Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Dec 13, 2016 at 4:59 PM
    mutilatedjak
    mutilatedjak n00b waffle
    WA
    11 DC SB TRD Sport 6spd
    BP-51s, Dakar leafs, ARB bumper, 4xinnovations rear HC, 3x trail camera, pure android, lightforce 170s, Dick Cepek 255 85s extreme terrain.
    I just received some dakar leafs and two bags of bushings.... Now I know one is for the rear eyes of the leafs.... Is the other set used to replace the oem shackle bushings?
  2. Dec 14, 2016 at 4:10 PM
    Kylsix
    Kylsix Makin' it Hail
    Rick
    Albuquerque, NM
    '12 Mag Gray T|X Pro
    OME w/ 886s & Dakkar Leafs
    Don't take the leaf out. Toyota leafs have a 1/2" "lift" on the driver's side from the factory, no aftermarket leafs do unless you get them custom made. Just buy the , that's what I did with my OME leafs, and what a friend of mine did as well, solved the Taco Lean.
    You don't replace the OEM shackle bushings. Both ends of the leaf springs need the new bushings, so that is where they go.
  3. Dec 14, 2016 at 4:14 PM
    Jamart5
    Jamart5 HoeRunner
    Juan
    SETX
    '16 4Runner TRD
    I just ordered the shim hopefully it does the trick.
    Kylsix[QUOTED] likes this.
  4. Dec 14, 2016 at 9:28 PM
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    im curious as well, as one end of my leafs is empty for the poly bushings, the other already has a bushing in it, and ive got 4 poly bushings total, not sure where the other two go
  5. Dec 14, 2016 at 9:54 PM
    Jtaoj0
    Jtaoj0 Well-Known Member
    New dakars come with bushings installed in the front and none in the rear. Mine came with extra bushings as well. I don't see why we would pop out the new already installed fronts?
    mutilatedjak likes this.
  6. Dec 15, 2016 at 8:22 AM
    Kylsix
    Rick
    Albuquerque, NM
    Maybe something changed since I installed mine, definitely weren't any extra bushings for me.
  7. Dec 25, 2016 at 11:17 PM
    06taco4.0
    06taco4.0 Mullet Magic
    Jacob
    Washington
    2006 Tacoma v6 4.0l 4WD
    2006 Tacoma V6 4.0L 4WD Dual K&N CAI Cherry Bomb glass pack +3 inch OME coils 3/4 inch toytec spacers Deaver 1.5 inch AAL iDelta toolbox Cree LED 7.5 inch lightbars on a bullbar 33in SVT Radial Wild Country
    Ok I'm looking at upgrading my front set up. I currently have 884 coils with a 3/4 inch top plate spacer. I'm wanting to go to bilstein 5100 struts and a taller ome coil. 1st question: will 885s keep the lift even if I have an aftermarket bumper? Or should I get the 886s ?
    Second question: will I HAVE to get now UCA's? I won't be doing much off-roading due to being in college. Thanks
  8. Dec 26, 2016 at 5:46 AM
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Reformed Taco driver in a GX460
    How much lift do you want?
  9. Dec 26, 2016 at 9:11 AM
    06taco4.0
    Jacob
    Washington
    Well right now I probably have 2 inches in the front and I'm looking for three atleast
  10. Dec 26, 2016 at 9:24 AM
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Don't go over 3 with suspension. 887's will get you close to 3". 885's will get you around 2". 886's will get you around 2.5-3" without a bigass bumper the ride will be very stiff.
  11. Dec 26, 2016 at 9:31 AM
    06taco4.0
    Jacob
    Washington
    So will be ucas be a must have?
  12. Dec 26, 2016 at 9:37 AM
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    If you go 887's I would say yes, but there are people who didn't.
    06taco4.0[QUOTED] likes this.
  13. Dec 26, 2016 at 9:56 AM
    06taco4.0
    Jacob
    Washington
    Alright cool. So sometime down the road when a get a bumper, will the 885s still hold up?
  14. Dec 26, 2016 at 12:03 PM
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Depends, aluminum maybe, steel you would lose lift. 886's are the best for steel.
  15. Dec 29, 2016 at 8:53 AM
    DrewDown
    DrewDown Well-Known Member
    Tucson, AZ
    2014 Double Cab Short Bed
    Looking to order my OME kit today. Just looking to do an AAL in the rear. Seems like a lot of vendors only sell the kit with the Dakar leaf pack which will sit too high for my needs. I also want to order the front coil and strut pre-assembled so I don't have to mess with a spring compressor. Toytec has it in stock for $1000 shipped.
    90021 front shocks
    885 front coils
    top plate spacers
    Assembled front coilovers with new hardware option
    Toytec AAL
    as configured $963.17
    Any reason I shouldn't go ahead and place my order? Truck is bone stock but I have wheels and tires on order. I don't 4 wheel for the sake of climbing over stuff but camp regularly. Most of my camping involves pulling a pop-up trailer. I hope to purchase a slide in camper in about a year, at which point I plan on switching to a beefier rear leaf pack, and since I won't be towing any more I will have a chance to get farther away from people (which means worse roads). Truck sees a lot of on pavement road trips as well so I would like to keep the drive-ability a priority. Any added insight would be appreciated. Thanks
  16. Dec 29, 2016 at 9:00 AM
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    @HeadStrong Off-Road has same thing with progressive aal for 989 shipped.
  17. Dec 29, 2016 at 9:02 AM
    DrewDown
    Tucson, AZ
    Does that include assembly? Will I need anything else like the shim for this taco lean I'm reading about?
  18. Dec 29, 2016 at 9:07 AM
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Yes
  19. Dec 29, 2016 at 9:08 AM
    DavidMietzner
    DavidMietzner Well-Known Member
    David
  20. Dec 29, 2016 at 9:13 AM
    Toytec Lifts
    Toytec Lifts Toyota Suspension specialist
    Rocky Mountains
    Toyota's are awesome
    We have everything in stock and can get the order shipped out immediately.
    We can ship to your door that full kit for $974.16. PM or give us a call here 303-255-4959
    -Justin
    Bannerman and DavidMietzner like this.
