Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Dec 12, 2015 at 12:59 AM
    #8761
    300AACTaco
    300AACTaco Well-Known Member
    Alaska
    Black '15 DCSB TRD Off Road 4x4
    ARB Old Man Emu 90000s and 60091s OME 886s, Trim Packer, Icon Tubular Uniball UCAs, CMC, Invisible Sway Bar, Dakar Rear Leaf Packs, Timbren Rear Bumpstops, All Pro U-bolt flip up kit, Method Race Wheels NV 16X8 4.5BS, Cooper ST Maxx LT285/75/16, DEPO Black Tail Lights, Weathertech Floormats, Cascadia Vehicle Tents Mt. Shasta in Earth Tone Green, Custom Green Tree Fabrication Bed Rack, N-Fab Spare Tire Bed Mount
    https://www.tacomaworld.com/threads/2nd-gen-ome-dakar-hub-to-fender-measurements.173193/
    "With 3rd leaf removed
    DCLB - 23 7/8" (1)
    DCSB - 23 3/8" (4)
    AC - 23 3/8" (2)
    With top overload removed
    DCLB - 24 (1)
    DCSB - 23 3/4 (8)"
  2. Dec 13, 2015 at 11:31 PM
    #8762
    300AACTaco
    Alaska
    Has anyone ever heard of someone using OME coils and getting far from the amount most report getting lift wise? For example my 887s on 90021s only gave about 2" lift. Am I the only one this has ever happened to?
  3. Dec 14, 2015 at 11:46 AM
    #8763
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    I found the answer to my question. It's an apples and oranges comparison.
    The OME shock is a twin tube, low-pressure design. This is radically different than a monotube high-pressure shock such as the Bilstein 5100.
    Apparently it's normal for a twin tube shock to not expand on it's own while compressed.
    Shock tech 101
    https://www.youtube.com/watch?v=vrUuESt2Q9I
    And
    https://www.youtube.com/watch?v=ZA8z0P3RVog
    Text version
    http://www.kyb.com/knowledge-center/shock-tech-for-pros/monotube-vs-twintube/
    DrFunker and tyfoon11 like this.
  4. Dec 14, 2015 at 1:36 PM
    #8764
    vrod671
    vrod671 The Okayest Member
    Brandon
    2022 TRD Sport
    Stock
    anyone?
  5. Dec 14, 2015 at 1:37 PM
    #8765
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    Nope. Didn't answer cuz I don't.
  6. Dec 14, 2015 at 1:38 PM
    #8766
    Crom
    Nick
    San Diego, CA
    Millions
    Could be your LCA bushings.
    vrod671[QUOTED] likes this.
  7. Dec 14, 2015 at 3:32 PM
    #8767
    silverpataco1968
    silverpataco1968 Tomorrow isn't Promised!
    Eric
    Eastern PA
    2007 DCSB and 2016 DCSB TRD Off-Road
    Plenty of great products so far !
    Or UCA ball joints Or CV Axle plenty of shit to make noise !:notsure:
    vrod671 likes this.
  8. Dec 14, 2015 at 3:37 PM
    #8768
    yesmar
    yesmar Well-Known Member
    Ramsey
    Harrisburg, PA
    A couple cars
    lift the truck up in the air so the tires are like 3" off the ground. get a digging bar and lay it on the ground under the tire. lift up the digging bar against the tire and the ground and search for loose/wore out components while you try to replicate the noise.
    vrod671 likes this.
  9. Dec 14, 2015 at 5:23 PM
    #8769
    tacoma2014
    tacoma2014 Well-Known Member
    Brandon
    Bellingham,wa
    2014 Sr5 doublecab longbox
    Hey guys, I am finally going to lift the Taco and decided on the OME lift... reading through the thread here and there it sounds like 886 with dakars is what I will get and not sure on the shocks yet. I don't have a front bumper yet with a winch but will shortly after the lift. will this setup give me a level stance? I have a topper and plan on putting more armor on the truck like sliders and a rear bumper. How would the ride be on and offroad with my truck setup like this?
