Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Sep 24, 2015 at 11:42 PM
    #7901
    vrod671
    vrod671 The Okayest Member
    Brandon
    2022 TRD Sport
    Stock
    any help is appreciated :thumbsup:
  2. Sep 25, 2015 at 4:45 AM
    #7902
    JRod4928
    JRod4928 Well-Known Member
    Pittsburgh
    '12 Tacoma SR5
    Extang Trifecta Tonneau WeatherTech Floor Liners Pop & Lock Tailgate Lock Antenna X Black Mesh Grillcraft with Tacoma Badge (Upper) and Cross (Lower) 18" BMF Wheels / Cooper 31.5" Tires 2" Leveling Kit
    get an alignment.
    la0d0g likes this.
  3. Sep 25, 2015 at 5:20 AM
    #7903
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    It's toed out. Your tie rods need to be adjusted in. Your geometry on the front end has changed a lot with the lift and new UCA'S. I am sure your camber isboff a s well. The noise I heard was from the tires fighting each other on corners. Also either remove the sway bar or buy a sway bar spacer kit to relocate it so it does not make contact.
    Get the alignment soon though. Being toed out like that will chew through the tires quickly.
    vrod671, la0d0g and JRod4928 like this.
  4. Sep 25, 2015 at 7:23 AM
    #7904
    la0d0g
    running for the hills
    For crawling not hauling
    This
    and this.
    Installing a lift isn't complete until you get an alignment.
    Kyitty and JRod4928[QUOTED] like this.
  5. Sep 25, 2015 at 7:24 AM
    #7905
    JRod4928
    Pittsburgh
    '12 Tacoma SR5
    This.
    This.
    and this
    la0d0g[QUOTED] and Kyitty like this.
  6. Sep 25, 2015 at 8:19 AM
    #7906
    Mtnflyer
    Mtnflyer I'm big in Japan
    Las Vegas
    Read a lot about differences in ride height between 885s and 887s and stiffness of 886s and which are best for added weight... I'm looking for 2.5-3" up front for clearance.
    My question is, if I'm adding a US Offroad bumper and winch (~130 lbs) and probably some plates underneath, do I need 886s? Or can I get away with 887s, which with a little weight up front would likely droop the front down to where 885s would be (~2.5" of lift) and have a softer ride?
    The US Offroad bumper won't weigh as much as a full bumper replacement so I don't know if the difference in added weight from the skids will make the difference or not for 886 or 887. I don't intend to keep the skids on full-time, only when I'm going off-roading, to try and keep my highway weight down a little. I'm leaning toward 887s.
    Any advice?
  7. Sep 25, 2015 at 9:29 AM
    #7907
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    I'm guessing 886's.
    My front skid alone is 65lbs (3/16" steel). No bumper or winch yet. I've got 887's right now. Haven't taken after measurements yet but I think it does down a bit. Rides smooth though.
    887's could meet you the height you want. But with the extra weight probably not.
  8. Sep 25, 2015 at 9:37 AM
    #7908
    la0d0g
    I have about the same amount of weight hanging off the front and full skids w/ 886s. ~2.5" of lift and the ride is great on and off the pavement.
    Depending on how much you wheel, I bet taking the skids on and off every time will get old pretty quick.
    Kyitty and Mtnflyer[QUOTED] like this.
  9. Sep 25, 2015 at 9:37 AM
    #7909
    SixthSnail
    SixthSnail I have no idea what I'm doing
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    I just got my full set up on the weight I will have on the truck and want to be sure I'm looking at the right suspension.
    Up front I have a 75 pound bumper and a 30 pound aluminum skid. I'm thinking 887s because I don't think that's enough weight to validate 886s.
    In back, I have a fiberglass cab high shell with a roof rack. I'll be adding a Prinsu rack soon. Together I think they weigh about 200 pounds. I also have a rear bumper with a swingout weighing 130 pounds along with a full size spare to add about another 100 or so pounds. For the rear, I was thinking of Dakars with the extra leads to give it the extra inch. I want the rear to have about 1" of rake so that it sits level when my RTT and gear is on the canopy.
    If anybody could double check my opinion on the parts I need, that would be awesome!
    Edit: the truck is a V6 4x4 Access Cab
    Kyitty likes this.
  10. Sep 25, 2015 at 9:43 AM
    #7910
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    Regardless of how much you wheel taking the skids on and off sucks. Again this depends on yours skids but mine just suck to take on and off without a hoist.
    As for the 886's I feel the same with the weight. Rides great. Even before I had the winch in it wasn't bad at all.
    Mtnflyer and la0d0g[QUOTED] like this.
  11. Sep 25, 2015 at 9:50 AM
    #7911
    Mtnflyer
    Las Vegas
    Only wheeling 1-2 times a month. Also make the trek from Vegas to Tahoe every couple months....how's the ride on 886s after 7 hrs? lol
  12. Sep 25, 2015 at 9:55 AM
    #7912
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    My trucks my daily driver. No problem driving that much with the 886's. Drives nice and smooth for me. I would drive 3-5 hours to school and no problems with the ride. Just gets smoother the more ya drive it :D
    If your wheeling that much I wouldn't bother removing the skids, I don't even want to remove mine to do maintence but no choice there.
  13. Sep 25, 2015 at 9:56 AM
    #7913
    la0d0g
    Just fine. Did Reno to Oregon twice last week. Its a f'n highway. After 8-10 hours in the saddle offroading well, sometimes that a different story.
  14. Sep 25, 2015 at 9:59 AM
    #7914
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    8-10 hours Offroad in general will take its toll. Lol
    la0d0g[QUOTED] likes this.
  15. Sep 25, 2015 at 10:00 AM
    #7915
    la0d0g
    Haha, no doubt. When I typed that I thought the same thing. You could be in any truck with any lift and still need a few beers to stand right.
    Mtnflyer likes this.
  16. Sep 25, 2015 at 10:03 AM
    #7916
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Absolutely, however I was wheeling stock and that 8-10 hour wheeling trip sucked compared to wheeling with the ome suspension. More insight for those who have wheeled stock.
  17. Sep 25, 2015 at 10:05 AM
    #7917
    Mtnflyer
    Las Vegas
    Ha, yeah! I'm just afraid of dropping weight to save gas if it will make for a harsher ride, but yeah it's still a highway...:burnrubber:
  18. Sep 25, 2015 at 10:07 AM
    #7918
    Mtnflyer
    Las Vegas
    Still on stock....I'm looking forward to the upgrade
  19. Sep 25, 2015 at 10:16 AM
    #7919
    la0d0g
    I've had both 884s and 886s and both rode really nice. I'm sure 887s will ride nice too I just think with you having that much weight on the truck that over time 887s will not hold up as well. FWIW :cheers:
  20. Sep 25, 2015 at 10:18 AM
    #7920
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Well depending on how you think of it, the skids just act as another passenger (weight wise). So if it's just you driving, your weight savings is just a passenger. Is it worth it to remove them for the possibility of a small increase in mpgs that not carrying that passenger may give you? That's how I looked at. May be wrong but helps me sleep at night :cool::anonymous:
