Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Jun 10, 2016 at 1:51 PM
    #9721
    3milecreek
    3milecreek MtnGoat
    Stephen
    Barnwell SC
    Heavily Modified 94 Yota
    Never the same
    Haha what ever floats ya boat. I live on a washboard dirt road and it sucks to have a stiff ass suspension. I wish I had the money to drop on some sweet coilovers but money problems.
  2. Jun 10, 2016 at 2:02 PM
    #9722
    Jamart5
    Jamart5 HoeRunner
    Juan
    SETX
    '16 4Runner TRD
    Damn so your saying I didn't have to buy a complete ome kit I just could of changed coils smh.. Anywho did you install CB drop I still haven't and truck has no vibes
  3. Jun 10, 2016 at 2:19 PM
    #9723
    3milecreek
    3milecreek MtnGoat
    Stephen
    Barnwell SC
    Never the same
    Yep. I'm running Billie 5100s with ome 886s and Dakars with Billie b110s and it rides a lil stiff but not bad stiff. Also note that i have 200lbs plus up front. Nope I don't have any vibes either so never installed one.
  4. Jun 10, 2016 at 2:42 PM
    #9724
    Jamart5
    Jamart5 HoeRunner
    Juan
    SETX
    '16 4Runner TRD
    I have about the same weight up front my ride varies day to day.
  5. Jun 10, 2016 at 2:47 PM
    #9725
    hillbillytoyo
    hillbillytoyo Well-Known Member
    Daniel
    WV
    17 Tundra Crewmax SR5 TRD Off Road.
    G2 bed cover
    Thanks guys, just ordered. And now the waiting game.
    TheTacoma likes this.
  6. Jun 11, 2016 at 12:27 AM
    #9726
    RifkinMasterson
    RifkinMasterson Well-Known Member
    Tennessee
    2012 Tacoma SR5
    My only real tip is read through the OME install DIY one here before you start, it really helps. Having a good ball joint separator is also really helpful. I sprayed any bolts that looked like they would be tough (leaf spring bolts, U bolts, lower shock bolt) with PB blaster a day before I started. Everything broke loose with ease. FYI, if you are like me and get 2 sets of bushings with your kit, it's an extra set. My dumbass assumed that since the springs had a bushing in them already that the other one must go in the shackle/bracket ordeal at the rear of the spring. Without even looking at the size, I commenced to destroy the stock on taking it out (instead of melting it, I used a drill press and just made tons of holes until it popped out). Well surprise! That's not where the new bushings go. I ended up spending 30 minutes and a lot of swearing "engineering" on of the new bushings to fit in there (by that I mean cutting it down with a hack saw until I could press it in the shackle). Don't do that and you should be able to finish in like 3-5 hours depending on if you've done suspension before.
    TheTacoma[QUOTED] likes this.
  7. Jun 11, 2016 at 12:30 AM
    #9727
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    wait, so i did get an extra poly bushing kit? now im confused, anybody got a parts list hanging around for a kit?
  8. Jun 14, 2016 at 7:33 AM
    #9728
    Twalt87
    Twalt87 Well-Known Member
    Travis
    Vancouver island Bc
    Heyoo, I'm going to be buying ome pretty soon and want to make sure my facts are correct before i do.
    Trucks a 12 double cab long bed. I have cooper discoverer st maxx tires which made my truck rough af. Im looking to gain close to 2" of lift.
    Everywhere i read says the 2885 coils will give almost 3" with a double cab and the 2884s would be closer to 2", this right?. I am going with their struts and shocks and the trim packer.
    For the rear I was just thinking of a 1" block to level it out.
    Is any of this wrong? Also Will this make my truck ride smoother then it is? or stiffer?
  9. Jun 14, 2016 at 7:38 AM
    #9729
    TheTacoma
    TheTacoma Well-Known Member
    Birmingham, AL
    2017 DCSB, TRD OR 4x4, Quicksand. SOS Bolt-on Sliders. 285x75r16. Kings
    That sounds right to me. The ride will be rough with the block in the back I think, I would go with an AAL.
