Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Aug 26, 2015 at 2:43 PM
    #7641
    mahaloTaco
    mahaloTaco TcBob's BFFL
    Max
    Los Angeles
    13 RC 4x4 S/C'd lockers 4.88's Airflow Snorkel McNeil Glass
    What do you guys think:
    Front struts: 5100 set to 2.5"
    Rear 5100 shocks and wheelers progressive AAL For now until I can buy UCA's
    And coils?
  2. Aug 26, 2015 at 2:44 PM
    #7642
    Dr. Jekyll
    Dr. Jekyll Well-Known Member
    Jimmy
    Honolulu, HI
    2015 Black DCSB Limited PreRunner
    Nope. 885s and 5100's set to 0.
    mahaloTaco[QUOTED] and Dirtboyz like this.
  3. Aug 26, 2015 at 2:48 PM
    #7643
    T4RFTMFW
    T4RFTMFW Well-Known Member
    I had 5100s at 1.75" but otherwise the same setup. 5100s at all 4 corners and the same 3 leaf AAL in the rear.
    I'd definitely so OME coils over 2.5 on the 5100s. Also, I would probably wait to lift the front until you see how much lift you need to compensate from the AALs.
    mahaloTaco and Dr. Jekyll like this.
  4. Aug 26, 2015 at 2:56 PM
    #7644
    Dirtboyz
    Dirtboyz Well-Known Member
    Spanaway, WA
    DCSB trd sport 4x4
    Front bilstein 5100 with OME 884 w/trim pack, 17" fuel trophy wheels wrapped with 32" toyot open country m/t, bakflip fibermax tonneau cover, Avec 30" led light bar behind lower grille, marathon seat covers in max 5 camo pattern, trimmed front and rear mud flaps, more to come.
    you could do that if you were in a pinch but like Jekyll said, 885 w/5100 set at 0. will give you a way better ride.
    mahaloTaco likes this.
  5. Aug 26, 2015 at 2:59 PM
    #7645
    Dirtboyz
    Spanaway, WA
    DCSB trd sport 4x4
    You could do that if you were in a pinch but you will have a better ride going with what Jekyll said!!
    Dr. Jekyll[QUOTED] likes this.
  6. Aug 26, 2015 at 3:09 PM
    #7646
    Arailt
    Arailt Well-Known Member
    Dallas, TX
    2019 GX460
    The 884/5100s on my DCSB 4x4 settled to just under 2" of lift. You'd probably see 2" or just over on a PreRunner.
  7. Aug 26, 2015 at 3:10 PM
    #7647
    Dr. Jekyll
    Jimmy
    Honolulu, HI
    Exactly what I was thinking.
  8. Aug 26, 2015 at 3:34 PM
    #7648
    Dirtboyz
    Spanaway, WA
    DCSB trd sport 4x4
    That's what I was getting around to but in longer words I guess. LOL
  9. Aug 26, 2015 at 4:04 PM
    #7649
    JWROSE4
    JWROSE4 Well-Known Member
    Jonny
    Virginia
    2013 DCSB SR5 4X4
    Work In Progress
    you obviously do some hard core off roading and therefore love your 886s. I will be doing offroading but nothing to your extreme. I am planning on running an offroad bumper and am on the fence as to whether I want an aluminum or steel one. i plan on putting a winch on it eventually just am not sure if i really need to go with the steel. anyhow all that being said would you say the stiffness of the 886s is too much for a daily driver that will not be offroad as much as yours is? just really on the fence about what setup i want to go with, 886 and steel bumper or 887 and aluminum. thanks.
  10. Aug 26, 2015 at 4:14 PM
    #7650
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Anderson, SC
    2015 DCSB 4x4 trd offroad
    Ome 887s, dakars, lr uca,sliders, konig countersteer,
    So I talked to two different companies today.... I'm dcsb 4x4 after research I am thinking 884x up front and Dakars in rear.. should be about 1.75-2 up front.. and 2.5-3 in rear which would yield an inch rake.. which once I put rtt and other stuff in bed even loaded will have a rake.. no bro lean ever..
  11. Aug 26, 2015 at 4:17 PM
    #7651
    Jeffvt0508
    Jeff
    Anderson, SC
    Also.. would not need upper control arms and no diff drop..
  12. Aug 26, 2015 at 4:22 PM
    #7652
    T4RFTMFW
    No UCAs isn't a guarantee. My truck drove noticeably worse at 1.75".
    Arailt likes this.
  13. Aug 26, 2015 at 4:32 PM
    #7653
    Jeffvt0508
    Jeff
    Anderson, SC
    But you are a prerunner.. I needed them too in mine... but most 4x4 can get away with out.. may not be perfect but are able to do it.. 884 make sure of that
  14. Aug 26, 2015 at 4:32 PM
    #7654
    la0d0g
    running for the hills
    For crawling not hauling
    I do off road a bunch but I also daily drive my truck and I don't consider it too stiff. I also had 884s before the 886s and I didn't think there was a huge difference, stiffnesswise, between the two. I also like the option of being able to add more weight as I do mods without losing height. I have a big ass battery too to hold up ;)
  15. Aug 26, 2015 at 4:39 PM
    #7655
    JWROSE4
    Jonny
    Virginia
    2013 DCSB SR5 4X4
    Work In Progress
    I also forgot to mention I plan on doing skids underneath as well. So I guess regardless of which bumper I go with the 887 are going to lose lift quickly once I start adding those. I really want to get as close to 3 inch as I can get and not lose it with weight. Just curious, how stiff's it gonna be till I get the bumper cause it could be a couple to 6 months before I can get the bumper. And why such a big battery?
  16. Aug 26, 2015 at 5:17 PM
    #7656
    la0d0g
    It'll be stiff but I don't think it'll be something you hate, consider it motivation to get your bumper on :)
    WRT to the battery, mine died so I picked up a platinum diehard marine. Things weighs like 80#s. Since I have a winch and lights and stuff I didn't want to run out of juice.
    Kyitty likes this.
  17. Aug 26, 2015 at 5:20 PM
    #7657
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    Just so you know the 885 is what OME recommends for the Tacoma Double Cab.
    Jeffvt0508[QUOTED] likes this.
  18. Aug 26, 2015 at 5:21 PM
    #7658
    Jeffvt0508
    Jeff
    Anderson, SC
    I know.. but I don't think I want to be so close to changing more things
  19. Aug 26, 2015 at 5:32 PM
    #7659
    Arailt
    Dallas, TX
    2019 GX460
    I have 884s on my DCSB 4x4 and three alignment shops could not get my front end to the "ideal" specs for a lifted truck. They were only able to get 1.5 caster and I have a noticeable amount of positive camber. It drives and steers well, but my tires are prematurely wearing on the outside edge thanks to the positive camber.
    OME also claims all of their coil options provide 2" of lift, which is incorrect. If you want 2.5" on a stock DC, go 885. If you want 2", go 884.
  20. Aug 26, 2015 at 5:40 PM
    #7660
    Jeffvt0508
    Jeff
    Anderson, SC
    Well just think if you had 885... .. didn't say it was perfect.. but less chance for uppers.. rather gamble than pay for uppers I don't need..
