Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Nov 9, 2015 at 12:09 PM
    #8241
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Slow down to less than 5 MPH over speed bumps.
  2. Nov 9, 2015 at 12:09 PM
    #8242
    T4RFTMFW
    No.
    Tacoma SS[QUOTED] likes this.
  3. Nov 9, 2015 at 12:10 PM
    #8243
    la0d0g
    running for the hills
    For crawling not hauling
    Cool. I like my dakars but carry a little bit of weight in the bed.
  4. Nov 9, 2015 at 12:10 PM
    #8244
    Tacoma SS
    Tacoma SS Well-Known Member
    Denver
    Supercharged 09 on 35s
    Boost and flex and 35s
    Yeah, I never carry any weight. So what you're saying is that if I were to buy this kid I would have everything that I need?
  5. Nov 9, 2015 at 12:12 PM
    #8245
    la0d0g
    As long as it has the trim packer you should be good to go. I also didn't do any shims or spacers with mine so not sure on that stuff.
  6. Nov 9, 2015 at 12:19 PM
    #8246
    Tacoma SS
    Denver
    Perfect, I guess it's time to start saving
  7. Nov 9, 2015 at 12:29 PM
    #8247
    Tacoma SS
    Denver
    What are the biggest tires I will be able to do with this set up?
  8. Nov 9, 2015 at 12:30 PM
    #8248
    T4RFTMFW
    285s with trimming and likely a CMC.
    255s otherwise are the tallest tire, but are narrow.
    265/75/16 or 265/70/17 for without trimming (and also fit stock height).
  9. Nov 9, 2015 at 12:36 PM
    #8249
    Tacoma SS
    Denver
    CMC? And I have 265/75/16's on right now with my 2 inch rough country block lift. I was hoping to be able to go at least a little bit bigger
  10. Nov 9, 2015 at 12:38 PM
    #8250
    T4RFTMFW
    Cab mount chop.
    285s are wider, which is the issue with rubbing.
  11. Nov 9, 2015 at 12:39 PM
    #8251
    Jon27
    Jon27 Well-Known Member
    Jon
    Salt Lake City, UT
    2015 Toyota Tacoma Off Road
    Shit on a black truck.
    What is the 4.5 backspace? A spacer or a measurement for the wheel? Sorry newb looking into this lift and wheel size. Thanks.
  12. Nov 9, 2015 at 12:39 PM
    #8252
    la0d0g
    & 315s if you want to cut :D
    T4RFTMFW likes this.
  13. Nov 9, 2015 at 12:41 PM
    #8253
    la0d0g
    Backspace is the depth from the mounting surface to the back of the wheel.
  14. Nov 9, 2015 at 12:43 PM
    #8254
    Tacoma SS
    Denver
    The biggest and widest that I can go with my 16 inch rims without having to cut and without rubbing? 265/75/16?
  15. Nov 9, 2015 at 12:44 PM
    #8255
    Jon27
    Jon
    Salt Lake City, UT
    Ok thanks.
  16. Nov 9, 2015 at 12:48 PM
    #8256
    Kylsix
    Kylsix Makin' it Hail
    Rick
    Albuquerque, NM
    '12 Mag Gray T|X Pro
    OME w/ 886s & Dakkar Leafs
    Just got my OME kit from Headstrong Offroad installed with 886s and no front bumper yet, this is such a true statement...
    I am running 255/85-16 Cooper S/T MAXX tires on mine, they're just shy of 33". No contact anywhere, no need for cab mount chop, though if I were to jump up to 265s that would probably require a chop, but the 255s look damned good and are very functional, and I don't think I'll ever change.
  17. Nov 9, 2015 at 12:48 PM
    #8257
    T4RFTMFW
    Yep.
    Kyitty likes this.
  18. Nov 9, 2015 at 1:01 PM
    #8258
    Tacoma SS
    Denver
    Would I have this same issue even though I have a giant plate bumper/winch?
  19. Nov 9, 2015 at 1:01 PM
    #8259
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    Headstrong OffRoad is awesome. I'm sure they'll customize the order for you. I worked with Marie when I got my OME kit from them. She was great.
    The Dakar is stiff with zero weight in the back. If you their a cab or other heavy objects back there you'll appreciate then though. I don't carry heavy stuff but I've piled numerous 40lb boxes in my truck and not seen it settle at all.
  20. Nov 9, 2015 at 1:04 PM
    #8260
    Tacoma SS
    Denver
    Yeah I pretty much never carry anything and that's why I think that the All-Pro leaf packs would be a good choice for me
