Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Sep 16, 2015 at 2:54 PM
    #7861
    T4RFTMFW
    T4RFTMFW Well-Known Member
    That's the one time you can call me Francis..
    crashngiggles and F16TACO like this.
  2. Sep 16, 2015 at 2:56 PM
    #7862
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    Depends on who you buy from. Headstrong OffRoad included the carrier bearing drop in my kit.
    But I'm a 2nd Gen!
  3. Sep 16, 2015 at 6:05 PM
    #7863
    JWROSE4
    JWROSE4 Well-Known Member
    Jonny
    Virginia
    2013 DCSB SR5 4X4
    Work In Progress
    Anyone know if the OME Dakars will work with the fox ultimate lift from toytec?
  4. Sep 17, 2015 at 3:38 PM
    #7864
    4x4Taco09
    4x4Taco09 Well-Known Member
    Dane
    Louisiana
    09 TRD Sport 4x4 BSP DC LB
    Kings, Deavers, Brute Force, Prinsu, Lights, all the stuff
    I have a full OME kit.
    887s and trim packer up front and Dakar heavy duty leaf packs.
    I do have plate bumpers front and rear. The lift has been installed for over a year now.
    The rear hub to fender measures 24"
    But the front only measures 22"? I knew that it would settle some, but I don't even think that the 1/4" spacer up front would get my to 1" more. Any idea why its still 2" shorter?
    Im thinking of just saving some money and going Icons. I know that they're expensive, but idk what else to do, should ride better and get some more travel
  5. Sep 17, 2015 at 4:27 PM
    #7865
    JWROSE4
    Jonny
    Virginia
    2013 DCSB SR5 4X4
    Work In Progress
    The 887s aren't designed for the bumpers you need the 886s and you should get your height back with the spacers
  6. Sep 17, 2015 at 4:51 PM
    #7866
    4x4Taco09
    Dane
    Louisiana
    I thought the 887s were for more weight? i.e. plater bumper and winch?
  7. Sep 17, 2015 at 5:04 PM
    #7867
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    That's the 886's.
    Kyitty likes this.
  8. Sep 17, 2015 at 5:07 PM
    #7868
    4x4Taco09
    Dane
    Louisiana
    Well now I'm going to grab some 886 and top spacers
  9. Sep 17, 2015 at 6:03 PM
    #7869
    JWROSE4
    Jonny
    Virginia
    2013 DCSB SR5 4X4
    Work In Progress
    The 887s are taller giving those that want 3 inches of lift just that without the off road bumpers and whatnot, the 886s are stiffer to handle the weight.
  10. Sep 17, 2015 at 6:06 PM
    #7870
    JWROSE4
    Jonny
    Virginia
    2013 DCSB SR5 4X4
    Work In Progress
    Also I would put the 886s in without the spacers first to see if that gets you where you wanna be before adding the spacers. If you put the spacers in first it may be too much. If I'm wrong others feel free to pitch in please... @OZ-T
  11. Sep 17, 2015 at 6:36 PM
    #7871
    frizbal
    frizbal Well-Known Member
    Sean
    Tulsa, Oklahoma
    2012 TRD Off-Road
    I have 887 and a front bumper and got proper height gain, but I also tore off the sway bar and skids. Put me within the recommended range with adding the bumper, but removing the factory skids, oem bumper, and sway bar.
  12. Sep 17, 2015 at 6:40 PM
    #7872
    JWROSE4
    Jonny
    Virginia
    2013 DCSB SR5 4X4
    Work In Progress
    Your bumper aluminum or steel?
  13. Sep 17, 2015 at 8:30 PM
    #7873
    4x4Taco09
    Dane
    Louisiana
    My bumper is around 180lbs give or take. Plus I'll be adding a winch soon.
    I'll go 886 springs first. I'll get the 1/4" spacers if it doesn't get me close to where I want
    I couldn't believe it when I measured the hub/fender distance.
  14. Sep 17, 2015 at 8:55 PM
    #7874
    AZoverlandTaco
    AZoverlandTaco How do I change my profile name?
    Eric
    Flagstaff
    Toyota 4 Life
    Used half inch of spacers in the center support bearing. That got rid of the major clunk. But still have a bit of axle wrap. It's definitely better than before.
  15. Sep 17, 2015 at 9:09 PM
    #7875
    TXTaco13
    TXTaco13 Taco/T4R Enthusiast
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    Are the BP-51's out yet for the Tacos?
  16. Sep 17, 2015 at 9:43 PM
    #7876
    frizbal
    Sean
    Tulsa, Oklahoma
    2012 TRD Off-Road
    Steel hybrid.
  17. Sep 17, 2015 at 9:59 PM
    #7877
    JWROSE4
    Jonny
    Virginia
    2013 DCSB SR5 4X4
    Work In Progress
    So not as much weight as the full plate...that's why you were able to get by with it
  18. Sep 19, 2015 at 10:11 PM
    #7878
    Lars
    Lars Radio Active
    Lars
    Cedar Creek, TX
    '10 Tundra TRD RockWarrior
    Yes.
    265/70/17 Hancook Dynapro ATMs with OME Nitrocharger Sports, 886 front springs. 2" AAL in the rear.
    doing what they were made to do.
    I like Photos that show the result of what we've done. :)
    T4RFTMFW likes this.
  19. Sep 19, 2015 at 10:31 PM
    #7879
    T4RFTMFW
  20. Sep 19, 2015 at 10:48 PM
    #7880
    Dr. Jekyll
    Dr. Jekyll Well-Known Member
    Jimmy
    Honolulu, HI
    2015 Black DCSB Limited PreRunner
    Nope...
