Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Jul 11, 2016 at 3:06 PM
    #9921
    raggedphoto
    raggedphoto Well-Known Member
    Oregon
    DCSB 07 Desert Sand Mica
    For long haul vs short crawl
    With my 886, Dakars and LR UCA's I feel like my truck tracks and corners better than stock ever did. Sure it is stiffer but it doesn't feel tippy nor does it bounce around the road when loaded down, over all a huge improvement!
    TheTacoma likes this.
  2. Jul 11, 2016 at 3:08 PM
    #9922
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    X2
    raggedphoto[QUOTED] likes this.
  3. Jul 11, 2016 at 7:53 PM
    #9923
    RifkinMasterson
    RifkinMasterson Well-Known Member
    Tennessee
    2012 Tacoma SR5
    My truck tracks perfectly straight and I like the ride better than stock (full OME stock kit on 2012 DC). I had a full OME kit on my old Land Rover and also loved it with 0 problems. I'd be willing to bet money that the trucks you drove either needed an alignment or had wayyyyy too much air in the tires. A quality suspension kit made to work together isn't going to give you any negative issues except for all the chicks that will want to ride in your truck (okay, that may be a stretch but you'll have lots of guys here liking it).
  4. Jul 11, 2016 at 9:08 PM
    #9924
    AiNoFaKNKeA
    AiNoFaKNKeA Well-Known Member
    Hawaii
    '14 TRD Sport DCSB
    885's w/ 1/2" spacers on OME Sport Nitros OME Dakars w/ Sport Nitros & D29XL AAL 285/65 BFG AT KOs on 18" Dropstars 645B 0 Offset 4.5" BS Spidertrax 1.25" Wheel Spacers LED Interior and Exterior 6K HID Headlamps and Fogs 6K LED DRL Switchbacks Pop and Lock Codeable Smart Lock Tailgate Handle Debadged Wet Okole's Front and Rear Weathertech Digital Fit Floor Liners Husky Liners Custom Molded Mud Guards Tint AMP Research Bed Step AMP Research Bed Extender ImMrYo Rear-View Mirror Lift Bracket Viper Alarm ICE: Alpine PDX-V9 Audio Control LC6i Image Dynamics CTX65CS Image Dynamics CTX65 Image Dynamics IDQ12 KnoKnoise Sound Deadening
    OME > Spacers
    You won't be disappointed.
  5. Jul 11, 2016 at 9:37 PM
    #9925
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Hey thanks. I did see those. I'm thinking about adding a piece to the frame where the bump stop makes contact though. Most likely just some square stock.
  6. Jul 11, 2016 at 9:40 PM
    #9926
    TXTaco13
    TXTaco13 Taco/T4R Enthusiast
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    Right on. I am going to go with them when I get mine, since you can tweak it in increments.
  7. Jul 12, 2016 at 7:38 AM
    #9927
    Jtaoj0
    Jtaoj0 Well-Known Member
    Hi here is an embarrassingly basic install question. I bought the full OME kit in the gb. Stock/light on a 2015 dcsb 4x4. I Also splurged and bought Light Racing UCAs. From what I understand. I will still need to disconnect the spindle and LCA to install the strut. Then reinstall per instructions. Does it matter if the UCAs are installed first or last? I was hoping if I did the UCAs I wouldn't need to drop the LCA. Also, on the UCAs, are there any tricks to not have to bend the inner fender? Cut off old and install new or? Thanks. Doing what I always do, which is overthink projects :)
  8. Jul 12, 2016 at 8:00 AM
    #9928
    B22wheeler
    B22wheeler Well-Known Member
    Brady
    Redondo beach
    2016 TRD Sport Tacoma
    No need to drop the Lower control arm. I got the same kit w/ SPC LR UCAS. I used the sawzall and cut the Uca bolt and reinstalled in the opposite direction.
