Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Apr 26, 2017 at 4:35 AM
    dgb1179
    dgb1179 Member
    Raleigh, NC
    2008 TRD Sport 4x4 DCLB
    Anyone happen to know approximate stock measurement hub to fender on 2nd gen TED sport? Forgot to take measurement before installation and am curious about how much lift I ended up with.
  2. Apr 26, 2017 at 4:47 AM
    MadRiverTaco
    MadRiverTaco Join TW, they said. It's free, they said.
    Brenden
    Waterbury, VT
    2012 Black DCSB TRD OR "Caroline"
    King 2.5 Ext. w/ Compression Adjusters (Front & Rear), Dakars w/ D29XL, TC UCA's & LCA's, ARE CX, 17" SEMA Pro's, 265/70/17 Falken Wildpeaks, BORA spacers, Rigid Side shooter ditch lights, ATHF bedside reinforcements, OME carrier bearing drop bracket, extended rear brake lines, Northstar 27F battery, Yakima Jetsream crossbars, OEM roof rack, OEM skid plate, TRD Pro grill, URD TCAI, 5.7L Throttle Body, BensonX bedside tool mounts, fire extinguisher bedside mount, AMP research bed step, Redline Tuning hood struts, ECGS needle bearing mod, CV Boot slide mod, Differential breather mod, U-Bolt Flip Kit w/ Timbren Bumpstops, A-pillar RAM mount w/ cell phone holder, ProFX tow mirrors with turn signals and heat, "Raptor" lights, DEPO taillights, motorized Pop n' Lock
    It should be:
    LF RF
    20" 20.5"
    LR RR
    21" 21"
    What did you install and when?
  3. Apr 26, 2017 at 5:45 AM
    dgb1179
    dgb1179 Member
    Raleigh, NC
    Installed OME 885s with the 10mm top plate spacers, trim packer for driver side, and dakars. Had it installed last Saturday.
  4. Apr 26, 2017 at 5:51 AM
    MadRiverTaco
    Brenden
    Waterbury, VT
    I'm confused. So you have 15 mm in top plate spacers (2 plates) on the driver side, and 10 mm on the passenger side?
  5. Apr 26, 2017 at 5:52 AM
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    Subbed for near future.
    Will be putting on OME 885/90000, with driver's side spacer pre-installed, (+/- 60k miles on them) on the front; and 5100s (5k miles) with Deaver AAL (brand new) in the rear.
    No armor, yet. Or any other weight gainers
  6. Apr 26, 2017 at 6:21 PM
    dgb1179
    dgb1179 Member
    Raleigh, NC
    So I am admittedly a bit of a noob, but according to Wheelers Offroad where I purchased the lift, the 5mm trim packer is installed under the spring seat on the strut. I had the coils pre-assemled from Wheelers and the trim packer was included in the assembly. The spacers are on the top plates. So effectively, yes, I have 15mm additonal on the driver side and 10mm on the passenger. Also installed the + leaf springs on the driver side. This was to eliminate the "taco lean".
  7. Apr 26, 2017 at 7:15 PM
    la0d0g
    running for the hills
    For crawling not hauling
    You done right.
  8. Apr 27, 2017 at 4:08 AM
    MadRiverTaco
    Brenden
    Waterbury, VT
    Oh I see. I was envisioning just two top plate spacers stacked on one side. Post up some pics of your truck!
  9. Apr 27, 2017 at 9:30 AM
    raggedphoto
    raggedphoto Well-Known Member
    Oregon
    DCSB 07 Desert Sand Mica
    For long haul vs short crawl
    Just wanted to update you guys on this. The folks at Toytec are super awesome and sending me all new parts, got to love great customer service!
    la0d0g likes this.
  10. Apr 27, 2017 at 9:33 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    You "might" want to get some UCAs.
    ChadsPride likes this.
  11. Apr 27, 2017 at 10:19 AM
    dirty deeds
    Nick
    Eastern KY
    Might. Might not.
    An alignment will determine that. Not the internet.
  12. Apr 27, 2017 at 10:22 AM
    ChadsPride
    Sponsored by TacomaWorld.com
  13. Apr 27, 2017 at 10:24 AM
    dirty deeds
    Nick
    Eastern KY
    Troof. I've heard about 50/50 that I do, or don't, need UCAs. Only an alignment will reveal the answer.
  14. Apr 27, 2017 at 10:26 AM
    ChadsPride
    I want UCA's and dont even need em
    Thanks TacomaWorld! :bananadead:
    Juforrest and dirty deeds like this.
  15. Apr 27, 2017 at 10:44 AM
    T4RFTMFW
    Hence the "might" part. :rolleyes:
    You'll be upwards of 2.5-2.75" in front, same as I was. I was fine with tire wear and street behavior, but it did drive a little skittish. Our trucks weigh about the same, so your lift is gonna be almost identical.
  16. Apr 27, 2017 at 11:31 AM
    CenCal805
    CenCal805 Well-Known Member
    California
    2016 Tacoma TRD OR AC
    So, I'm just about install full leaf pack + D29xl and 6112 on the front and I've been curios if I need UCA. Before you bash me, I am new to all of this. Yes, I've spent hours in the suspension forum and still haven't seen a definitive answer. How will an alignment determine if you need UCA? What should I look for as the determining factor on the print out from the alignment?
  17. Apr 27, 2017 at 11:34 AM
    T4RFTMFW
    Caster.
    Also the rear suspension setup really doesn't make a difference on UCAs. You setting the 6112s will.
    If you crank them to all hell then you'll likely need them, if you don't, you likely wont.
    CenCal805[QUOTED] and ChadsPride like this.
  18. Apr 27, 2017 at 11:36 AM
    CenCal805
    California
    Gotcha, thanks for answering. I'll do some more reading about alignments measurements and terms. I'm hoping I don't need to set them too high to get a slight rake or level.
  19. Apr 27, 2017 at 11:37 AM
    T4RFTMFW
    What kind of added weight do you have on the rear of your truck?
  20. Apr 27, 2017 at 11:37 AM
    ChadsPride
    Couple thick chicks, why you askin?​
