Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Apr 27, 2017 at 11:38 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    I like thickies.
    ChadsPride[QUOTED] likes this.
  2. Apr 27, 2017 at 11:38 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    Samsies, moar bettur. ​
  3. Apr 27, 2017 at 11:39 AM
    CenCal805
    CenCal805 Well-Known Member
    California
    2016 Tacoma TRD OR AC
    A.R.E. MX shell, DIY sleeping platform w/ drawer system, surfboards and camping gear that stays loaded. 600-700# constant load is my guess.
    ChadsPride and T4RFTMFW[QUOTED] like this.
  4. Apr 27, 2017 at 11:41 AM
    T4RFTMFW
    Hefty.
    I think I lost 3/4" or so with that load and the standard Dakar pack (no AAL). So you'd probably only lose 1/2" or so? Can't remember offhand what the AAL adds in height.
    ChadsPride and CenCal805 like this.
  5. Apr 27, 2017 at 11:41 AM
    T4RFTMFW
    I'd assume for level look you'd be cranking them pretty high, especially if you have added weight up front.
    CenCal805 and ChadsPride like this.
  6. Apr 27, 2017 at 11:47 AM
    CenCal805
    California
    No added weight up front other than RCI Skid.. I'm getting my BAMF sliders tomorrow. You think they will have much impact on the front?
    Truthfully, I've spend so much money lately, I might as well just get some UCAs and be done with it.. I'm fairly certain I've spent more time on this site that working lately. Crazy, this damn site has cost me a fortune. Both in time and money. Good times!
    Sna, JWROSE4 and ChadsPride like this.
  7. Apr 27, 2017 at 11:48 AM
    T4RFTMFW
    I never had sliders, so can only speak from others experiences - but yes.
    Sliders are heavy as fuck, 160 lbs-180 lbs right? How much are yours?
    ChadsPride and CenCal805[QUOTED] like this.
  8. Apr 27, 2017 at 11:51 AM
    MadRiverTaco
    MadRiverTaco Join TW, they said. It's free, they said.
    Brenden
    Waterbury, VT
    2012 Black DCSB TRD OR "Caroline"
    King 2.5 Ext. w/ Compression Adjusters (Front & Rear), Dakars w/ D29XL, TC UCA's & LCA's, ARE CX, 17" SEMA Pro's, 265/70/17 Falken Wildpeaks, BORA spacers, Rigid Side shooter ditch lights, ATHF bedside reinforcements, OME carrier bearing drop bracket, extended rear brake lines, Northstar 27F battery, Yakima Jetsream crossbars, OEM roof rack, OEM skid plate, TRD Pro grill, URD TCAI, 5.7L Throttle Body, BensonX bedside tool mounts, fire extinguisher bedside mount, AMP research bed step, Redline Tuning hood struts, ECGS needle bearing mod, CV Boot slide mod, Differential breather mod, U-Bolt Flip Kit w/ Timbren Bumpstops, A-pillar RAM mount w/ cell phone holder, ProFX tow mirrors with turn signals and heat, "Raptor" lights, DEPO taillights, motorized Pop n' Lock
    Both a gift and a curse
  9. Apr 27, 2017 at 11:51 AM
    CenCal805
    California
    You are right on the money.. 165#.
    ChadsPride likes this.
  10. Apr 27, 2017 at 11:52 AM
    T4RFTMFW
    Have someone 165 lbs sit in the cab and see what it drops. I would venture its probably 1/2" on stock suspension with the skid.
  11. Apr 27, 2017 at 11:56 AM
    CenCal805
    California
    Good point! Looks like I'm gonna have to crank those 6112s up and get UCAs. Hopefully have this done withing the next 2 weeks. I'm doing all the work myself to learn, so I'm sure it will take longer than what it would take most. Good thing I have a beater Civic to drive to work while my truck sits disassembled in the garage for days and days.
  12. Apr 27, 2017 at 11:58 AM
    T4RFTMFW
    Out of curiosity can you upgrade the coils on 6112s?
  13. Apr 27, 2017 at 12:00 PM
    CenCal805
    California
    Yeah, I think you can.. I remember reading that some guys went with 650# and others went with 700# coils instead of what comes with the 6112s. I'm fairly certain it was guys with plate bumpers.
  14. Apr 27, 2017 at 12:03 PM
    T4RFTMFW
    Yeah I wouldn't go that high for your setup.
    650 should be good though, I was figuring they come with 600s but 650s should save you a few cranks.
    Interested to see how it all sits.
    @Pirhett is doing an LR UCA group buy pretty soon, if you're in the market.
  15. Apr 27, 2017 at 12:09 PM
    CenCal805
    California
    I'm not sure what # springs they come with.. I'm looking on the website now and it doesn't say anything about lbs rating. All it says is
    • Custom engineered cold wound linear springs for enhanced vehicle control
    I think when I read that guys went to either 650# or 700# springs, that they were upgrading to those.
    Now, I need to find out what comes standard with the 6112s...
  16. Apr 27, 2017 at 3:19 PM
    Sna
    Sna Well-Known Member
    Alberta
    ‘15 trd sport 6MT dcsb, mostly stock?
    As mentioned, yes you can. Eibach has 14" coils for the size of the 6112's.
    I am currently trying to decided which to go with....driving me nuts actually.
    6112's come with 14" 600# coils. The Eibach 14" 650# or 700# are used to carry the extra weight of plate bumpers, winches skids, etc. They're the same length as the ones that come with the 6112's but have higher springs rates so they sag less with the additional weight.
  17. Apr 27, 2017 at 3:25 PM
    Sna
    Alberta
    I decided to just get the damn UCA's as part of my suspension plan since I'm going to have everything apart and I didn't want to do it again. Extra cost but I will be able to get the alignment numbers I want.
    My plan was to set the 6112's to the 4th notch (2.15" per Bilstein but people get close to 2.5") with the coils that come with them but now that I am going with a aluminum plate bumper, winch, aluminum skids and steel sliders I will be using either 650# or 700# coils probably set to the 3rd notch since they will not sag as much as the 600# coils. I am hoping this will get me close to the 2.5" of lift I want.
    CenCal805[QUOTED] likes this.
  18. Apr 27, 2017 at 3:39 PM
    la0d0g
    running for the hills
    For crawling not hauling
    Confused. Why would you set them up a notch instead of using the could to lift?
  19. Apr 27, 2017 at 3:42 PM
    CenCal805
    California
    Thanks for all the info! You've just settled it for me, I'm getting the damn UCA's now too. Do it right the first time and buy once, cry once. Now, just to decide on which ones. I guess Total Chaos is what most people run, so I'll start there. As far as the springs, it's going to be tough to know if I should upgrade. I guess I'll be driven nuts trying to decide too. Dammit!
    Sna[QUOTED] likes this.
  20. Apr 27, 2017 at 3:43 PM
    Sna
    Alberta
    Not sure I understand what you're saying....looks like autocorrect or typo.
    No extra weight the 6112's would be set to the 4th notch (2nd highest setting) but with the extra weight and 650 or 700 coils they will probably be set to the 3rd notch since the coils will not sag as much. I would rather do this than increase the preload on the coils.