  10. Dec 14, 2015 at 5:45 PM
    #8770
    la0d0g
    la0d0g Its 4 oÂ’clock somewhere
    running for the hills
    For crawling not hauling
    886s with dakars will probably leave you close to level until you put weight on the front. I have about .5" of rake w/ this setup and about 175lbs on the front. Ride is subjective, I like how mine rides :D
  11. Dec 14, 2015 at 5:46 PM
    #8771
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    See Build Page
    I believe the 886 with Dakars will give you rake.
    My 887's (taller springs) with Dakars still had rake.
    Though it seems this varies from truck to truck.
  12. Dec 14, 2015 at 6:00 PM
    #8772
    Jamart5
    Jamart5 HoeRunner
    Juan
    SETX
    '16 4Runner TRD
    I have the 886's with dakars in back gonna add 1/4 spacers on both sides because I still rub some and I want the Cali lean
  13. Dec 14, 2015 at 6:01 PM
    #8773
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    This is how it looked a couple days after the lift and a few loads in the rear. No front anything (just crush bar and stock rear bumper)
    With front bumpers and no rear bumper
    And now (no winch, rear bumper but no load-trailer is not hooked up)
    I have a winch now and it barely did anything. The ride is a bit softer but really it hasn't bothered me at all through the stages I showed you.
    Tires in all pictures are 265/75/16. Pretty good visual for ya. No spacer for taco lean. 886s and dakars.
    After close to three years and with the added winch with 255/85/16 this is how it sits. Not the best pic as the rear tires is a tiny bit flexed as I'm not on flat ground, but gives you an idea. Also have a 60-70lb tool box on the passenger side. Still rides same to similar. Little softer but awesome off-road.
    Jamart5 likes this.
  14. Dec 14, 2015 at 8:00 PM
    #8774
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    This
    vrod671 likes this.
  15. Dec 14, 2015 at 8:03 PM
    #8775
    vrod671
    Brandon
    2022 TRD Sport
    Stock
    Will check..thanks!
  16. Dec 14, 2015 at 8:28 PM
    #8776
    raggedphoto
    raggedphoto Well-Known Member
    Oregon
    DCSB 07 Desert Sand Mica
    For long haul vs short crawl
    I sit with a slight rake with this set up and I have about 200 pounds in the front with a bumper and winch. In the back I have a topper, deck and 70 pounds(ish) of tools. One of these days I need to measure everything but I think after the weight and settling I have less then 2.75" of lift which is fine with me. On a recent road trip I have a lot of added weight in the back and the Dakars held up really well, barely dropped in height at all!
  17. Dec 15, 2015 at 10:17 AM
    #8777
    tacoma2014
    Brandon
    Bellingham,wa
    wow thats not bad at all... the bottom pic with the trailer not hooked up looks like very little rake. I have a leer topper on mine so it might lower it a smidge. i have 265 75 16 on mine now but it still looks good with the same tires with the lift...
  18. Dec 15, 2015 at 12:31 PM
    #8778
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Yeah it's not bad at all. Also I believe I had full skids and sliders. Just something to mention.
  19. Dec 16, 2015 at 5:51 AM
    #8779
    backwoodsbob
    backwoodsbob Member
    Bobby
    Suffolk,VA
    2011 tacoma 4x4 trd
    I just put my 3in ome lift on with the top plate spacers and full Dakar leaf packs along with LR UCA's. And I have 33x12.50 tires I am going to put on it.. From the reading I have done it seems that I need rims with 4.5 back spacing to clear them, and probably have to trim the wheel wells.. If I do all of this should they fit fine?
  20. Dec 16, 2015 at 7:48 AM
    #8780
    proven21
    proven21 Well-Known Member
    Sterling, VA ( Loudoun County)
    2016 Taco DCSBOR 4x4 - Super White
    OME 90021 Front Strut 2887 Coils & OME N182 Rear Shocks, Wheelers Progressive AAL Pack, TC UCA's, BFG TA KO2 285/70r17 w/ 17" Method Wheels, AVS Window Visors, CoverKing NeoSupreme Seat Covers (charcoal/black), Mobtown Offroad Sliders, Relentless Fab. Bed Rack.
    Does anybody know where to get OME stickers at all???????? Yellow or white or something I would prefer the old school logo but I will take anything at this point.
