Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Nov 30, 2015 at 6:03 PM
    #8621
    saddlecreek
    saddlecreek Member
    Nick
    Mazama, WA
    2013 AC 6MT TRD Sport /91 Toyota Truck 4x4/08 Yaris 5MT lifted
    OZ-T…..I have a question. Installing my OME next week on my 05 extended cab TRD sport (with topper and no weight up front) next week and want to go with the 885 springs instead of the 884's that this company is telling me to go with. There saying that it might actually be higher in the front and there not into that because of how it would handle on trail. I would assume if it turned out that way it would only be about .25-.5 higher. I really want to try and achieve 3 inches up front without a spacer and will be going with 255/80/17's on stock wheels without spacers and full leaf packs in the back. Any photos or recommendations?
    Spent a couple hours going through this large thread and gave up…decided to post. My first. Its good to be here.
  2. Nov 30, 2015 at 6:06 PM
    #8622
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Which leaf pack
  3. Nov 30, 2015 at 6:13 PM
    #8623
    saddlecreek
    saddlecreek Member
    Nick
    Mazama, WA
    CS047R Rear Leaf Springs.
  4. Nov 30, 2015 at 7:02 PM
    #8624
    OZ-T
    Peter North
    British Columbia
    You won't be nose high with 885's even if you get 3" out of them
  5. Nov 30, 2015 at 7:03 PM
    #8625
    OZ-T
    Peter North
    British Columbia
    You may want to go back a page or 2 and read Crom's posts re using 5100's instead of OME shocks
  6. Nov 30, 2015 at 7:32 PM
    #8626
    saddlecreek
    saddlecreek Member
    Nick
    Mazama, WA
    In other words a decent setup then even with the topper on the back? Thanks for the feed back OZ, I'll check out Crom's posts. Ill post photos next week.
  7. Nov 30, 2015 at 7:35 PM
    #8627
    OZ-T
    Peter North
    British Columbia
    I have a DCLB , 885's and Dakars ( same leaf pack as you ) and a Leer 100RCC cap plus about 250 lbs of tools and I have 1 1/2" of rake , you are unlikely to have a nose high condition
  8. Nov 30, 2015 at 7:40 PM
    #8628
    saddlecreek
    saddlecreek Member
    Nick
    Mazama, WA
    I figured I would be fine. Been trying to find photos of extended cabs with 885's, and Dakars. Hard to find. Hard to find extended cabs in general….with a 6 speed manual.
  9. Nov 30, 2015 at 7:46 PM
    #8629
    OZ-T
    Peter North
    British Columbia
    You talking Access Cab ?
  10. Nov 30, 2015 at 7:47 PM
    #8630
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    So if I put a 115# Pelfreybilt bumper, plus my skids, plus me, plus a Winch, on 886's... Then load four obese dogs, 17 bags of concrete, 2 gorgeous ladies, two small cats, and a lawn mower in the bed of my truck with my Dakars.... Plus a handful of Bluray movies in the cab..... Oooh and exactly half a tank of 87 octane fuel....
    What temp will it be during the Super Bowl this year? :)
  11. Nov 30, 2015 at 7:54 PM
    #8631
    saddlecreek
    saddlecreek Member
    Nick
    Mazama, WA
    *Access cab
  12. Nov 30, 2015 at 8:12 PM
    #8632
    Ianp05
    Ianp05 Well-Known Member
    IAN
    DETROIT
    2006 Double Cab 4x4 TRD Sport
    Hi there -
    I have an 06 DCSB and I'd like to add a little clearance. I do alot of driving so I'm not looking for anything huge, I was thinking 1"-2" max. I spend alot of time on mountain roads, through rivers and deep rutted mud and snow, but don't do much rock crawling or plan on doing it. I don't use sliders or any major skid plates as they add weight and hurt gas milage but I would like a little extra clearance. Yes, I worry about gas milage, and, no, I not going to buy a Prius. My understanding is that you don't see tremendous hit in MPG's until you get to 3" and above (correct me if this is wrong) so I'd like to stay under that. I'm looking for ride quality and clearance over anything else. I'm often on highways traveling around 70-80MPH so I'm hoping to avoid rattles and whatnot. This is why I've been interested in OME, from what I understand they're supposed to be one of the best setups you can get.
