Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Apr 5, 2016 at 11:44 PM
    #9301
    nizzmont
    nizzmont Well-Known Member
    Brian
    S.E WA state
    2015 doublecab TRD sport
    in progress
    I got on the list for the 887's with HS today,thinking I'm going with the dakar rear leaf pack instead of a AAL or 3 pack
  2. Apr 5, 2016 at 11:46 PM
    #9302
    nizzmont
    Brian
    S.E WA state
    in progress
    Should note I'm trying to get a full 3 inches of lift and getting new UCA'S as well,is the front different drop recommended on this?over real it done with and without
  3. Apr 6, 2016 at 4:30 AM
    #9303
    jon.e.b3030
    jon.e.b3030 Well-Known Member
    john
    Hey all, quik question, can my ome shocks freeze ? I only get a clunking in front when temp gets below 20* f?
  4. Apr 6, 2016 at 4:59 AM
    #9304
    la0d0g
    running for the hills
    For crawling not hauling
    Diff drop is not recommended.
  5. Apr 6, 2016 at 4:59 AM
    #9305
    hardground
    hardground Well-Known Member
    Massachusetts
    2011 TRD OR DC V6 Manual
    OME Lift, ImMrYo Mirror Bracket, BlendMount & Mirror Tap ,TRD Quickshifter, 4x4 Illuminated Switch, Red Line Hood Struts, Bak Roll-X
    If I go with 2887 should I put on new UCA's?
    A 2" lift is fine with me, don't need 3" but want the truck level.
    Is there a OME leaf pack that only lifts 2"?
    Or are people just seeing 3" because the sag in their old suspensions?
  6. Apr 6, 2016 at 5:03 AM
    #9306
    la0d0g
    887s will net you about 3" of lift and yes it is recommended to get new UCAs when going that high. If you don't have a lot of weight up front you should look at 884s for about 2" of lift. When I had 884s with skids and sliders I got ~1.75" of lift.
  7. Apr 6, 2016 at 5:06 AM
    #9307
    hardground
    Massachusetts
    How was the rake with the 884's?
    Why not 885"s?
  8. Apr 6, 2016 at 5:10 AM
    #9308
    la0d0g
    Rake was minimal with TSB springs. I got a good deal on the 884s used and thought that was the direction I wanted to go with my truck. I've since gotten 886s. Here is a picture with the 884s with TSB leaf pack
  9. Apr 6, 2016 at 5:11 AM
    #9309
    nizzmont
    Brian
    S.E WA state
    in progress
    Thanks for the info on that,just trying to get all my stuff lined out so I have everything I need on hand when I start my lift install
  10. Apr 6, 2016 at 5:12 AM
    #9310
    nizzmont
    Brian
    S.E WA state
    in progress
    Looks great!what size tires?
  11. Apr 6, 2016 at 5:15 AM
    #9311
    la0d0g
    Those were 265/75 r16 BFG km2s
  12. Apr 6, 2016 at 5:16 AM
    #9312
    hardground
    Massachusetts
    Looks awesome! But I would like to use the OME Rear springs, thoughts?
  13. Apr 6, 2016 at 5:19 AM
    #9313
    nizzmont
    Brian
    S.E WA state
    in progress
    I'm leaning towards the dakar set but to save some coin maybe the HS 3 pack but im undecided.like most things I read on here and I get new ideas or change my mind lol
    DrFunker likes this.
  14. Apr 6, 2016 at 5:23 AM
    #9314
    DrFunker
    DrFunker Well-Known Member
    :laugh: yup. Damn you TW!
    YotaBum likes this.
  15. Apr 6, 2016 at 5:23 AM
    #9315
    la0d0g
    Get them and remove a leaf. You'll have a little more rake but will definitely be able to carry more.
    Edit: I love my dakars
  16. Apr 6, 2016 at 5:31 AM
    #9316
    hardground
    Massachusetts
    Did you put new UCA on your new setup?
    I want the Dakars for all the stuff I carry.
    Should I just put on new UCA's and be done with it?
    Drive 35K per year so don't want to kill my drive shafts.
  17. Apr 6, 2016 at 5:32 AM
    #9317
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    Marie at Headstrong told me NOT to do the front diff drop when I did my 887s.
  18. Apr 6, 2016 at 5:34 AM
    #9318
    nizzmont
    Brian
    S.E WA state
    in progress
    I sway back and forth on the rear Springs lol.front I'm going 887 cause my bumper will be no more than 130 then deduct factory parts removed for it and I should be ok as far as sag goes
  19. Apr 6, 2016 at 5:34 AM
    #9319
    la0d0g
    Yes, i have total chaos UCAs now but with my 884s i didn't come close to needing new ones. Heck, I didn't even need an alignment after I installed them (I guess I'm lucky with lifts) though I did get one.
  20. Apr 6, 2016 at 5:35 AM
    #9320
    hardground
    Massachusetts
    Are you worried about your drive shafts?
