Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Jun 16, 2016 at 6:57 AM
    #9741
    la0d0g
    running for the hills
    For crawling not hauling
    Toe and camber 0
    Caster 3
    Or as close to those as possible. And don't yell at the alignment person ;)
    moe2o4 likes this.
  2. Jun 16, 2016 at 7:12 AM
    #9742
    Natedog 73
    Natedog 73 Member
    Nathan
    2006 red tacoma prerunner
    THANKS FOR THE INFO. AND WHY WOULD I YELL AT THE ALIGNMENT PERSON?
    scottalot likes this.
  3. Jun 16, 2016 at 7:13 AM
    #9743
    moe2o4
    moe2o4 Well-Known Member
    Corey
    Pittsburgh PA
    2016 SR Silver 2.7L 5 Speed
    OME 3" Lift, 32" Tires, Lots of Mods!
    You caps lock stuck on? :rofl::rofl:
    la0d0g likes this.
  4. Jun 16, 2016 at 7:47 AM
    #9744
    Natedog 73
    Natedog 73 Member
    Nathan
    I KNOW TO LAZY TO HIT SHIFT. :benchpress:
    scottalot[QUOTED] likes this.
  5. Jun 16, 2016 at 7:52 AM
    #9745
    moe2o4
    Corey
    Pittsburgh PA
    Shift wont turn caps lock off.......:rofl::rofl:
  6. Jun 16, 2016 at 8:22 AM
    #9746
    Natedog 73
    Natedog 73 Member
    Nathan
    No but you have to use it if you want to start a sentence with a capital letter. So I will use shift for you people instead of caps lock.:thumbsup:
  7. Jun 16, 2016 at 8:25 AM
    #9747
    Natedog 73
    Natedog 73 Member
    Nathan
    No but you do have to use it if you want to start a sentence with a capital letter. Just thought it was easier using caps lock. Will start doing the right way. :thumbsup: Thanks for keeping my hillbilly butt in line.:D
  8. Jun 16, 2016 at 8:38 AM
    #9748
    Natedog 73
    Natedog 73 Member
    Nathan
    I am getting the OME lift for my Tacoma prerunner and I had a leveling kit on my truck and the truck never drove right since I had the leveling kit put on it would road walk bad. I had a alignment tech ck it out and he said everything looked good. He drove it around the block to ck it out and he said it was normal. So I have been driving it like that for 2 years. I got on this forum and found this thread on the OME lift. Everything I have read sounds like the OME lift and UCA's will fix my problem. Any thoughts?
  9. Jun 16, 2016 at 9:02 AM
    #9749
    Natedog 73
    Natedog 73 Member
    Nathan
    Thanks for your input. I will get back on Thurs. after lift install and alignment with results and maybe some pics. If I can figure out how to do pictures on here.
  10. Jun 16, 2016 at 9:21 AM
    #9750
    moe2o4
    Corey
    Pittsburgh PA
    Those are the specs you want!
  11. Jun 16, 2016 at 9:22 AM
    #9751
    Natedog 73
    Natedog 73 Member
    Nathan
    Yes. Somebody answered that for me on the previous page. :thumbsup:
    moe2o4 and scottalot[QUOTED] like this.
  12. Jun 16, 2016 at 9:37 AM
    #9752
    Natedog 73
    Natedog 73 Member
    Nathan
    Yes I know. This forum is awesome and so are the people here. Thanks everybody for making a newbie welcome.
  13. Jun 16, 2016 at 9:42 AM
    #9753
    moe2o4
    Corey
    Pittsburgh PA
    Anytime man!
  14. Jun 17, 2016 at 1:48 PM
    #9754
    Fahrenheit
    Fahrenheit Well-Hung Member
    Garth
    NS
    So, I'm having the great debate, i have 886s going on soon, i also have a 1/2" spacer, and i have the D29XL aal to go on too, this should be fairly level when it's all said and done ya?
  15. Jun 18, 2016 at 5:38 AM
    #9755
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    Are you running any armour? If your running a front bumper with a swing out and a cap and gear in the rear I would say so you would be level. I have a cap with a bed slide and gear and I am adding the d29xl to give the rear end some help as I am slightly sagging.
    Truck with the 886's and dakars no d29xl. No bumper only sliders and skids.
    With armour
    No bumper in case your not running one
    kinda give you an idea with the armour options if your running any.
  16. Jun 18, 2016 at 2:29 PM
    #9756
    Fahrenheit
    Garth
    NS
    Sorry, yes i have a Pelfreybilt steel bumper and skid. I would like to have the D29XLs as i put a fair amount of weight in the rear during the winter months, as my plan was to load a lrg tote box with sand and mount a shovel in the event of a no traction occurrence, not just me but others. My Dakars both have (-) on them
  17. Jun 18, 2016 at 6:04 PM
    #9757
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Another question about bump stops. I'm on a five hour flight right now. I have nothing but time on my hands... But I've be searching and searching with no luck. I KNOW I've seen the answer to this question on here before, but now I just can't find it.
    Right now I'm running Dakars and Ride Rites. I had the bags prior to the Dakars and I just don't need them now. My question is this. I want to run Superbumps with a U-bolt flip kit with the Dakars.
    I know I've seen this setup on here. Anyone know what flip kit works with the Superbumps and Dakars?
    Thank you!
  18. Jun 18, 2016 at 10:26 PM
    #9758
    TXTaco13
    TXTaco13 Taco/T4R Enthusiast
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    I think the All Pro does
  19. Jun 19, 2016 at 4:34 AM
    #9759
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
  20. Jun 19, 2016 at 11:32 AM
    #9760
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Hey thank you. I just found the correct setup on Wheelers page:
    tacoma16[QUOTED] likes this.
