Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Aug 26, 2015 at 6:01 PM
    #7661
    Dr. Jekyll
    Dr. Jekyll Well-Known Member
    Jimmy
    Honolulu, HI
    2015 Black DCSB Limited PreRunner
    Damn James didn't realize you had these issues...
  2. Aug 26, 2015 at 6:45 PM
    #7662
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    OME states 50mm ( 2" ) of lift with the additional front weight specified for each coil
  3. Aug 26, 2015 at 6:46 PM
    #7663
    OZ-T
    Peter North
    British Columbia
    You are just delaying the inevitable
    T4RFTMFW and vrod671 like this.
  4. Aug 26, 2015 at 7:26 PM
    #7664
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    So I just schedule to have my truck looked at next week when my local custom shop re-opens (new facility). They said I should have them recheck tightness on everything after 500 miles. I've also been experiencing a squeaky sound on the front driver suspension for over a week now. Front passenger side doesn't do it. Not sure what I should be looking at or if it's a big deal that I should try to identify prior to my visit next week.
    Bushings? Shock absorber? Anyone have ideas? :)
    I have OME 887's, Nitrocharger Sport Shocks, and LR UCA's up front.
  5. Aug 26, 2015 at 7:27 PM
    #7665
    Arailt
    Arailt Well-Known Member
    Dallas, TX
    2019 GX460
    http://store.arbusa.com/2-Inch-05-On-Tacoma-Stock-Sport-Kit-OMETAC05LKSB-P21031.aspx
    "This complete Old Man Emu suspension kit is engineered to improve ride and handling while providing approximately 2 inches of suspension lift to a stock Toyota Tacoma."
    That's with 885 coils. I suppose 2.5" could be interpreted as approximately 2"
  6. Aug 26, 2015 at 7:30 PM
    #7666
    OZ-T
    Peter North
    British Columbia
  7. Aug 26, 2015 at 7:40 PM
    #7667
    Arailt
    Dallas, TX
    2019 GX460
  8. Aug 26, 2015 at 7:43 PM
    #7668
    OZ-T
    Peter North
    British Columbia
    50 mm on 885's with up to 50kg
    50 mm on 886's with 51 - 100kg
    The height has to be established with the maximum weight otherwise it makes no sense
  9. Aug 27, 2015 at 8:31 AM
    #7669
    Dirtboyz
    Dirtboyz Well-Known Member
    Spanaway, WA
    DCSB trd sport 4x4
    Front bilstein 5100 with OME 884 w/trim pack, 17" fuel trophy wheels wrapped with 32" toyot open country m/t, bakflip fibermax tonneau cover, Avec 30" led light bar behind lower grille, marathon seat covers in max 5 camo pattern, trimmed front and rear mud flaps, more to come.
    was that 1.75 with 5100 and OEM springs? I ask because I had that set up and it drove like shit. truck was all over the road. that's why I went with the coil lift instead and it solved my problems big time. before it was kind of scary to drive on the interstate. I can handle older trucks that have play in the steering wheel but when your truck likes to follow the road on its own is a different story ha. my guess with the pour outcome with the 5100 set at 1.75 is there is not much give to give if that makes sense. also when you get your alignment try to get them to make your camber as close to zero and pull as much caster as possible. that helped a lot to.
    Jeffvt0508 likes this.
  10. Aug 27, 2015 at 8:50 AM
    #7670
    Arailt
    Dallas, TX
    2019 GX460
    It was not. I had two different techs try at the tire shop where I bought my Duratracs and one tech at a different tire shop try an as well. They all told me I would have to live with the positive camber if I wanted the increased caster. I plan to get new UCAs soon, but maybe I'll take it to an off road shop before I do. Thanks for the info.
  11. Aug 27, 2015 at 8:55 AM
    #7671
    Dirtboyz
    Spanaway, WA
    DCSB trd sport 4x4
    Yea I would def do that first because some alignment shops will not do what you want them to (or can't figure it out) but most off road shops will. if anything the caster is ok and probably the most you are going to get out of OEM UCA but tell them you want 0 camber and as min toe as you want which I doe know you want some toe but not camel!! that is for the tire wear. good luck and I hope it works out. but I will say I will be getting UCA sometime down the road but not right now because it drives fine to me with almost perfect tire wear also!
    Arailt[QUOTED] likes this.
  12. Aug 27, 2015 at 9:26 AM
    #7672
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Yep!
    Drives better with 884s but not a ton of difference between the two in general because (I assume) I could have benefitted from new UCAs even at 1.75".
    OME rides far better but there are some driving characteristics that remain from the previous setup that an "as good as it can be" alignment didn't fix.
    I'm limited by the UCAs.
  13. Aug 27, 2015 at 10:16 AM
    #7673
    Dirtboyz
    Spanaway, WA
    DCSB trd sport 4x4
    I totally agree. It just depends on how much you want to put up with it I guess haha. but im fine for now anyways. Like I said one day I will get LR UCA but it's not at the top of my list as of right now. But the mod bug changes from day to day so who knows!
  14. Aug 27, 2015 at 1:55 PM
    #7674
    Larry
    Larry CARL
    CARL
    anyone use the 883's? and if so what did you do about the rear?
  15. Aug 27, 2015 at 1:57 PM
    #7675
    Drinknmolson
    Drinknmolson Well-Known Member
    Wheat Ridge, CO
    10 DCSB sport
    Aren't those for 3rd gen 4runners??
  16. Aug 27, 2015 at 3:36 PM
    #7676
    OZ-T
    Peter North
    British Columbia
    883's will fit on 2nd Gen Tacomas , just like 887's do
  17. Aug 27, 2015 at 4:16 PM
    #7677
    T4RFTMFW
    I almost went 883s, was on the fence actually. Glad I didn't.
  18. Aug 27, 2015 at 4:25 PM
    #7678
    vrod671
    vrod671 The Okayest Member
    Brandon
    2022 TRD Sport
    Stock
    when installing my OME kit, do i have to relocate or remove the swaybar or should i just leave it the way it is?
  19. Aug 27, 2015 at 4:26 PM
    #7679
    T4RFTMFW
    No reason to remove it. Unless you want to debate sway bar necessity like the others who have done so, in hell.
    I didn't need to relocate mine.
    vrod671 likes this.
  20. Aug 27, 2015 at 5:09 PM
    #7680
    Drinknmolson
    Wheat Ridge, CO
    10 DCSB sport
    Am i wrong or is Toyota using the same coil/strut suspension other than spring height and maybe weight ratings in all versions of tacoma, 4runner and sequoia since what '95?? Edit: and tundra