  10. Jun 14, 2016 at 10:01 AM
    #9730
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Reformed Taco driver in a GX460
    I just put 885's on my '13 and after settling its 1-3/4" lift. Kinda disappointed. Think I'm going to go to .85 on my 5100's.
  11. Jun 14, 2016 at 10:05 AM
    #9731
    la0d0g
    running for the hills
    For crawling not hauling
    Why do you need more lift? Is it worth changing the ride for?
  12. Jun 14, 2016 at 10:09 AM
    #9732
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    To clear the 33's I just ordered. I will try 1/2" top plate spacer first.
  13. Jun 14, 2016 at 10:17 AM
    #9733
    la0d0g
    You don't need any more lift than that to clear 33s. CMC, plastic cut, etc. sure but not more lift.
  14. Jun 14, 2016 at 12:10 PM
    #9734
    moe2o4
    moe2o4 Well-Known Member
    Corey
    Pittsburgh PA
    2016 SR Silver 2.7L 5 Speed
    OME 3" Lift, 32" Tires, Lots of Mods!
    Hi Guys,
    Just got my tracking number from the group buy for my OME Suspension Kit with 887's and Dakar leafs the other day. So hopefully they will be here in a few days. I also got a set of Light Racing Upper control arms and a set of 4 stainless steel 2" extended brake hoses! And 2 new bolts for the upper control arms so I can just cut the heads off and pull them out!
    I got a few questions for you guys. I do all the work on my own vehicles and I'll be installing the kit.
    1. Just wondering when I install the Light racing upper control arms should I just center the ball-joint in the center of the oval slot where you adjust it back and forth for the camber?
    2. I'll be scheduling a alignment for the truck shortly after I get the lift installed but should I ride on the kit for a few days before the alignment if there is going to be any settling?
    Thanks!
  15. Jun 14, 2016 at 12:20 PM
    #9735
    The Hunter
    The Hunter Sailing the high Puddle's
    Hunter
    Monroe NJ
    2011 Submarine
    Flux capacitor and bi-plane wings
    Youll need a new alignment instantly after installing the lift or your camber caster and toe will be all off...
    moe2o4[QUOTED] likes this.
  16. Jun 14, 2016 at 12:22 PM
    #9736
    moe2o4
    Corey
    Pittsburgh PA
    Gonna try to get a appointment for the day after I install the kit or possibly the same day!
  17. Jun 14, 2016 at 12:31 PM
    #9737
    AKSig88
    AKSig88 Well-Known Member
    Ann Arbor, MI
    2023 SR5 Tundra
    I got an appointment for tomorrow evening, the same time my 285's are mounted. Hopefully I can install my OME kit before this appointment lol!
  18. Jun 14, 2016 at 12:51 PM
    #9738
    la0d0g
    Yep, otherwise you're going to be paying for two of them :D
    AKSig88[QUOTED] and moe2o4 like this.
  19. Jun 14, 2016 at 1:48 PM
    #9739
    raggedphoto
    raggedphoto Well-Known Member
    Oregon
    DCSB 07 Desert Sand Mica
    For long haul vs short crawl
    I can't recall how I set my but I just followed the instructions that came with them, they give you a baseline for where they should be set based on the amount of lift. I also took those instructions to the alignment shop incase they had questions. I had the truck aligned the next day after the lift.
  20. Jun 16, 2016 at 5:53 AM
    #9740
    Natedog 73
    Natedog 73 Member
    Nathan
    2006 red tacoma prerunner
    GETTING MY OME LIFT WITH 885'S AND DAKAR LEAFS AND PRO COMP UCA'S PUT ON MONDAY. JUST WONDERING IF SOMEBODY COULD HELP ME WITH ALIGNMENT SPECS TO SET FRONT END AT. CALLED PRO COMP AND THEY SAID TO PUT IT AT STOCK SPECS. I DON'T THINK THIS IS RIGHT BECAUSE I WILL BE ADDING ABOUT 2.5 INCHES TO MY TACO.
