Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Aug 17, 2016 at 9:58 AM
    Twinkie0311
    Twinkie0311 Mall crawling like a boss
    Hillsboro, Oregon
    13 DCLB TRD Sport MGM
    OME Lift w/ Dakars, TRD catback exhaust, 275/70/17 with SCS Stealth 6. and much more.
    Cool. There isn't too much of s difference between 265/70/17 vs 275/70/17. I just wasn't sure with the back spacing and stuff the Stealth 6 wheels would give me.
  2. Aug 18, 2016 at 9:25 PM
    FL TRD
    FL TRD Well-Known Member
    Florida
    05 Prerunner SR5 TRD
    Hi guys quick question I have a 3" spacer lift on the front of my 05 trd or pre runner and I just bought some 5100's and I'm looking at the emu springs how can I get 3" of lift so I don't have to use the spacer lift? Will the 885's give me the 3" with shocks set at 0 or do I have to add the top plate? Thanks for any help
    TheTacoma likes this.
  3. Aug 18, 2016 at 9:39 PM
    dirtnsmores
    dirtnsmores A camping truck
    Southern California
    06 DCLB Prerunner
    OME885/5100, DAKAR MED-DUTY, SOFTOPPER
    you just need the 885s set at zero on the 5100s
  4. Aug 18, 2016 at 10:28 PM
    vrod671
    vrod671 The Okayest Member
    Brandon
    2022 TRD Sport
    Stock
    887's
    Sub-Zero and hoverlover like this.
  5. Aug 19, 2016 at 8:02 AM
    FL TRD
    Florida
    So 885 or 887 lol? Won't the 887 make the ride stiff? I don't off road with the truck so I want the 3" lift but a nice a ride if possible
  6. Aug 19, 2016 at 8:19 AM
    JWROSE4
    JWROSE4 Well-Known Member
    Jonny
    Virginia
    2013 DCSB SR5 4X4
    Work In Progress
    Im assuming your a double cab. If so then get the 887 for 3 inches of lift.
    hoverlover likes this.
  7. Aug 19, 2016 at 8:22 AM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    Double Cab, 887 gives the lift off 886 without the stiff ride supposedly. You won't get 3" with just 885. I don't have experience with bilsteins, so this info would be with nitro charger struts
    scottalot likes this.
  8. Aug 19, 2016 at 8:28 AM
    dirtnsmores
    Southern California
    06 DCLB Prerunner
    but he's prerunner it looks like. Gonna be pretty damn close to 3" with 885. Either way is a nice lift. My 885s go on next week! Went with the bilsteins
    TheTacoma and Juforrest like this.
  9. Aug 19, 2016 at 9:05 AM
    TheTacoma
    TheTacoma Well-Known Member
    Birmingham, AL
    2017 DCSB, TRD OR 4x4, Quicksand. SOS Bolt-on Sliders. 285x75r16. Kings
    Exactly, I am right at 3" on my prerunner with 885s. The 887 are the same spring rate as the 885s just 1/2" more lift.
  10. Aug 19, 2016 at 9:09 AM
    dirtnsmores
    Southern California
    06 DCLB Prerunner
    question. To install new UCAs do I have to remove the coilovers as well? My UCAs are backordered thinking about installing the shocks first since I have them and running the stock UCAs for a bit
  11. Aug 19, 2016 at 9:28 AM
    TheTacoma
    Birmingham, AL
    Nope! I installed my UCAs about 2 weeks after my lift. Took me about 30mins each side.
    Quick run through:
    1. tie the spending up, and separate the spindle from the UCA.
    2. Bend the fender so you can get the UCA bolt out.
    3.Loses and remove the UCA bolt
    4.Reinstall the UCA bold from the same direction you took it out with the new UCA.
    5.Attach the spindle to the new UCA
    6.Torque it all down.
    7.Drink a beer
    8.Get an alignment.
    dirtnsmores[QUOTED] likes this.
  12. Aug 19, 2016 at 9:31 AM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    Why does pre runner matter? Do you get that much lift without the weight of the 4wd components?
    TheTacoma[QUOTED] likes this.
  13. Aug 19, 2016 at 9:32 AM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    Why didn't you put the bolts in the opposite way they came out so you don't have to fight the fender again
  14. Aug 19, 2016 at 9:38 AM
    TheTacoma
    Birmingham, AL
    Correct.
    That way if anything just happens to come lost the bolt won't fall right out. It's way less likely to work its way back up at the angle its at. With just a small quick bend of the fender there is no problems with it.
  15. Aug 19, 2016 at 10:26 AM
    FL TRD
    Florida
    Yes I have a double cab ok so the 887 should get me to the 3" then right
  16. Aug 19, 2016 at 11:08 AM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    Here's your answer:
  17. Aug 19, 2016 at 11:49 AM
    dirtnsmores
    Southern California
    06 DCLB Prerunner
    awesome thanks. Hopefully my install of the coilovers and aal goes good this weekend!
  18. Aug 20, 2016 at 6:38 AM
    TheTacoma
    Birmingham, AL
    Good luck! Just post if you run into any problems.
  19. Aug 29, 2016 at 4:25 PM
    Hardscrabble
    Hardscrabble Well-Known Member
    Scott
    McDonough, GA
    ‘20 Sport M/T AC 4WD & '15 TRDOR DCSB 4WD
    A little of this and a little of that.
    Installed an OME lift kit on my 2011 DCSB 4WD. Full Dakars and 885 springs. LR UCA's too.
    raggedphoto and tacoma16 like this.
  20. Aug 29, 2016 at 4:27 PM
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    Well, found out what the noise is. The whole shock absorber is moving in the top hat. and binding the spring. I think the top hat is fubard. Can't see it just simply being loose as the other side has just as many threads showing. Any ideas?
    Attached a video. Hoping it's simply just the top hat and not the whole shock.
    https://youtu.be/80YyuM5gK70
