Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Mar 1, 2013 at 10:00 AM
    #781
    la0d0g
    running for the hills
    For crawling not hauling
    Yes, trim packer for the lean and Dakars in the back with 5100s and extenders.
  2. Mar 1, 2013 at 10:02 AM
    #782
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    schweet...thx.
  3. Mar 1, 2013 at 11:09 AM
    #783
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    I'm using the extended travel 5100's. nice upgrade from the nitrocharger for sure.
  4. Mar 1, 2013 at 2:07 PM
    #784
    The_Hodge
    SC
    just got my current ones...
    DF - 22 1/2
    PF - 22 3/4
    DR - 24
    PR - 23 3/4
    saggy standard 3" AP pack on the rear w/ a .5" block on the DR. now that i have my tire carrier, it's no longer needed but i never removed it.
  5. Mar 1, 2013 at 2:13 PM
    #785
    la0d0g
    Dakars!
  6. Mar 1, 2013 at 2:18 PM
    #786
    The_Hodge
    SC
    i've heard good things about the 3 leaf icon progressive, so putting that on my stock set of leafs. they were low miles when i took them off and had a 1.5 or 2" pro comp AAL on them.
  7. Mar 1, 2013 at 2:22 PM
    #787
    la0d0g
    Makes sense and save some $$
  8. Mar 1, 2013 at 2:27 PM
    #788
    The_Hodge
    SC
    yeah...less than $900 vs ~1200
  9. Mar 1, 2013 at 2:59 PM
    #789
    la0d0g
    :thumbsup:
  10. Mar 1, 2013 at 3:39 PM
    #790
    JTrean
    JTrean Well-Known Member
    I have a question for first gen owners. I know a few people have used the 883 coils instead of 881's (with nitro sport struts of course). I am considering going this route as well for my 03 v6 ex cab. I am looking for 2.5in up front and I read that this is achievable with the 883 coils without the addition of the 10mm spacers? Will these still ride softer than the eibachs, which have a larger spring rate of 620? Would 882's be a better idea?
    Thanks in advance
  11. Mar 1, 2013 at 3:49 PM
    #791
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    883s =~590 lb/in 882s=~500 lb/in
  12. Mar 1, 2013 at 3:59 PM
    #792
    JTrean
    I am familiar with the specs. According to wheelers, the 882's have a lower spring rate but higher height than the 883's. My question is, which coil will give me a 2.5in lift and the more comfortable ride? I would rather not use 881's with the 10mm spacers
  13. Mar 1, 2013 at 4:11 PM
    #793
    evanmb31
    evan
    connecticut
    09 trd off road
    Not sure, i don't know much about first gens i just thought the specs might help. There isnt many first gen guys in this thread
  14. Mar 1, 2013 at 4:18 PM
    #794
    JTrean
    ya i know :(
  15. Mar 1, 2013 at 4:25 PM
    #795
    Whitehall
    Whitehall Easy Does It
    Colorado
    2012 Pyrite ACLB OR
    Hi All. I'm putting on some new parts and would like some advice. I have 885Xs (no trim packer, no spacers) and Dakars on an ACLB. I have sliders and a topper. Here are my current hub center to fender measurements.
    FL: 21.750
    FR: 22.500
    RL: 23.125
    RR: 23.875
    In coming weeks I will be adding a steel plate front bumper, winch, and IFS skid. In conjunction, I'm changing to 886s with driver's side trim packer and LR UCAs.
    So my current numbers are on the low side. I'm considering using top plate spacer w/ the 886s and the Dakar AAL in order to get 2.5-3 inch lift over stock. I'd like to try to get it right the first time so I only have to get one alignment and only have to pull my shock apart once.
    What do yall think?
  16. Mar 1, 2013 at 4:32 PM
    #796
    la0d0g
    For this ^^ see this VV except I'm DCSB and aluminum front and mid and no cap and... oh hell I guess its not the same at all :eek:
  17. Mar 1, 2013 at 6:17 PM
    #797
    Hollywood22
    Hollywood22 Wranglin the Badger
    Johnny
    Southern Ontario
    Generation X
    OME Lift, LR UCA's
    How much lift will I get in the front using the OME 90000 sport shocks and the 885 coils? I have a stock 09 DC SB.
    On the Toytec website it says that you will get a full three inches with the top spacers. But what will you get without the spacers?
    Thanks
  18. Mar 1, 2013 at 6:44 PM
    #798
    evanmb31
    evan
    connecticut
    09 trd off road
    Bout 2.5
  19. Mar 1, 2013 at 6:47 PM
    #799
    Hollywood22
    Johnny
    Southern Ontario
    Generation X
    OME Lift, LR UCA's
    Thanks man.
  20. Mar 1, 2013 at 6:48 PM
    #800
    evanmb31
    evan
    connecticut
    09 trd off road
