Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Apr 14, 2017 at 12:34 PM
    la0d0g
    running for the hills
    For crawling not hauling
    Depending on how much weight you're going to put up front you might want to look at 886s.
  2. Apr 14, 2017 at 12:45 PM
    GORUCKtaco506
    GORUCKtaco506 Well-Known Member
    Glenn
    Orange County, Ca
    2016 TRD Sport 4x4 DCLB Super White
    ARE cx shell with windoors, carpeted sleeping platform, red LED map lights, LED vanity lights, tailgate vinyl inserts, glove box vinyl inserts, dog ramp, blacked front grill and white emblem, blacked badges, debadged tailgate.
    All I'm planning on is a bumper, most likely aluminum but possibly steel. I'm leaning towards Pelfreybilt but that's a ways down the road. It'll be the stock one for a while, no winch
  3. Apr 14, 2017 at 12:46 PM
    la0d0g
    888s or 885s will do then.
  4. Apr 14, 2017 at 2:13 PM
    GORUCKtaco506
    Glenn
    Orange County, Ca
    Ok, cool. Thanks for the info. What tire size would you recommend with that set up?
  5. Apr 14, 2017 at 2:23 PM
    la0d0g
    255s if you don't want to cut. 285s if you do. 315s if you want to cut even more. :)
  6. Apr 14, 2017 at 2:23 PM
    cappsinc
    cappsinc Active Member
    '15 TRD Sport DCLB 4x4
    Stressing my stock suspension so it's time for an upgrade.
    Considering the OME 885 nitro charger and full Dakar leaf kit to support my constant 720# payload.
    Will the Dakars support the 720# payload?
    Will the 2" 885s level out the front with the Dakars in the rear supporting the 720#?
  7. Apr 14, 2017 at 3:24 PM
    GORUCKtaco506
    Glenn
    Orange County, Ca
    255 it is haha, thanks
    la0d0g[QUOTED] likes this.
  8. Apr 14, 2017 at 3:26 PM
    Tacotruck7
    Tacotruck7 Well-Known Member
    SoCal
    04 Prerunner Dbl Cab 2.7L
    So I have 882's I got used up front on my double cab four banger. They gave me too much lift. I'm thinking of going down to 881's. Will this level my truck out? Right now I'm a little higher up front.
    I'm currently running Nitro's all around. Dakar Leaf Pack. 882's up front.
  9. Apr 15, 2017 at 5:39 AM
    MadRiverTaco
    MadRiverTaco Join TW, they said. It's free, they said.
    Brenden
    Waterbury, VT
    2012 Black DCSB TRD OR "Caroline"
    King 2.5 Ext. w/ Compression Adjusters (Front & Rear), Dakars w/ D29XL, TC UCA's & LCA's, ARE CX, 17" SEMA Pro's, 265/70/17 Falken Wildpeaks, BORA spacers, Rigid Side shooter ditch lights, ATHF bedside reinforcements, OME carrier bearing drop bracket, extended rear brake lines, Northstar 27F battery, Yakima Jetsream crossbars, OEM roof rack, OEM skid plate, TRD Pro grill, URD TCAI, 5.7L Throttle Body, BensonX bedside tool mounts, fire extinguisher bedside mount, AMP research bed step, Redline Tuning hood struts, ECGS needle bearing mod, CV Boot slide mod, Differential breather mod, U-Bolt Flip Kit w/ Timbren Bumpstops, A-pillar RAM mount w/ cell phone holder, ProFX tow mirrors with turn signals and heat, "Raptor" lights, DEPO taillights, motorized Pop n' Lock
    The full Dakar pack will support the load and for a DC 4x4 they net about 2.75" of lift. So 885s won't get you level. You'll need 887s for that plan. But would you not want to maintain some rake?
  10. Apr 16, 2017 at 6:36 AM
    cappsinc
    Thanks. I do like the stock 1" - 1.5" rake so yes some rake is fine with me.
    OME says 2.75" - 3" out of the Dakar cs047r then the added d29xl leaf adds roughly 1/2"
    Looks like the 885 and 887 are both 590# springs so the only difference is the length. So both could work for me depending on what I get out of the Dakar cs047r and d29xl leaf carrying this load.
