Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Mar 4, 2013 at 12:07 PM
    #841
    4Wheelin4Banger
    4Wheelin4Banger [OP] Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    I just finnished adding 1/4" top plate spacers & I'm almost where I was before adding the sliders & skids. I was 23 3/8" DS I'm now 23 1/8".
  2. Mar 4, 2013 at 4:22 PM
    #842
    rjsimz
    rjsimz Well-Known Member
    Rob
    Huntersville, NC
    13 4x4 DCLB
    Well I bought the springs with 15000-20000 miles on it...
  3. Mar 4, 2013 at 4:35 PM
    #843
    Hollywood22
    Hollywood22 Wranglin the Badger
    Johnny
    Southern Ontario
    Generation X
    OME Lift, LR UCA's
    Looking good......what size tire you runnin?
  4. Mar 4, 2013 at 5:59 PM
    #844
    8BoltRacing
    8BoltRacing Custom Fabrication and Performance
    Jared
    Greensburg PA
    The Angry Warthog
    DO 3 hoop, Wheelers HD Leaf Set w/ES poly bushings, OME 884X Coils, 5100's, Selfmade Satoshi, Single beam headlights, Fogs anytime, high beams with low beams mod, ABS kill switch, AMSOIL fluids in everything, K&N Intake, TB Spacer, FAL Electric Fan and TRD Rad Cap, DT Long Tubes, URD Y-pipe w/xtra O2 bungs and 3" v-band , Custom 3-inch Exhaust w/v-band and 3030XL Aero turbine muffler and Aero 3040 tip, URD Fuel Pump Upgrade, B&M Short Shifter, EBC Dimpled and Slotted Rotors with EBC Yellowstuff pads, Pulseplugs, HIDs: Fogs 3000k, Highs 4300k, Lows 8000k, URD Throwout Bearing Repair kit, Fidanza Aluminium Flywheel+Competition Clutch Stage 4
    my rear springs are shot and just suck in general.. taxes are coming soon and ive been waiting to do this for a while. I currently have 5100's and DO 3 hoop. I am between the Wheelers HD Springs or the Deavers. Would I be ok with the 885 coils up front?
  5. Mar 4, 2013 at 7:57 PM
    #845
    Ds2199
    Ds2199 Active Member
    Golden, CO
    2013 TRD Sport
    OME 885 Coils, OME 9000 Nitrocharger struts, OME N182 Rear Shocks, Dakar Leaf springs, N-Fab steps, Katskins Leather seats, Weathertech floor liners
    Thanks!
    265/70 17
  6. Mar 5, 2013 at 8:47 PM
    #846
    8BoltRacing
    Jared
    Greensburg PA
    The Angry Warthog
    Guess I should mention that I have a car to haul to the track and back and I do some frequent hauling of scrap and other such things from time to time. The most off-road running I do right now is the occasional dirt road and such. I would like to do some trail runs sometime though.
  7. Mar 8, 2013 at 9:45 AM
    #847
    mclovin
    mclovin chicka chicka, yeah!
    Biloxi
    16 TRD OR DC Barcelona Red
    Prev, 04 Xtra Cab Prerunner, 12 SR5 4x4 AC
    so i dont have measurements right now, but i have 886x with 90000 up front and dakars in the back with n182.
    i did notice that after putting on my HC bumper with tire swing the back came down a bunch!
    Question to the OME gods... will the D29XL add a leaf help with bringing up the back to where it used to be or am i just going to have to live with a sagging rear.... i am pretty nose high right now and im hoping that will change when i get my front bumper and winch installed...
    i'll grab measurements today if i can
  8. Mar 8, 2013 at 9:47 AM
    #848
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    according to ARB/OME specs the d29xl leaf should add approx 3/4" and increase the spring rate
    http://www.arbusa.com/uploads/PDF/accessorizeYourRig/toyotaTacoma.pdf
    (Notes in bottom of last page)
    alternately , you can flip the upper overload
  9. Mar 8, 2013 at 9:50 AM
    #849
    mclovin
    Biloxi
  10. Mar 8, 2013 at 9:53 AM
    #850
    OZ-T
    Peter North
    British Columbia
    You can usually get centre pins at a spring shop , I think I paid around $8
    U bolts are technically a one use item
  11. Mar 8, 2013 at 9:54 AM
    #851
    OZ-T
    Peter North
    British Columbia
    Did you catch my edit that you can also flip the upper overload ?
  12. Mar 8, 2013 at 9:55 AM
    #852
    mclovin
    Biloxi
    what does that do? sorry im pretty ignorant to the details of leaf springs?
  13. Mar 8, 2013 at 9:58 AM
    #853
    OZ-T
    Peter North
    British Columbia
    Flipping the upper overload has it engage and support the leafs earlier
  14. Mar 8, 2013 at 10:01 AM
    #854
    mclovin
    Biloxi
    hmmm i might try that as well as the add a leafs... i mean they are pretty cheap and if they dont yield the lift im trying to get back to..
  15. Mar 8, 2013 at 10:06 AM
    #855
    OZ-T
    Peter North
    British Columbia
    I would suggest adding the AAL first , then if that doesn't solve it , consider flipping the overload
  16. Mar 8, 2013 at 10:11 AM
    #856
    mclovin
    Biloxi
    sounds good, i just took some measurements. dont know if i did them right but here goes.
    FL 24.25
    FR 24.5
    RL 24.25
    RR 24
  17. Mar 8, 2013 at 12:10 PM
    #857
    OZ-T
    Peter North
    British Columbia
    That is about average for rear heights if you reference my Dakar measurement thread
    I think the AAL alone will fix you up if you want more height
  18. Mar 8, 2013 at 2:25 PM
    #858
    mclovin
    Biloxi
    well i guess what i know what im gonna be doing in a few weeks then. thanks for the help
  19. Mar 8, 2013 at 2:26 PM
    #859
    OZ-T
    Peter North
    British Columbia
    :thumbsup:
  20. Mar 8, 2013 at 3:04 PM
    #860
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Where are you guys having luck getting your alignments done? I'm putting in LR UCA's tonight.
