Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. May 22, 2017 at 11:33 AM
    la0d0g
    running for the hills
    For crawling not hauling
    Over speed bump goes clunk.
  2. May 22, 2017 at 11:34 AM
    la0d0g
    :fistbump:
  3. May 22, 2017 at 11:36 AM
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
  4. May 22, 2017 at 11:36 AM
    dirty deeds
    Nick
    Eastern KY
    More worried about off road performance now.
  5. May 22, 2017 at 11:57 AM
    la0d0g
    Do you like high speed or creepy crawly stuff?
    dirty deeds[QUOTED] likes this.
  6. May 22, 2017 at 12:15 PM
    dirty deeds
    Nick
    Eastern KY
    Both
  7. May 22, 2017 at 12:52 PM
    la0d0g
    I find that OME is better suited to slower stuff. Need them bling bling shocks for the fast stuff.
    I'm only somewhat kidding :D
  8. May 22, 2017 at 1:26 PM
    dirty deeds
    Nick
    Eastern KY
    Well, I was always told, "If it's yellow, might as well be pink." So...
    Very hard for me to not spray paint the OME shocks
    la0d0g[QUOTED] likes this.
  9. May 22, 2017 at 1:56 PM
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    I got a set of OME Rear Shocks from a local TW Member and ended up spray painting them black lol
  10. May 22, 2017 at 2:05 PM
    Sna
    Sna Well-Known Member
    Alberta
    ‘15 trd sport 6MT dcsb, mostly stock?
    This is why I decided to go with 6112's over the OME kit.
  11. May 23, 2017 at 2:14 PM
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    Okay. Finally installed my kit a few weeks ago, stock Dakar pack out back and 885's up front, OME shocks all around. I have the leaf packs with the anti-noise kit. Only vibes I'm getting are a small shudder at takeoff, and possibly some low speed vibes to about 20ish mph. I did not put the carrier bearing spacer in yet. Think that will fix it?
    greeneggsnspam likes this.
  12. May 23, 2017 at 2:15 PM
    la0d0g
    There's one sure way to find out.
    dirty deeds and scottalot like this.
  13. May 23, 2017 at 2:17 PM
    Gaunt596
    Matthew
    Central Maryland
    Yup. Planning on installing once I get home today, just wanted to consult the hive first
    la0d0g[QUOTED] and scottalot like this.
  14. May 23, 2017 at 4:28 PM
    4WDTrout
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    Off the top of your head, can anyone tell me if I'm going to have to or "should" replace my u-bolts if I plan to replace my Dakar bushings?
  15. May 23, 2017 at 6:00 PM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
    I didn't bother with it. But I haven't really felt any vibes. Probably because our roads are shit and I couldn't tell if I'm hitting a pot hole or my wheel is about to fall off.
    Put it in and give it a go. Report back your findings.
    la0d0g and dirty deeds like this.
  16. May 24, 2017 at 3:33 AM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    I had the shudder from takeoff after lift. Installed 3 degree axle shim and flushed transmission at the same time and filled to proper level. It's about 95% gone. No other shudder at any speed.
    Sna likes this.
  17. May 24, 2017 at 6:19 AM
    la0d0g
    I think you're supposed to replace them any time you undo them. I have followed this rule with my Tacoma but not with my 85. I have those things off and on all the time. I torque them to spec and they're fine. So I'm not sure :D
  18. May 24, 2017 at 6:21 AM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Maybe if they're old you should replace them.
    Maybe > 6 months, probably not. 2 years +, sure why not.
    dirty deeds and la0d0g like this.
  19. May 24, 2017 at 6:47 AM
    dirty deeds
    Nick
    Eastern KY
    I didn't replace mine this past weekend when I put on the Deaver AALs. But they looked to be in great shape and little, if any, stretch in the threads.
    All bolts/nuts were torqued to impact gun strength :D
  20. May 24, 2017 at 6:57 AM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    :bananadead:
