Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Aug 20, 2015 at 6:50 PM
    #7521
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Synthetic seems to be the crowd favorite. Strong, lightweight, less dangerous.
    Also, more fragile, less robust, more expensive.
  2. Aug 20, 2015 at 6:54 PM
    #7522
    JWROSE4
    JWROSE4 Well-Known Member
    Jonny
    Virginia
    2013 DCSB SR5 4X4
    Work In Progress
    Yea the fragile and less robust part is what I was afraid of. Although no more than I would probably be using it, it may not be that bad.
  3. Aug 20, 2015 at 7:21 PM
    #7523
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    The slide in shims from headstrong. Do I need to do anything with the center pin of the dakar? Or just place these underneath? Do these just sit on top of the axle or get bolted down other than just the U bolts? Do you recommend the pin through over the slide in?
  4. Aug 20, 2015 at 7:22 PM
    #7524
    T4RFTMFW
    You'll need the centering pin lengtheners. Did you get those?
  5. Aug 20, 2015 at 7:23 PM
    #7525
    la0d0g
    running for the hills
    For crawling not hauling
    I have synthetic. If you take care of it it'll take care of you. Steel is pretty bullet proof but can be sketchier.
  6. Aug 20, 2015 at 7:32 PM
    #7526
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    This
  7. Aug 20, 2015 at 7:36 PM
    #7527
    crashngiggles
    Jared
    No I didn't. ....does headstrong carry those? If not where might I pick up some? Are they just longer replacement pins for the dakars? Wait....it actually says that the shims from headstrong come with them......yeah.
  8. Aug 20, 2015 at 7:37 PM
    #7528
    T4RFTMFW
    Headstrong does, yes. I need some myself (I ordered some but didn't see them in my box).
    They are essentially a spacer.
  9. Aug 20, 2015 at 7:38 PM
    #7529
    Fern11
    Fern11 Well-Known Member
    Karson
    Lake Charles LA
    11 Timberland Mica 4x4 6-Speed TRD Sport
    OME COMPLETE LIFT. 285-70-17 Dynapro's. 17x8 Pro Comp 7005.
    Yeah j ordered some with my lift
  10. Aug 21, 2015 at 12:34 PM
    #7530
    Mr Salty
    Mr Salty "Give up the good to go for the great"
    Hermmy
    SoCal (Bro Capital of the world)
    White SR5 Pre-runner
    Lots of chrome
    The thing with their shims is they are a couple mm too thick for the OME and OEM ubolts. All other aftermarket ubolts measure more like 2 5/8", which is slightly wider.
    What does this mean for those with factory or OME ubolts... you'll have to try and squeeze them in-between using force (say hello to your mallet) OR take the shims down a bit so they slide easily into place (the better non-temperamental approach). Ask me how I know after "sliding" these into place on my neighbors truck :(
    I guess this is why they have this statement on their site (its me missing details like this that get me each time)
    "NOTE: depending on application and remaining thread left on ubolts longer ubolts may be required. Also shims may need to be filed down a bit in order to fit between the ubolts (this is common with factory as well as OME brand ubolts)".
  11. Aug 21, 2015 at 12:37 PM
    #7531
    OZ-T
    Peter North
    British Columbia
    I have Toytec shims on with the U bolts that came with my OME kit , we didn't have to file them but I also didn't slide them in , they went on with the U Bolts slacked right off
  12. Aug 21, 2015 at 1:15 PM
    #7532
    trailbound
    trailbound Well-Known Member
    Rob
    Surprise, AZ
    2016 DCSB TRD OR 4x4
    I haven't installed my dakars yet but when I ordered them from Wheeler's, Dan said to get the next longer length U-bolt (8.5") to run with the Toytec 3° shims. The shims also came with the longer center bolts to replace the ones that come on the dakars. I can always trim the u-bolts if the look too long but an inch shouldn't matter much.
  13. Aug 21, 2015 at 1:22 PM
    #7533
    T4RFTMFW
    Shims from Headstrong are slightly wider than the OME u bolts. They offer Maxtrac u bolts which are wider as an alternative for those who anticipate or choose to run the shims, which are slightly wider.
    I have OME u bolts and plan on just machining a little off the shims instead. I think at the time of my order they were out of stock on Maxtrac u bolts.
  14. Aug 21, 2015 at 1:24 PM
    #7534
    Mr Salty
    Hermmy
    Lots of chrome
    The shims are not that thick so longer center pins and ubolts are not really needed. There's already enough length there to support the addition of the shims.
  15. Aug 21, 2015 at 1:24 PM
    #7535
    T4RFTMFW
    Agreed. Plenty of length on the u bolts. I drilled out the bump stops a little to avoid cutting the centering pins down should I want to add an AAL or something later.
  16. Aug 21, 2015 at 1:26 PM
    #7536
    Mr Salty
    Hermmy
    Lots of chrome
    Yeah the ubolts and the center pins are long enough to support the addition of their AAL thus adding shims (both slide in and none slide in ones) wouldn't be an issue.
  17. Aug 21, 2015 at 1:27 PM
    #7537
    OZ-T
    Peter North
    British Columbia
    I think there is some confusion re longer centre pins and pin head lengtheners / pin collars
  18. Aug 21, 2015 at 1:34 PM
    #7538
    Mr Salty
    Hermmy
    Lots of chrome
    Regardless of shim design both will need more length from the center pin and ubolts. In the case of the OME rear set-up both the ubolts and center pins will allow for the addition of shims due to their length.
  19. Aug 21, 2015 at 1:36 PM
    #7539
    trailbound
    Rob
    Surprise, AZ
    I'm not sure either and just went off their recommendation. I believe that the standard u-bolts are 7.5". I just checked the shims and they measure .250" on the thin end and taper up to .465". There is a .020" counter bore on the one side of the hole which must be for the bolt head to rest on.
  20. Aug 21, 2015 at 1:36 PM
    #7540
    OZ-T
    Peter North
    British Columbia
    But slide in shims don't work without extending the head of the centre pin by using a collar
