Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. May 18, 2016 at 4:24 PM
    #9581
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Ha! I don't plan on going too hard. But I may end up doing the Superbumps anyway at some point :thumbsup:
    It's all good though. My truck gets nowhere near 20 MPG... :D
  2. May 18, 2016 at 4:48 PM
    #9582
    Danno 1948
    Danno 1948 Danno 1948
    Dan
    Ocala,Fl.
    2023 Tacoma Trail Edition/ Ice White
    little bit of everything
    ok I got a question, I just got new coil springs (ome 2881 old man emu heavy duty springs) I have bilsteins 5100 shocks on front and rear, I also have a extra leaf in the rear. which has the rear about 1" higher than the front. "when I put the new coil springs" (Im running oem coil spring right now and 5100 on the second setting) do I put the front 5100 on what setting to make it level with the back... 02 with a 3.4 automatic nothing on the font bumper ( hope this make scense)
  3. May 19, 2016 at 2:50 AM
    #9583
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    I got these from CVJ :http://www.cvjaxles.com
    I had one installed when I had an axle rebuilt. The other I just ordered the boot and installed myself.
    scottalot[QUOTED] likes this.
  4. May 19, 2016 at 3:20 AM
    #9584
    NMW 4x4
    NMW 4x4 Wheels With Moose.
    Walt
    T8 R11 WELS, Maine
    '14 DCLB SR5 4x4
    I would definitely set the 5100's at 0", since the 881's will be providing the lift.
    If you find you need slightly more lift, you can always bring them back up a notch.
  5. May 19, 2016 at 5:47 AM
    #9585
    la0d0g
    running for the hills
    For crawling not hauling
    Good call :rofl:
  6. May 19, 2016 at 6:35 AM
    #9586
    Danno 1948
    Dan
    Ocala,Fl.
    thank you, that's what I was thinking too.do you have to pull coil back apart to adjust to the next notch?
  7. May 19, 2016 at 6:50 AM
    #9587
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Yeah, I lost a clamp and wasn't sure how long it was off. I just went ahead and replaced the axle.
    Now, I have LCA skids too, hopefully, keep sticks and such getting in there...
  8. May 19, 2016 at 6:57 AM
    #9588
    NMW 4x4
    Walt
    T8 R11 WELS, Maine
    '14 DCLB SR5 4x4
    Generally speaking, yes. I suppose if you drooped the suspension enough to take the load off of the coil, you could hold the spring up and raise the seat.
    But, at that point, you're only two bolts away from being able to pull the shock out, at which point it would be much easier to adjust.
  9. May 19, 2016 at 10:13 AM
    #9589
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Great... One more thing to worry about :annoyed::D
  10. May 19, 2016 at 10:18 AM
    #9590
    la0d0g
    Who makes your LCA skid ?
  11. May 19, 2016 at 11:17 AM
    #9591
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    RCI. I have all of their skids :thumbsup:
    scottalot likes this.
  12. May 19, 2016 at 11:21 AM
    #9592
    la0d0g
    Righto. I asked because I have BAMF LCA skids and there is no contact with mine.
  13. May 19, 2016 at 11:25 AM
    #9593
    la0d0g
    I'm glad you're sure of things :rofl:
    HolyHandGrenade and scottalot like this.
  14. May 19, 2016 at 11:27 AM
    #9594
    Ihatetacomas
    Ihatetacomas Because tacomas hate me
    Dylan
    Elko NV
    '12 White LB TRD Sport
    Used @ 23,283 Volant Intake (w/ scoop)(removed August 2016), BAKFlip G2 Tonneau Cover, (drain tube mod), Pop & Lock Tailgate Lock, Stampede Vigilante Premium VP Series Hood Protector, 5lb Extinguisher, Shovel & Axe mounted in bed, Shok Industries Sound Deadener, Mercury: (K62, MGR-1200, MGR-495) Triton 8" Subs, Custom-Made: Sub Box, Speaker Templates, Vapor Barrier, All-Pro Bumper w/Kickouts, hidden trailer hitch, wooden cup-holder Misc: Knukonceptz RCA, speaker, and power wires, Big 3 Upgrade, a very full Husky technician tool box
    Has there been any news on the BP51's? Installs in our forum? Also do they come 'stock' with the reservoirs or is that an option?
  15. May 19, 2016 at 12:23 PM
    #9595
    ssmith0480
    ssmith0480 Well-Known Member
    Shaun
    Ringgold, GA
    2019 TRD Offroad
    Extended travel Kings, 650 coils Tundra Kings rear Icon AAL with 1/2” shim & Firestone airbags Total Chaos UCA’s ARB onboard air VTX Stinger 17x9 -25 offset Yokohama g003 MT 295/70/17’s RCI roof rack and bed rack TRD Pro skid TRD Pro tail lights R4T high clearance exhaust CBI Baja bumper Smittybilt xrc 9500 winch Dobinsons snorkel, Syklone precleaner Caliraised ditch lights, rigid covers 5.29 gears CVT Mt. Washington RTT Body Armor sliders ECGS bushing
    How do you calculate lift height if there is a difference side to side in stock height? For example...my original measurements in the front was 20" on driver side and 20.5" on passenger side. Was the driver side 1/2" low due to Taco lean? Should it have been 20.5" as well?
    I guess what I'm asking is if I need to lift the driver side 3.5 inches to truly have 3" of lift (that's just as an example...I would rather be around 2 3/4").
  16. May 19, 2016 at 12:42 PM
    #9596
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Same lift both sides, trim packer on the drivers side :thumbsup:
  17. May 19, 2016 at 12:48 PM
    #9597
    ssmith0480
    Shaun
    Ringgold, GA
    2019 TRD Offroad
    Yeah I did that. It's still low though. I'm trying to figure out how to make it 2.75" of lift and still keep it level in the front. I apparently need top plate spacers to get 2.75" of lift but I'm unsure of which to add.This is what I have so far...
    So if anyone can help me with this I'd appreciate it.
  18. May 19, 2016 at 12:54 PM
    #9598
    la0d0g
    So you have the lift installed now? If so, which springs?
  19. May 19, 2016 at 12:59 PM
    #9599
    ssmith0480
    Shaun
    Ringgold, GA
    2019 TRD Offroad
    887
  20. May 19, 2016 at 1:00 PM
    #9600
    la0d0g
    How much lift do you have now? 2.5?
