Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Oct 19, 2015 at 4:08 PM
    #8101
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Anderson, SC
    2015 DCSB 4x4 trd offroad
    Ome 887s, dakars, lr uca,sliders, konig countersteer,
    I recently installed the ucas on my truck.. Just remember patience..can be a pain installing
  2. Oct 19, 2015 at 4:15 PM
    #8102
    backwoodsbob
    backwoodsbob Member
    Bobby
    Suffolk,VA
    2011 tacoma 4x4 trd
    Gotcha. After owing a ford for a year I am used to everything being more difficult to install than it should be. haha
  3. Oct 19, 2015 at 5:09 PM
    #8103
    Jamart5
    Jamart5 HoeRunner
    Juan
    SETX
    '16 4Runner TRD
    Ok had to grind down the lower shock mount to fit the rear shocks now they fit.
    Kyitty and vrod671 like this.
  4. Oct 19, 2015 at 5:14 PM
    #8104
    vrod671
    vrod671 The Okayest Member
    Brandon
    2022 TRD Sport 4x4
    Stock
    i thought that was an issue with the 2015's..glad you got it to work!
  5. Oct 19, 2015 at 6:50 PM
    #8105
    Jamart5
    Jamart5 HoeRunner
    Juan
    SETX
    '16 4Runner TRD
    I thought so to but nothing the old grinder couldn't do
  6. Oct 20, 2015 at 6:08 PM
    #8106
    hurtcoastie
    hurtcoastie Well-Known Member
    Jordan
    2013 Regular Cab 4x4, MT
    Hey guys, a bit off topic..I'm experiencing an awful thud when I go over speed bumps. From my research, that seems to come with the territory when you get an OME lift. From what I've read, its because the front struts are not any longer than stock and so they overextend. Does anyone have a recommendation for this? Other than the obvious one to slow down over speed bumps? Because I can sometimes hear/feel it when I'm going down the road and hit a pothole. With stock, I had no issues. I have the 1/4" top plate spacer and my truck sits level (I haven't measured it, but it looks level). If I remove the top spacers, would this help or no? I haven't noticed anywhere that the UCA would be hitting. If only I could get a camera under there to be sure..Thanks for your input!
  7. Oct 20, 2015 at 6:21 PM
    #8107
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Over Speed Bump Goes Clank
  8. Oct 20, 2015 at 6:28 PM
    #8108
    hurtcoastie
    Jordan
    I have the 885s as you suggested in your March post, but the clank is still there. I have Boss shocks in the rear since I have a '15 and didn't want to risk the OME not fitting properly. If, in the future, I change out the front OME struts with Boss struts, would that fix the issue? I ordered from Toytec if that helps. Not sure if Boss is better quality or not. I know the complete lift kit was several hundred $$ more though.
  9. Oct 20, 2015 at 6:28 PM
    #8109
    mouse007
    mouse007 Well-Known Member
    Mauricio
    Weston,Florida.
    2014 TRD Off-Road 4x4
    ICON Vehicle Dynamics Uni-Ball UCA, ICON Vehicle Dynamics Extended travel remote reservoir coilovers, with 700# Coils and CDC (Compression Damping Control) Clicker Valves. Dakar Leafs Old Man Emu Nitro Sport Shocks Toyotech U-Bolt flip kit, Goodyear F. & R. extended Stainless Steel Brake lines. aFe Pro Dry drop in air filter. ARB Bull Bar. Weld on AVID Off-Road Rock Sliders W/ Kick Out. Tires: 285/75 R16 BFGoodrich KO/TA's. Light Force Blitz 240's 12v. Warn M-8000 W/ Viking Off-Road Synthetic winch line.
    Hello,
    Is anyone running the 886 Coils with Icon UCA's..? I resantly swapped my UCA from Cambrug O.E. Ball joints to the Icon units. I'm having a random clunk, almost as if the Ball Joint in the UCA is maxing out. Any advise..? I'm guessing as the 886 give you almost 3" am Icon C.O. Should only be set at 2.5" the ball joint is maxing out..? Is this possible..?
    Thanks..!
  10. Oct 20, 2015 at 6:30 PM
    #8110
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    Isn't it just the sway bar contacting the coil? Sway bar spacers should help. Cheap option too.
  11. Oct 20, 2015 at 6:32 PM
    #8111
    OZ-T
    Peter North
    British Columbia
    My clank went away , but the general consenus is the OME shocks top out over sharp drops like speed bumps
  12. Oct 20, 2015 at 6:33 PM
    #8112
    OZ-T
    Peter North
    British Columbia
    That is a possibility too
  13. Oct 20, 2015 at 6:33 PM
    #8113
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Can't imagine it maxing it out consider (I think this is right) that icon coilovers have more travel than OME. So it shouldn't be flexed right out.
    If you have the sway bar on it could be the coil contacting the coil.
    mouse007[QUOTED] likes this.
  14. Oct 20, 2015 at 6:34 PM
    #8114
    vrod671
    Brandon
    2022 TRD Sport 4x4
    Stock
    my sway bar was hitting the coil bucket..i had to get the relocate spacer...
  15. Oct 20, 2015 at 7:04 PM
    #8115
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    I put the sway are relocation bracket on durring the install. I was warned by another member that I might need it, so I just did it with the lift.
  16. Oct 20, 2015 at 7:09 PM
    #8116
    mouse007
    Mauricio
    Weston,Florida.
    @tacoma16 I was thinking the same.. I mean, the Icon should have more travel right..?
    The sway bar has been remove (best mod hands down).
    If I bounce on the front bumper (ARB) you hear the ball joint top out. The sound/noise I here is only on the pass side, it only happens when I'm making a slight turn right or left. It's a sold thump not a clank (metal on metal)
    I posted here to see if any of the 886 guys could chime in. Thanks for the input, much apriciated.
  17. Oct 20, 2015 at 7:11 PM
    #8117
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    I just want to say this real quick
    Earlier in this thread, I state that my Mobtown recovery bar receiver hitch came welded on crooked. Well, Joe at Mobtown saw this and contacted me before I could contact him. He stated that their jig was bent unbeknownst to him. He is sending me a replacement recovery bar right away. Awesome customer service. Thank you Joe!
  18. Oct 20, 2015 at 7:16 PM
    #8118
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    I've only been driving my truck with the 886's for a day. I did notice that when I went over the first speed bump at the same speed I used to, there was a clank. I just attributed this to the stiffer springs?
  19. Oct 20, 2015 at 7:18 PM
    #8119
    OZ-T
    Peter North
    British Columbia
    Its the shocks
  20. Oct 20, 2015 at 7:18 PM
    #8120
    OZ-T
    Peter North
    British Columbia
