Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Sep 25, 2015 at 10:34 AM
    #7921
    Mtnflyer
    Mtnflyer I'm big in Japan
    Las Vegas
    That's probably a good call
  2. Sep 25, 2015 at 10:49 AM
    #7922
    Dr. Jekyll
    Dr. Jekyll Well-Known Member
    Jimmy
    Honolulu, HI
    2015 Black DCSB Limited PreRunner
    that's exactly how I look at any weight being added to a truck, bumper, sliders etc. If my friends thought that way I'd never be invited anywhere #220pounds
  3. Sep 25, 2015 at 12:11 PM
    #7923
    mAtTyG04
    mAtTyG04 Well-Known Member
    Edmonton
    2019 Quick Sand OR
    6112 Front Suspension, Fox 2.0 Rear Shocks, Nitto Ridge Grappler - LT285/75R17 C, Rear Blackout Tacoma Badge, De-badged, Icon Rebound Wheels, TRD Grill Gights, CBI Ditch Light Brackets w/ Baja Design Lights, Husky Liners, JBA UCAs, Geenlane Off-road Sliders, Tacotrooper Decal, DuraBump Rear Bump Stops, Pro-clip USA Phone Mount
    I'm around the 137lbs mark with my bumper. Think I'm going 887. Far as I know 886 is designed for 200lbs +
  4. Sep 25, 2015 at 12:59 PM
    #7924
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    Don't forget about winch, skids, dual battery maybe, or anything over the front suspension that may get you to that 200 mark. Always good to think long term. Or just switch coils later on. Either way works lol
    la0d0g likes this.
  5. Sep 25, 2015 at 1:13 PM
    #7925
    la0d0g
    running for the hills
    For crawling not hauling
    Truth. My battery weighs in at 75#.
  6. Sep 25, 2015 at 5:14 PM
    #7926
    vrod671
    vrod671 The Okayest Member
    Brandon
    2022 TRD Sport
    Stock
    Thanks! Just dropped truck to get aligned and also picking up sway bar spacer.
  7. Sep 28, 2015 at 12:07 AM
    #7927
    vrod671
    Brandon
    2022 TRD Sport
    Stock
    Need a quick response..could anybody identify the sound @ 6 seconds into this clip. Happens when I tap the breaks. I have a toy toytec 2inch AAL. Do I need extended break lines and is it safe to drive? Breaks feel normal...
    this HTML class. Value is https://youtu.be/0XU
  8. Sep 28, 2015 at 12:13 AM
    #7928
    vrod671
    Brandon
    2022 TRD Sport
    Stock
    Sorry can't upload video on my phone
  9. Sep 28, 2015 at 9:48 AM
    #7929
    TacoCasita
    TacoCasita Active Member
    Robert
    CenterPoint, Indiana
    15 Taco DC LB Sport 4X
    Front tow hook, bed tie downs, soon: OME lift, new tires, 17" Method Mesh wheels.
    Is there such a thing as 887X's or are just the newer 885's the only X's?
    Reason I'm asking is I have 885X's and just got a set of 887's and noticed they didn't have the X.
  10. Sep 28, 2015 at 9:52 AM
    #7930
    la0d0g
    All coils are now Xs so they dropped the X all together.
  11. Sep 28, 2015 at 10:13 AM
    #7931
    TacoCasita
    Robert
    Good deal. I was re-questioning swapping out my 885's for 887's. Thanks.
  12. Sep 28, 2015 at 1:25 PM
    #7932
    vrod671
    Brandon
    2022 TRD Sport
    Stock
  13. Sep 28, 2015 at 1:31 PM
    #7933
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Not anything in the bed pockets and the spare is tight in the carrier ? Exhaust hangers are all intact ?
  14. Sep 28, 2015 at 1:33 PM
    #7934
    vrod671
    Brandon
    2022 TRD Sport
    Stock
    bed/cubbies are empty. started making noise after lift..
  15. Sep 28, 2015 at 1:34 PM
    #7935
    vrod671
    Brandon
    2022 TRD Sport
    Stock
    didn't check spare tire..exhaust hangers are good. only happens when i press the breaks.
  16. Sep 28, 2015 at 4:24 PM
    #7936
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    Driver side to left of transmission. Mounted to the frame are two brake lines for the rear end. Make sure the bracket is snug.
    Horrible picture but wearing slacks I can't crawl under mine. Ignore my white skid plate!
    vrod671[QUOTED] likes this.
  17. Sep 28, 2015 at 4:28 PM
    #7937
    vrod671
    Brandon
    2022 TRD Sport
    Stock
    thanks! i'll check after work.
  18. Sep 30, 2015 at 6:59 PM
    #7938
    vrod671
    Brandon
    2022 TRD Sport
    Stock
    Is the OME kit usually this squeaky?
  19. Sep 30, 2015 at 7:13 PM
    #7939
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    See Build Page
    Mine was until I had them redo it. Properly greased it is quiet AND rides smoother now too.
    Edit: Actually it was my UCAs that were making noise.
  20. Sep 30, 2015 at 8:26 PM
    #7940
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Anderson, SC
    2015 DCSB 4x4 trd offroad
    Ome 887s, dakars, lr uca,sliders, konig countersteer,
    How many of you guys have the diff drop? Is it worth it?
