Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Feb 8, 2016 at 12:41 PM
    #9101
    bluefish
    bluefish overkill is underrated
    Nick
    Boston
    chitbox
    Thank you I'd appreciate it
  2. Feb 11, 2016 at 9:40 AM
    #9102
    crolison
    crolison Well-Known Member
    Ar vah da, CO
    POS
    Have another question for 885x.
    Double cab, 4wd, steel front skid, and sliders, offroad rear bumper and topper.
    Looking for around 1.75-2" of lift with the weight of my truck and picked up a used set of 885x with 40k miles and seeing if those should do the job with the sliders, and skid
  3. Feb 11, 2016 at 9:46 AM
    #9103
    TacoBurrito07
    TacoBurrito07 Well-Known Member
    Jake
    Arizona
    07 SWB Dbl cab TRD Sport 4x4
    You will probably be close to 2" but could be just above that.
  4. Feb 11, 2016 at 5:27 PM
    #9104
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Where'd you get 4? Source them all individually? I like the looks of them too.
    vrod671 likes this.
  5. Feb 11, 2016 at 6:40 PM
    #9105
    crolison
    Ar vah da, CO
    POS
    Actually found 4 on Craigslist together. I've bought a set before from junkyards. Usual price is 20-30 a rim
  6. Feb 11, 2016 at 6:43 PM
    #9106
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Nice. I'm sporting factory TRD OR wheels now. Maybe when they get really pitted...
  7. Feb 13, 2016 at 6:56 AM
    #9107
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    My research of many pages of TW threads and other sources have convinced me that the 5100/OME884x combo will work well with the OEM UCA.
    I have a 05 DCSB OR with a brand spanking new frame/rear leaf pack and I just ordered: OME884x and @HeadStrong Off-Road 3 leaf progressive AAL. I already have Bilstein 5100's on all four corners.
    My goal is to get a 1.5-2" lift after @Mobtown Offroad Front Receiver Recovery Bar (~45 lbs), Mobtown Bolt-on skids, near future full aluminum skids and portable receiver mounted winch (~85 lbs.)
    Part of this goal is to NOT have to do anything requiring a lot of work under my truck (i'm too old and too cheap), but getting decent offroad capability: No UCA replace, no top plate lift spacers (except 1/4" drivers side to correct "Taco Lean"), no new rear shocks, no new bump stops, no limiting straps, no diff drop, no shock relocation, no shackle flip. The more you start going over 2.5" of lift, the likelihood of doing all his crazy ass stuff goes up.
  8. Feb 15, 2016 at 9:37 PM
    #9108
    Mutt2jeff
    Mutt2jeff Member
    Washington
    07 tacoma
    At 120k miles, my rear leaf springs are flat and the bilstiens ride like absolute garbage. I would really like the truck to ride better onroad, be more supple on washboard and rough gravel roads, and be able to pull a trailer without squatting like a bad dog. I am looking to replace all 4 corners, and OME seems like it's well respected. Who is a good vendor to talk to who can suggest the right components?
  9. Feb 15, 2016 at 9:42 PM
    #9109
    TXTaco13
    TXTaco13 Taco/T4R Enthusiast
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    A lot of people reccomend Headstrong. I have never purchased from them, but I did have some inquiries about products, and they were very helpful.
    HeadStrong Off-Road likes this.
  10. Feb 15, 2016 at 9:46 PM
    #9110
    zeekevin
    zeekevin Well-Known Member
    San Diego
    wheeler's off road, I have ordered a quite a few things from them and never had a single problem with them. shipping should be fairly cheap because you are close to them, @YotaDan should be able to answer all your questions
    YotaDan likes this.
  11. Feb 16, 2016 at 6:12 AM
    #9111
    jtweezy
    jtweezy Well-Known Member
    Austin
    2014 4X4 DCSB OR V6
    trdparts4u -- free shipping. You can't customize the kit online, but call them up they can help you. I went with the standard kit and it was everything I needed.
  12. Feb 16, 2016 at 6:16 AM
    #9112
    NMW 4x4
    NMW 4x4 Wheels With Moose.
    Walt
    T8 R11 WELS, Maine
    '14 DCLB SR5 4x4
    x2 for Wheeler's Offroad. They're awesome.
  13. Feb 16, 2016 at 6:31 AM
    #9113
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    Headstrong OffRoad is where I went. Marie was very helpful.
  14. Feb 16, 2016 at 9:42 AM
    #9114
    la0d0g
    la0d0g Its 4 oÂ’clock somewhere
    running for the hills
    For crawling not hauling
    Plus candy! Wheelers FTW!
  15. Feb 16, 2016 at 9:45 AM
    #9115
    WheelInTheSky
    WheelInTheSky Ramblin' Man
    G
    Jackson Hole
    02 XtraCab 4x4 SR5-speed
    With the money I saved buying my kit through headstrong I could buy a fuckload of candy.
  16. Feb 16, 2016 at 9:53 AM
    #9116
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    I am looking at getting the OME Dakars for my 2011 dcsb with how they come and no AAL, I am wanting to also do the u bolt flip kit but am unsure what length i need and or what others have chosen. The rep at toytec said it would probably be too short with a shim under the pack.
  17. Feb 16, 2016 at 10:04 AM
    #9117
    zeekevin
    San Diego
    I ordered my u bolt flip kit thru wheelers which is the all pro setup from what I was told, here is a picture. It should be more then plenty of threads with the Dakar pack and shim
    Please ignore the brake lines, that was full droop with no shocks for testing purposes.
  18. Feb 16, 2016 at 10:09 AM
    #9118
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    are those the regular u bolts or extended ones?
  19. Feb 16, 2016 at 10:12 AM
    #9119
    zeekevin
    San Diego
    Not sure, I just called wheelers off road and told them what I wanted my setup to be, and they paired all the parts together and took my money and sent my box of parts and candy out to my door.
    GrayR1n0 likes this.
  20. Feb 16, 2016 at 10:13 AM
    #9120
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    ok. Does anyone have a measurement of how long u bolts they used?