    If I pull the trigger on the OME set I'll get both sets of springs just in case
  11. Apr 16, 2017 at 7:08 AM
    MadRiverTaco
    Brenden
    Waterbury, VT
    You'll get anywhere from 3.5 - 4" with the Dakars and D29XL leaf so yes, rake will be maintained with this setup. If you're on the fence with both springs, just get the 887s. Both will settle and it sounds like you're set on having 3" up front.
  12. Apr 16, 2017 at 8:21 AM
    cappsinc
    I'm not set on having 3" in the front. I'm on the fence between the two springs because I'm unsure on how the Dakar+D29xl leafs are going to sit with the 720# payload. No load produces 3.5" per OME. With the load, I don't know. I'd prefer a 2" set up all the way around to avoid issues with other parts (UCAs, ecgs) however, the rear set up with the Dakars is dictating what I do to the fronts. That's where my question sits, between the 885s and the 887s.
  13. Apr 16, 2017 at 8:31 AM
    MadRiverTaco
    Brenden
    Waterbury, VT
    Then omit the AAL and just do the Dakars out back with 885s in the front. That will give you about 1" of rake. If you do go with the Dakars + AAL you will most certainly need the 887s or it will look awkward with the ass end way up. 887s with Dakars will get the truck fairly level. There are threads dedicated to each set up that gives you an idea of what to expect.
  14. Apr 16, 2017 at 8:32 AM
    cappsinc
    Thanks for the feedback
    MadRiverTaco[QUOTED] likes this.
  15. Apr 16, 2017 at 9:30 AM
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Reformed Taco driver in a GX460
    You can remove the long overload spring from the Dakar pack without reducing the load capacity. If you have 720# all the time go with the add a leaf in the pack and 887's. You may even want to go with 888's. (Yes they will fit and will be closer to 3" than 887's)
  16. Apr 16, 2017 at 9:41 AM
    cappsinc
    Thanks
    I checked out your set up. Looks great! I also have a DCLB 4x4. How's that BP-51 set up? Are you running 275s?
    I'm picturing that on mine
  17. Apr 16, 2017 at 9:44 AM
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    285's. They are very nice. My only complaint is crawling into the wheel well to adjust the comp and rebound. Dont need to do it unless I change stuff but I am constantly changing things.
  18. Apr 16, 2017 at 3:24 PM
    Broverlanding
    Broverlanding Well-Known Member
    Grant
    St. Augustine, Fl
    2016 TRD OR
    CBI all the things BP51 Shadow Awn - Custom bed rack
  19. Apr 16, 2017 at 5:31 PM
    cuda2k
    cuda2k Well-Known Member
    Jon
    Allen, TX
    BRM 15 TRD Off Road 4wd
    LVL8 MK6 wheels,SOS Sliders,Smked 3rd Brake,Gibson Exhaust
    Newb question of the day, gonna ask it here since I'm working with an OME setup - due to an issue with my Dakars I won't be able to install those for a week or so - should I wait till then to have the alignment done so the truck is sitting level / intended rake instead of the bro-lean I've got going now (tail saggin). Not sure how they measure caster, so with the truck at a significantly different angle than it'll be sitting normally wondering if that'll throw it off.
  20. Apr 18, 2017 at 9:14 AM
    upTOPOverland_Drew
    upTOPOverland_Drew upTOP Overland Technical Design and Application
    Drew
    Littleton, CO
    2017 TRD OR DCSB SUPER WHITE
    All the things...click the link in sig
    TOTAL NOOB TO SUSPENSION! HELP!
    I have a 2017 TRD OR DCSB and am looking at doing a small lift here towards the end of the year. My requirements and details are as follows:
    • I want only approximately 2" of lift, even a little less is okay. I also want to fix my taco lean.
    • I will likely be putting 265/75/R16s on because this is a daily driver that sees 40 highway miles per day for my work commute.
    • I will be adding a Leer 100XR and a DIY Drawer system and plan on adding full aluminum RCI skids and also their sliders. All in all I am thinking these items will amount to around a 500# constant load.
    At this point I am thinking I will be doing with the 887 coils, 90021 shocks and the standard dakar leaf pack, not adding or removing a leaf.
    • Do you think I am making the right decision?
    • Will I need UCAs? If so, what do y'all recommend?
    • Do you guys recommend I do the front diff drop or ECGS or both?
    • Are extended brake lines necessary?
    • What else do I need or do you recommend?
    Thanks in advance!
    baileybrandon likes this.