    I'm also hoping to level the truck.
    I also have NO idea what I'm doing. I am not a mechanic, however, my two close friends are and can't wait to get their hands on my truck. They have quite a bit of experience lifting trucks, but told me I had to decide on my own parts, which I respect.
    I'm looking for resources, install instructions, parts selections, opinions and reviews. I'm assuming this is probably the best spot.
    Any information you guys can provide would be awesome. Thanks in advance!
  13. Nov 30, 2015 at 8:18 PM
    #8633
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    See Build Page
    My 3" OME lift didn't alter my MPGs. That happened after I added skids and wider rims - plus cold weather hit.
  14. Dec 1, 2015 at 5:25 AM
    #8634
    jtweezy
    jtweezy Well-Known Member
    Austin
    2014 4X4 DCSB OR V6
    42
    Kyitty[QUOTED] likes this.
  15. Dec 1, 2015 at 5:31 AM
    #8635
    jtweezy
    Austin
    2014 4X4 DCSB OR V6
    I'm scouring this thread looking for vibration issues and I'm not coming up with a solution. I just took a 1300 mile trip on the new OME setup and my vibration is still there. Seems worse after I've been driving for a while (like long highway stretches at 65-75mph). The vibration is most prominent at 45mph and it's a long pulse that can be felt in the floorboard. At first I kept thinking driveline, but the more I read the more I'm leaning towards needle bearing. I got truck aligned right after the install and the wheels balanced right before this trip.
    Also, I'm getting a real bad popping sound when I'm at full steering wheel lock in reverse. I think I may have popped a sway bar end link joint during the OME install, so I have to check on that today. Anyone have experience with the grease-able Moog end links?
    proven21 likes this.
  16. Dec 1, 2015 at 5:37 AM
    #8636
    gunn_runner
    gunn_runner www.gunnphotoservices.com
    Rocky River, OH
    2013 DCLB TRD
    OME 886 & Dakars. 35" Mickey Thompson Baja Boss
    If its the front drivers side needle bearing, it will go away when put into 4wd. Try that and report back. If it doesnt go away, most likely driveshaft u-joints are the culprit. Those are the two main vibration culprits we face when lifting the Tacomas.
    Kyitty likes this.
  17. Dec 1, 2015 at 6:37 AM
    #8637
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    See Build Page
    I've been trying to diagnose this on my Taco!! It only can be felt between 35-45mph when cruising. If slowing or accelerating I don't feel it. And I only feel it through the far left foot rest on the floor board.
    The "pulsing" comment is right on. It's like driving over the vibration groves on the side of the highway.
    I never get a pop though. Truck drives straight, etc. I haven't noticed it on 4x4 I don't believe but I'm rarely in 4x4 unless on an icy road and accelerating from a stop.
    Been considering going to Toyota to figure out what the heck this is. It's barely noticeable but it's there.
  18. Dec 1, 2015 at 6:39 AM
    #8638
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    See Build Page
    If it is that needle bearing what's the Method of repair? I've been trying to figure out this exact vibe (no popping) for months now on my 2015. Honestly can't tell you whether it began before or after lift.
  19. Dec 1, 2015 at 6:48 AM
    #8639
    proven21
    proven21 Well-Known Member
    Sterling, VA ( Loudoun County)
    2016 Taco DCSBOR 4x4 - Super White
    OME 90021 Front Strut 2887 Coils & OME N182 Rear Shocks, Wheelers Progressive AAL Pack, TC UCA's, BFG TA KO2 285/70r17 w/ 17" Method Wheels, AVS Window Visors, CoverKing NeoSupreme Seat Covers (charcoal/black), Mobtown Offroad Sliders, Relentless Fab. Bed Rack.
    I have just started experiencing this same exact thing just put on my OME setup you will see the post I did above with what I put on it, I just dropped it off at the dealership today considering there is only 1500 miles on it. I need answers!
  20. Dec 1, 2015 at 7:06 AM
    #8640
    PoweredBySoy
    PoweredBySoy Well-Known Member
    Jesse
    Minnesota
    2013 DCSB SR5
    Kyitty[QUOTED] and proven21 like this.
