Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Jan 21, 2013 at 12:06 PM
    #81
    4Wheelin4Banger
    4Wheelin4Banger [OP] Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    Moose is always a good source for info.
  2. Jan 21, 2013 at 12:10 PM
    #82
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Mind>>>blown. Learn something new everyday here. I also thougt more caster will move the wheel foward in the wheel well. Makes sense though how bjmoose expained it.
    On the instructions for alignment by spc it says to max out caster on the LCA cams, get caster where you want it with the adjustable UCAs then dial back the LCA cams to get camber perfect. It all makes sense now :D
  3. Jan 21, 2013 at 3:51 PM
    #83
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    This should help out:
    http://www.cruiseroutfitters.com/tech_OME_coils.html
    Spring name/Spring rate (N/mm)/Bar dia/Coil length (mm)
    [FONT=Arial,Helvetica]OME 883 / [/FONT]103 / 17 / 375
    [FONT=Arial,Helvetica]OME 884 / [/FONT]103 / 17 / 385
    [FONT=Arial,Helvetica]OME 885 / [/FONT]103 / 17 / 395
    [FONT=Arial,Helvetica]OME 886 / [/FONT]115 / 18 / 402
    103 = 588 #/in
    115 = 656 #/in
    LGOPs504 likes this.
  4. Jan 21, 2013 at 3:53 PM
    #84
    evanmb31
    evan
    connecticut
    09 trd off road
    ^:woot: now i know where to find it!
  5. Jan 21, 2013 at 4:30 PM
    #85
    Nicky Lam
    Nicky Lam Dog Face Soldier
    Nick
    Somers Point/Mount Laurel, NJ
    2013 Blk DC Off Road
    NOV12: Front windows tinted to matched to rear windows 12NOV12: Fog light anytime mod DEC12: OME 885 w/ 25912 top plate spacers for full 3" lift OME Trim packer Dakar Rear 5 Leaf Packs Total Chaos Uniball Upper Control Arms 2.5° Degree Rear Axle Shims 18JAN13: 17x9 Fuel Kranks 17x9 4.5 BS -12mm Offset 285-70-17 Goodyear Duratracs 23JAN13: OME Carrier Bearing Drop Kit 05FEB13 TRD Aluminum Skid Plate 05FEB13 TRD Stainless Steel Cat Back Exhaust (2012 modified to fit 2013) Auto Mate 5304A (Viper 5704 Equivalent) 2-Way Alarm/Remote Start with Smart Start for iPhone De-Badged All Emblems 30JUL13 Go Rhino Stainless Steel Dominator II Side Steps *not yet installed: Stainless Steel Extended Rear Brake Lines
    well... given i have TC UCA, and they are not adjustable, i can only adjust from the oem lower control arms. TC UCA have added caster built into them. im at 1.4 Caster now, if increase caster from the lower control arm/eccentric cams i will INCREASE Clearance.
    so... if im rubbing in reverse now with 1.4 and i raise that back up to 2.4-2.9 degree caster from the LCA it will give me more clearance at the cab mount (which i want) because its not hitting the front fender or wheel well at all right now. i have a lot of extra room towards the front that i want to move the wheel forward maybe 0.5 inches would be perfect
    had me all worried for a little bit there
  6. Jan 21, 2013 at 4:47 PM
    #86
    la0d0g
    running for the hills
    For crawling not hauling
    +1 for this jazz!
  7. Jan 21, 2013 at 10:57 PM
    #87
    Tacoma414
    Tacoma414 Well-Known Member
    Cody
    Agua Dulce
    06 PreRunner SR5 4.0L
    Flowmaster Exhaust 2" spacer lift 09 Tails blacked out Black headlight mod 6000k HIDs/Foglight mod Fog Light Mod 20" LED Light Bar Behind Grille Billet Grille Color matched mirros, doorhandles and bumper 5% tint all around Pioneer 4300dvd 2 10" kicker CVRs Alpine speakers Dome light: Blue LED Map light: White LED
    I have a v6 Pre runner AC and I have 2" spacers on it now, how much lift would I get if I loose the spacers and put 5100s and
    884x: ?
    885x: ?
  8. Jan 21, 2013 at 11:01 PM
    #88
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Probably stay where it is with 884's , you may get another 1/2" with 885's
  9. Jan 21, 2013 at 11:04 PM
    #89
    Tacoma414
    Cody
    Agua Dulce
    So it wouldn't have a huge difference in looks with a half inch?
  10. Jan 21, 2013 at 11:05 PM
    #90
    OZ-T
    Peter North
    British Columbia
    about a 1/2" worth
  11. Jan 22, 2013 at 12:03 AM
    #91
    just2wd
    just2wd Well-Known Member
    Dan
    California
    07 PreRunner TRD Off Road
    Planning on getting ome kit ..if I get 886 coils would it require top plate spacers still for full 3 inch lift? I have an access cab
  12. Jan 22, 2013 at 2:40 AM
    #92
    evanmb31
    evan
    connecticut
    09 trd off road
    Pretty sure top plate spacers are bot recomended with 886s. Let someone else confirm that. Are you planning on adding extra weight up front?
  13. Jan 22, 2013 at 7:30 AM
    #93
    OZ-T
    Peter North
    British Columbia
    No need for top plate spacers to get 3" with 886's
  14. Jan 22, 2013 at 7:34 AM
    #94
    Eagledynasty
    Eagledynasty The White Knight
    AJ
    Worcester, MassHole
    09 Super White DoubleCab Off-Road
    2009 SWDC O/R. Check Build!
    With your access cab the 886x may push you above 3" of lift without the top plates.
  15. Jan 22, 2013 at 7:35 AM
    #95
    just2wd
    Dan
    California
    Yes I plan on changing the bumper..thanks for the help!
  16. Jan 22, 2013 at 7:38 AM
    #96
    Pugga
    Massachusetts
    :laugh:
  17. Jan 22, 2013 at 7:41 AM
    #97
    dlooney
    dlooney Well-Known Member
    Dennis
    Wilmington NC
    07 TRD Sport PreRunner
    Satoshi w/ hella 500s mounted behind, 20% tint, 6K HID retro headlights, 4300k HID fog lights, DTRLs, plastidipped front valence, cb mount
    Anyone know if the FJ and Tacoma OME coils are interchangeable? There's a guy selling the front setup but he said he had it on his FJ, he says it'll fit tacomas as well.
  18. Jan 22, 2013 at 8:07 AM
    #98
    4Wheelin4Banger
    Randy
    The coils appear to be, but it depends on the year for the shocks according to Toytec.
    FJs '10 & up take a different shock.
  19. Jan 22, 2013 at 10:06 AM
    #99
    dlooney
    Dennis
    Wilmington NC
    Thanks that helps a lot. One other thing, the guy says they're 884 coils. I have a v6 double cab and I know I'm supposed to have the 885s but how much of a difference does it make? I'm ok if I don't get the full 3 inches, in fact I'd prefer closer to 2.5 anyways.
  20. Jan 22, 2013 at 10:09 AM
    #100
    Pugga
    Massachusetts
    You're not 'supposed' to have any specific coil. 883, 884, 885 and 886 all fit the Tacoma and you can choose which coil you prefer based on the amount of lift you want. 884's will put you right around 2" of lift.
