As far as carrying heavy loads, I don't do so a whole lot, but when I do I have quick attachment bumps I install that reinforce the packs perfectly.
  12. Aug 10, 2015 at 10:48 AM
    #7312
    OZ-T
    Peter North
    British Columbia
    Makes sense , I have a constant 450 lbs then add load to that
  13. Aug 10, 2015 at 11:39 AM
    #7313
    Dr. Jekyll
    Dr. Jekyll Well-Known Member
    Jimmy
    Honolulu, HI
    2015 Black DCSB Limited PreRunner
    Okay I've heard a couple of options but would like a few more opinions. Here's my situation:
    Truck: 2015 Double Cab Prerunner Short Bed
    Adding: Pelfreybilt Plate Bumper with center hoop 115 lbs. and Pelfreybilt Sliders w/ top plates 85 lbs.
    Goal: Raise the front end about 2" after the armor is in.
    Options: Billy 5100 Adjustables up front with either the 884 or 885.
    I'm not getting larger tires yet as the truck is brand spanking new so if anything I'll wait till I jump up to 32" tires at 275/65R18
    Thanks for any input or feedback you may have.
  14. Aug 10, 2015 at 11:41 AM
    #7314
    T4RFTMFW
    T4RFTMFW Well-Known Member
    You'll need 886s. @tacomgee has a similar setup you want to have and is on 885s and is under 2" up front with bumper and sliders.
  15. Aug 10, 2015 at 8:34 PM
    #7315
    shr133
    shr133 Well-Known Member
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
    Cool I've thought of removing the overload for that reason. Removing the 3rd seams to make the pack too soft from the reviews I've read...
  16. Aug 10, 2015 at 11:43 PM
    #7316
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    So both HK and LK come with CS047R?
  17. Aug 10, 2015 at 11:59 PM
    #7317
    OZ-T
    Peter North
    British Columbia
  18. Aug 11, 2015 at 6:44 AM
    #7318
    AJC84
    AJC84 Well-Known Member
    Andy
    2011 DC LB V6 4X4 MAG GREY
    Lift going in today need some help fast! Have Taco Lean question. Having Dakars and 885s installed with toytec 10mm top plate spacers on my 2011 double cab long bed 4X4. Doing nitro charger sport shocks/struts.
    My stock hub to center measurements are
    Driver: 20.5
    Passenger: 20
    Rears: 21.5
    1. So my drivers side is slightly higher before lift. I have read a few threads saying after putting in an OME lift there is "Taco Lean". It seems the factory coils are side specific. So can I expect to have the drivers side sag quite a bit after putting in my lift?
    2. If I have mismatched dakars I will put the + side on the drivers side. But doesn't a lot of the sag come from the front drivers side?
    3. Would I have to also to a trim packer in the front to bring it up?
    4. Can the trim packer be installed in conjunction with the top plate spacers I am doing? I am not sure where these install on the coil assembly.
    Thanks in advance!
  19. Aug 11, 2015 at 7:08 AM
    #7319
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Anderson, SC
    2015 DCSB 4x4 trd offroad
    Ome 887s, dakars, lr uca,sliders, konig countersteer,
    So to answer your questions fast .. your new shocks and struts will cause the taco lean.. putting the + sided pack on driver side helps in general.. not a substitute for the trim packer .. the other thing is the trim packer goes on the shock itself.. you will see a ring/lip on the shock.. it slides on and sits there.. this should be installed before coils go on.. its impossible once its together.. one other thing is to make sure you have extended top hat spacer bolts for the 10mm spacer if not.. may not be able to tighten the top over the spacer
  20. Aug 11, 2015 at 7:46 AM
    #7320
    AJC84
    Andy
    Thanks Jeff.
    Anyone have pics of installed trim packer or pic of shock and place trim packer goes?
    So is it impossible to install trim packer at a later date or just a pain to do? I don't think the shop doing my lift has this part in stock.
    I do have extended studs for my top plates.