  9. Jul 12, 2016 at 12:48 PM
    #9929
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    I don't think you need to drop the lca entirely or remove spline. . ..I like above post for removal and reinstall ^
  10. Jul 12, 2016 at 12:55 PM
    #9930
    la0d0g
    la0d0g Its 4 oÂ’clock somewhere
    running for the hills
    For crawling not hauling
    Correct. Pop the tie rod end off, remove the two lower knuckle bolts and swing to the side. Insert coil assembly.
  11. Jul 12, 2016 at 2:10 PM
    #9931
    BCephus
    BCephus Alright then
    Slingblade
    Virginia
    08 DCabSB 6 speed OME'd
    OME 886/dakar heavy, ARB bumper, 9.5XP warn, PDM tranquil kit, custom bullet hole tailgate anti theft kit, Camburg ball joint UCAs, Centerforce II clutch, FJ cruiser TRD wheels (black) with 285/75/16 Ds (white letters out, (Duh))
    Yep. Coils are pretty stiff. I should have gotten them assembled by a local shop with an adequate spring compressor. Might consider that, they are beefy. Sway bar relocate also if you plan on keeping it installed. Some do, some don't. I'm skeered to take it off. Handles awesome on the road, really nice off road..just tops out the suspension on occasion and clunks.
  12. Jul 12, 2016 at 3:36 PM
    #9932
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
  13. Jul 12, 2016 at 9:47 PM
    #9933
    Jtaoj0
    Thanks for the replies. So you popped out the old UCA, left the LCA alone, then did the the coil Over? I was thinking about just cutting the LCA bolt and doing new. Didn't know about the reversal of the bolt trick. That is cool. How close was alignment before taking to a shop? The place I like is 30 miles away. Thanks! Jj
  14. Jul 12, 2016 at 9:49 PM
    #9934
    Jtaoj0
    More info and help. You guys are awesome. Thank you for you help and input! Jj
  15. Jul 13, 2016 at 2:58 PM
    #9935
    TheTacoma
    TheTacoma Well-Known Member
    Birmingham, AL
    2017 DCSB, TRD OR 4x4, Quicksand. SOS Bolt-on Sliders. 285x75r16. Kings
    I would not do anything to the LCA, there is plenty of room to get it installed. Especially if you are doing new UCAs at the same time. You can push the lower arm down to if you need room to get the struts in.
  16. Jul 13, 2016 at 3:00 PM
    #9936
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    My alignment was almost perfect, I drove for a few weeks so it would settle and I installed a bumper, then got it aligned
  17. Jul 13, 2016 at 3:20 PM
    #9937
    Jtaoj0
    Thanks guys. This helps a bunch. Tx jj
  18. Jul 13, 2016 at 9:37 PM
    #9938
    300AACTaco
    300AACTaco Well-Known Member
    Alaska
    Black '15 DCSB TRD Off Road 4x4
    ARB Old Man Emu 90000s and 60091s OME 886s, Trim Packer, Icon Tubular Uniball UCAs, CMC, Invisible Sway Bar, Dakar Rear Leaf Packs, Timbren Rear Bumpstops, All Pro U-bolt flip up kit, Method Race Wheels NV 16X8 4.5BS, Cooper ST Maxx LT285/75/16, DEPO Black Tail Lights, Weathertech Floormats, Cascadia Vehicle Tents Mt. Shasta in Earth Tone Green, Custom Green Tree Fabrication Bed Rack, N-Fab Spare Tire Bed Mount
    Anyone ever blown an OME shock here? I've had two incidents where I swear I should've blown one but didn't, these shocks are awesome
    Sandman614 likes this.
  19. Jul 13, 2016 at 9:54 PM
    #9939
    Sandman614
    Tim
    '06 SR5 Off Road
    I blew out a brand new OME BP51 rear shock.
    300AACTaco[QUOTED] likes this.
  20. Jul 13, 2016 at 9:55 PM
    #9940
    Sandman614
    Tim
    '06 SR5 Off Road
    This always makes me worry. I hope the nut never comes loose...
