Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Sep 2, 2015 at 9:41 PM
    #7781
    Powpow604
    Powpow604 Member
    Alex
    2015 white Tacoma trd
  2. Sep 3, 2015 at 1:15 AM
    #7782
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    Validated by the sasquatch from the north!
    SixthSnail likes this.
  3. Sep 3, 2015 at 11:50 AM
    #7783
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    I'm running Dakars with 3 deg shims on the back of my truck with Nitro originals. Both Dakar packs were rated as (+) but the pass side is an inch or so higher. I do have the packer on the front driver side to help eliminate driver side lean but the back is way off.
    Is there a good option for levelling the rear? Thought about removing upper overload on the pass side but I don't want mismatched leaf packs. Not too keen on a driver side spacer either but is that the best approach? If so, I'm probably gonna say screw it and put up with it.
  4. Sep 3, 2015 at 1:06 PM
    #7784
    Drinknmolson
    Drinknmolson Well-Known Member
    Wheat Ridge, CO
    10 DCSB sport
    Oz or someone, help! Still got the vibes!
    So i watched the video and downloaded an inclinometer, figured out my angles bought and installed shims, did i put them in wrong? Am i just sol and i need to take out an overload? Maybe i already smoked a ujoint? I thot my 3rd gen cv's were frustrating this is just annoying as heck.
  5. Sep 3, 2015 at 1:55 PM
    #7785
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    Are your angles actually back near 0?
  6. Sep 3, 2015 at 2:45 PM
    #7786
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
  7. Sep 3, 2015 at 2:50 PM
    #7787
    Drinknmolson
    Wheat Ridge, CO
    10 DCSB sport
    No
  8. Sep 3, 2015 at 3:05 PM
    #7788
    neverstuck
    Guido
    Lebanon
    13 DCLB sport
    Thanks. I'll grab a couple of those if it continues to bother me. Not too eager to pull all of it apart again. Maybe I'll just the 300 lbs in the back rear corner of my bed.
  9. Sep 3, 2015 at 3:11 PM
    #7789
    trailbound
    trailbound Well-Known Member
    Rob
    Surprise, AZ
    2016 DCSB TRD OR 4x4
    Has the jury changed on needing extended brake lines with the dakars? I have been digging around the forum and see some folks saying that they are required and others that are saying the opposite.
  10. Sep 3, 2015 at 3:30 PM
    #7790
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    See Build Page
    Didn't need them on my 2015 DCLB.
    trailbound[QUOTED] likes this.
  11. Sep 3, 2015 at 3:32 PM
    #7791
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    See Build Page
    What I got from that video was the point was trying to get the drivelling angles as close to 0 degrees as possible. This puts the components in a straight line which reduces vibration and wear.
    Have not checked mine yet but I'm not noticing an annoying vibration either.
  12. Sep 3, 2015 at 3:54 PM
    #7792
    PoweredBySoy
    PoweredBySoy Well-Known Member
    Jesse
    Minnesota
    2013 DCSB SR5
    I realize the answers are probably somewhere within these 400 pages.. but.... well......
    Does anybody want to share hub-fender measurements using 884's on a DCSB 4x4? No armor up front. Gracias.
    My 883's gave me 1 1/4". Looking for a strong 2".
  13. Sep 3, 2015 at 5:00 PM
    #7793
    Drinknmolson
    Wheat Ridge, CO
    10 DCSB sport
    I will measure when i get home i think its sitting at 22" hub to fender
  14. Sep 3, 2015 at 6:16 PM
    #7794
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Anderson, SC
    2015 DCSB 4x4 trd offroad
    Ome 887s, dakars, lr uca,sliders, konig countersteer,
    Are the yellow old man emu bushings junk? Thought I read where the stock bushings worked better?
  15. Sep 3, 2015 at 6:35 PM
    #7795
    3milecreek
    3milecreek MtnGoat
    Stephen
    Barnwell SC
    Heavily Modified 94 Yota
    Never the same
    Anybody running 886s with a small top plate spacer with steel bumper and winch with dakars? I got 885s with top plate and got like 2.5" with bumper and winch. Wondering if I switch to 886s would I need a top plate spacer to get 3" of lift? Want my truck with just a tiny rake almost level.
  16. Sep 3, 2015 at 6:38 PM
    #7796
    la0d0g
    running for the hills
    For crawling not hauling
    You would probably need a spacer. I have 886s (no spacers) with an aluminum bumper and winch (~135lbs) and have maybe 2.75" lift. Also have full skids and a big battery too.
  17. Sep 3, 2015 at 6:47 PM
    #7797
    3milecreek
    3milecreek MtnGoat
    Stephen
    Barnwell SC
    Never the same
    Okay. I have about 220lbs up front total. Without skids and I'm getting low. By the way I love your rig man!
    la0d0g likes this.
  18. Sep 3, 2015 at 6:47 PM
    #7798
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    See Build Page
    So I visited my local customs shop today for my OME install checkup. They determined my squeaking on the front end was coming from the LR UCA bushings. They squirted them with what they called "RGS" (aka Really Good Stuff) and the squeaking is gone. Seems this would likely be a temporary fix at most though. They assured me the stuff was safe for the poly bushings though.
  19. Sep 3, 2015 at 7:02 PM
    #7799
    OZ-T
    Peter North
    British Columbia
    Did they use the supplied grease when they installed the LR UCAs ?
  20. Sep 3, 2015 at 7:04 PM
    #7800
    Breckentruck
    Breckentruck Member
    2013 Silver Tacoma TRD
    OME 886, Dakar, Total Chaos UCA, 255-80-17 Cooper ST Maxx, ProComp Wheels Installing Soon: ARB Deluxe Front Bumper, Warn VR10000 Winch
    So I've ordered the lift kit, UCAs (total chaos) and bumper (ARB) ....I am trying to decide what to do for tires...My question is that if I get a 16 x 8 wheel, could I run both a 285 + 265...I was thinking of maybe going with 265s for snow tires since I live in Breckenridge....I was told they will grip better in snow than a 285. Is this correct?
    Any recommendations on a tire that does well in snow is appreciated too!
