Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Dec 16, 2015 at 7:59 AM
    #8781
    Jamart5
    Jamart5 HoeRunner
    Juan
    SETX
    '16 4Runner TRD
    @Acerwin can make some
  2. Dec 16, 2015 at 9:05 AM
    #8782
    la0d0g
    running for the hills
    For crawling not hauling
    4 or 4.5 bs will work fine. Probably need to do a CMC as well to eliminate all rub.
  3. Dec 16, 2015 at 4:35 PM
    #8783
    silverpataco1968
    silverpataco1968 Tomorrow isn't Promised!
    Eric
    Eastern PA
    2007 DCSB and 2016 DCSB TRD Off-Road
    Plenty of great products so far !
    I just spent 20K this year with 3" front 4.75 " rear at first 285/70-17" Now 6" BDS with 7" in front 8" in the rear. 35"x12.5" BFG KO 2's with Fuel D538 wheels and only a 4.5" back set with still allows my new tires to rub the Swaybar! If "my" shop knew what they were doing they should have sold me 3.5"or 4" back spacing on the wheels! BMC will need to be done or you hit it with the steering wheel turned all the way in either direction!
  4. Dec 16, 2015 at 4:44 PM
    #8784
    la0d0g
    Swaybar relocate wouldn't move it out of the way? Or swaybar delete, I like that option.
  5. Dec 16, 2015 at 5:00 PM
    #8785
    silverpataco1968
    Eric
    Eastern PA
    Swaybar relocation kits a joke! Two spacers dropp it a bit!
  6. Dec 16, 2015 at 5:01 PM
    #8786
    la0d0g
    Just take it off then.
  7. Dec 16, 2015 at 5:04 PM
    #8787
    Jamart5
    Jamart5 HoeRunner
    Juan
    SETX
    '16 4Runner TRD
    Took mine off not really a difference.
  8. Dec 16, 2015 at 5:06 PM
    #8788
    la0d0g
    Mine came off with 884s and stayed off when I went to 886s. I can tell there is some extra body roll going around roundabouts but other than that I only notice it offroad. I drive like an old person though.
  9. Dec 16, 2015 at 5:08 PM
    #8789
    Jamart5
    Jamart5 HoeRunner
    Juan
    SETX
    '16 4Runner TRD
    I only feel it around 65 :)
    la0d0g[QUOTED] likes this.
  10. Dec 16, 2015 at 6:23 PM
    #8790
    YotaBum
    YotaBum Not So Well-Known Member
    Alex
    North Georgia
    2015 TRD Sport DCSB
    Blacked Out-887-Dakars-LR UCA-FJ Trail Team wheels-285 BFG KO2
    Drops it a little bit and moves it forward an inch... Worked for me with my 887 front.
    la0d0g likes this.
  11. Dec 16, 2015 at 6:25 PM
    #8791
    vrod671
    vrod671 The Okayest Member
    Brandon
    2022 TRD Sport
    Stock
    Same here
  12. Dec 17, 2015 at 9:18 AM
    #8792
    TNTramair
    TNTramair Well-Known Member
    2015 TRD OR SPORT
    anyone have issues with their Dakars creeking like an old wooden floor?? any permanent remedy for this? i hit the leafs with some spray lubricant and it goes away for a short time but eventually comes back. any input would be great...search not netting any results for me.
  13. Dec 17, 2015 at 9:28 AM
    #8793
    la0d0g
    Do the OZ thing and put rubber in between the leafs and the squeak point. I forgot all the details. @OZ-T for the link.
  14. Dec 17, 2015 at 9:37 AM
    #8794
    la0d0g
    Here is the thread with the details
    https://www.tacomaworld.com/threads/squeaky-dakars-any-advice-from-others-with-the-dakars.156353/
  15. Dec 17, 2015 at 10:29 AM
    #8795
    TNTramair
    2015 TRD OR SPORT
    thank you both.
  16. Dec 18, 2015 at 4:04 PM
    #8796
    shaneckc
    shaneckc Fyntünd Designs Vendor
    Shane
    Thousand Oaks, CA
    2014 SR Package DCLB 4x4
    I just bought the Toytec package for an OME setup. 9000 shocks up front with 885coils in preparation for a bumper addition later on. Purchased assembled with new bushings. I'm going to handle the install myself with a few experienced friends. Also got a smoking deal on some unibal Camburg UCA's. I plan on running 33" BFG K02s after chopping the cab mount, flattening the pinch weld, and trimming the fenders. I plan on running 1.25" spidertraxx wheel spacers for all 4 wheels, and I got some good tips on how to achieve proper alignment with this setup.
    I couldn't easily find the answers to the things I am wondering, so maybe someone will be willing to help me out here:
    Should I bother with the 4x4 front diff drop?
    I have both the ToyTec top plate spacers that are sold with this kit, and the Hell Bent Steel front spacers. It is my understanding that the installation of both of these is the same, with the Hell Bent steel spacers being intended to increase the height even more, so I'm wondering; could I use the hell bent steel spacers for a bit of extra lift up front? If possible, what would the costs / benefits of doing this be?
    Thanks to any and all for their contributions here :thumbsup:
  17. Dec 18, 2015 at 6:00 PM
    #8797
    jareebz
    jareebz Well-Known Member
    TX
    2019 TRDOR DCLB
    I don't know about the double spacer deal (seems like a bad idea), but the diff drops aren't good on 2nd gens so don't bother with that.
  18. Dec 18, 2015 at 6:01 PM
    #8798
    shaneckc
    Shane
    Thousand Oaks, CA
    Not double spacer. Just the larger one instead of the ~3/4" from ToyTec.
  19. Dec 18, 2015 at 6:02 PM
    #8799
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Bad idea
    shaneckc likes this.
  20. Dec 18, 2015 at 6:04 PM
    #8800
    jareebz
    TX
    2019 TRDOR DCLB
    Not an expert here by any means, just been reading a lot the last few years. I'd stick with the top plate spacers you got instead of the taller ones. Bumping your lift up that high is going to cause bad CV angles. That's the main reason people stay at or below 3" of lift.
