Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Oct 31, 2015 at 3:27 PM
    #8201
    Lars
    Lars Radio Active
    Lars
    Cedar Creek, TX
    '10 Tundra TRD RockWarrior
    Yes.
    It's annoying to do a job twice. At the same time I suspect it's less work than repairing everything that might break if you actually hit the mount.
    Jamart5[QUOTED] likes this.
  2. Nov 1, 2015 at 7:24 AM
    #8202
    Washington
    Washington Well-Known Member
    Minot, ND
    15 Tacoma TRD off-road
    Stealth Custom Series- Stealth 6 wheels, 285/70-17 Goodyear Duratracs, Allpro stainless extended brake lines, Dakar rear leaf springs, Light racing upper control arms, OME 887 front coils, OME 90000 front struts, OME 60091 rear shocks, BPF front skid plate, CB radio, Shovel mount in bed rail, 30" LED light bar in front bumper, Rear Diff lock anytime relay mod, Diff breather mod
    Anyone running Icon or Fox remote reservoir shocks in the rear with Dakars? if so which ones did you get?
  3. Nov 1, 2015 at 8:31 AM
    #8203
    SLOBRA
    SLOBRA LET IT EAT®
    Albuquerque, NM
    2012 DCSB 4x4 TRD O/R
    What caster/camber should I ask the alignment shop to set with the full OME kit (Dakars and 886), LR UCAs and 255/85/75 Cooper ST MAXX?
  4. Nov 1, 2015 at 8:37 AM
    #8204
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    I have my caster at 3* camber and toe 0 or close
  5. Nov 1, 2015 at 8:39 AM
    #8205
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    3,0,0
    303tacoma likes this.
  6. Nov 1, 2015 at 6:01 PM
    #8206
    SlapChop7
    SlapChop7 Well-Known Member
    Eastern NC
    2019 MGM DCSB OR 4x4
    Anyone out there with 285s and LR UCAs and OME having any issues with rubbing when slightly flexing? Only noticeable rubbing I can see is slight rubbing on the cab mount when at full lock but this is not the rubbing I'm referring to. I think the tire is rubbing on the UCA when I hit a big bump. Now if I can remember correctly the camber/ball joint nut wasn't all the way extended out as far as it would go when I installed the lift but it was close. I don't see any rubbing marks anywhere but when I hit a large bump it sounds like some serious rubbing going on. Any ideas?
  7. Nov 1, 2015 at 6:03 PM
    #8207
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    Over "bump goes clank"? Do you have 886 OME springs up front? Any skids, winch, steel bumpers up front?
  8. Nov 1, 2015 at 6:06 PM
    #8208
    SlapChop7
    Eastern NC
    Nah not the clank. It's different. It sounds like the knobs on my tires are rubbing on something for a split second when i hit a big bump. Its pretty loud and sounds like somethings gonna get ripped off. I stick my hand on the back side of the tires when not flexed and there feels to be very little room but no noticable rubbing marks anywhere on the UCAs. I have 887s and nothing up front. I turn my wheels full lock left and right and it only touches the cab mount at full lock.
  9. Nov 1, 2015 at 6:11 PM
    #8209
    SlapChop7
    Eastern NC
    Should the camber on the UCAs be extended all the way out and only adjust for camber on the LCA? Will this clear the tires from the UCA?
  10. Nov 1, 2015 at 6:13 PM
    #8210
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    See Build Page
    Hmm. Maybe find a big rock and get one of the front tires on it to force full flex. Then check out where things are at?
    I need to do that too... Just to flex mine for once. Haha
  11. Nov 1, 2015 at 6:16 PM
    #8211
    SlapChop7
    Eastern NC
    Yea that's a start. I'll run one of the tires up on the curb next to my place and report back. :bored:
  12. Nov 1, 2015 at 6:24 PM
    #8212
    vrod671
    vrod671 The Okayest Member
    Brandon
    2022 TRD Sport
    Stock
    :yay:my suspension finally stopped squeaking:woot:
    Kyitty likes this.
  13. Nov 1, 2015 at 6:27 PM
    #8213
    SlapChop7
    Eastern NC
    So I did a slow speed flex over the curb and no noises. Plenty of room between the tires and UCAs. It seems to only rub at faster speeds. :confused:
  14. Nov 4, 2015 at 5:53 AM
    #8214
    SlapChop7
    Eastern NC
    I figured out the issue. The sway bar is rubbing the driver side coilover. Now I gotta make the decision to remove it or relocate it... :rolleyes:
  15. Nov 4, 2015 at 6:03 AM
    #8215
    Jamart5
    Jamart5 HoeRunner
    Juan
    SETX
    '16 4Runner TRD
    Remove I had doubts about it but it's really not a big difference
  16. Nov 4, 2015 at 7:11 AM
    #8216
    TacoBurrito07
    TacoBurrito07 Well-Known Member
    Jake
    Arizona
    07 SWB Dbl cab TRD Sport 4x4
    Remove it. I honestly don't even notice a difference in the way it drives.
  17. Nov 4, 2015 at 8:16 AM
    #8217
    OZ-T
    Peter North
    British Columbia
    Sway bar relocates are like $20
    vrod671 likes this.
  18. Nov 4, 2015 at 9:43 AM
    #8218
    yesmar
    yesmar Well-Known Member
    Ramsey
    Harrisburg, PA
    A couple cars
    washers are like free, or some metal with 2 holes drilled
  19. Nov 4, 2015 at 12:01 PM
    #8219
    vrod671
    Brandon
    2022 TRD Sport
    Stock
    X2
  20. Nov 5, 2015 at 11:31 AM
    #8220
    gunn_runner
    gunn_runner www.gunnphotoservices.com
    Rocky River, OH
    2013 DCLB TRD
    OME 886 & Dakars. 35" Mickey Thompson Baja Boss
    Top hat clock?
    Guys, I hope this isn't a stupid question (I should start all posts like that!): a shop assembled my coils on the front struts, off the truck; Im in the driveway doing a test fit and when I move the strut into position at the top, the bottom eye hole doesn't line up on the lower control arm mount. Can I rotate the bottom of the strut to line it up? Or does the whole coil/strut need to come apart and be reclocked?
    mouse007 likes this.
