Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Jun 13, 2017 at 9:34 AM
    Age315
    Age315 Well-Known Member
    AJ
    Castle Rock, CO
    2016 BBP Yeti Mobile
    TRD Baja Kit with JBA UCA's 1/2 inch spacer on top, Medium Dakars with BAMF hangars and super bumps all around. 285/75/16 Cooper Discoverer AT3 XLT's on graphite TRD faux beadlock wheels. Pro skid powder coated black with Pelfreybilt aluminum mid skid and aluminum gas tank skid.
    Question for you, did you buy the 6112's with the upgraded springs or did you buy the springs separate? I'm looking to get about 3 inches of lift but don't want to preload the spring at all if possible. I would consider the 6112 with a stiffer spring at a lower setting but would be concerned about the ride. How is yours riding with it set where it's at now?
  2. Jun 13, 2017 at 4:07 PM
    Sna
    Sna Well-Known Member
    Alberta
    ‘15 trd sport 6MT dcsb, mostly stock?
    The Eibach 650# springs were bought separately. You may need to buy 700# springs if you do not want to run any preload but even at that I'm not sure you'd get 3" and the ride would most likely be crappy. My ride is great (I assume it will be fine one lower on the 3rd notch too) and I bomb up my driveway curb and can barely feel it.
  3. Jun 13, 2017 at 4:11 PM
    Age315
    AJ
    Castle Rock, CO
    Thanks for letting me know.
  4. Jun 13, 2017 at 8:08 PM
    Sna
    Alberta
    I also have noticed a slight shudder when I accelerate from a stop but it goes away very quickly. I have a 3* shim on the axle and the OME carrier bearing drop. Any ideas? @OZ-T
  5. Jun 13, 2017 at 8:39 PM
    la0d0g
    running for the hills
    For crawling not hauling
    Did you put them on before checking if you had vibes? They're not mandatory; better used after establishing you actually have vibrations. And then not adding them at the same time.
    greeneggsnspam likes this.
  6. Jun 13, 2017 at 9:12 PM
    Sna
    Alberta
    I put them in at the same time because from the reading I've done, they were a good thing to do after a lift. I only have the very brief takeoff shudder and haven't noticed any other vibrations.
  7. Jun 14, 2017 at 5:05 AM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
    Maybe if you add all that weight in the photo on to the 885s, you get back to the stock height?
    :notsure:
    But they could just mean coil rate for a stock/non-armored vehicle. I'm not too sure, but this seems pretty likely.
    la0d0g[QUOTED] likes this.
  8. Jun 14, 2017 at 5:16 AM
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Reformed Taco driver in a GX460
    You need to check the working angles of your ujoints. You can download inclinometer app. I think they are supposed to be 1 degree different.
    Sna[QUOTED] likes this.
  9. Jun 14, 2017 at 6:51 AM
    la0d0g
    Still doesn't make sense to me when the 885s and 888s have the same rating. Maybe they are talking height. Fucks me o_O
  10. Jun 14, 2017 at 8:31 AM
    saundern
    saundern Swerve for nothing
    Nick
    Simpsonville, SC
    2005 TRD Sport
    Decided to go with Headstrong and this kit. Let me know what ya'll think and if I need to add anything.
    Coils: 886 x2
    Struts: OME 90000 Firm Struts x2
    Trim Packer for driver side lean
    OME 60091 Nitrocharger Sport rear shocks x2
    Headstrong's Progressive 3-leaf AAL with U-bolts
    OME driveshaft spacer to correct vibration (ordered from another site)
    Should I get new strut mounts while i'm at it also?
  11. Jun 14, 2017 at 10:40 AM
    1BDTACO
    1BDTACO Well-Known Member
    Joe
    North Dakota
    2017 Tacoma TRD OR
    OME Medium Lift, Fx Pro wheels, Falken at3 285/70/17
    888 have are a taller spring to start with. Maybe that's what's messing ya up haha
  12. Jun 14, 2017 at 11:05 AM
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    How many miles are on your truck?
  13. Jun 14, 2017 at 11:05 AM
    la0d0g
    Don't immediately install the carrier bearing drop, sometimes its not needed.
    Edit: Doh
    I'm aware of that thus my initial question.
  14. Jun 14, 2017 at 11:06 AM
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    If you get new mounts might as well get the assembly service. It will save a bunch of time.
  15. Jun 14, 2017 at 11:13 AM
    saundern
    Nick
    Simpsonville, SC
    2005 TRD Sport
    120,xxx
    http://m.autozone.com/suspension-st...rut-mount-front/279553_726713_12162?location=
    How would I know if I need a carrier beating drop?
    I was planning to get them assembled since I don't want to deal with a coil compressor.
  16. Jun 14, 2017 at 11:15 AM
    la0d0g
    You don't have to use a coil compressor, you can use the weight of the truck to assemble them, but agreed that spending a few extra bucks makes the install that much quicker.
    saundern[QUOTED] likes this.
  17. Jun 14, 2017 at 11:57 AM
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    You will have driveshaft vibrations you can feel. You would need to pull the bushings out of yours. I think they are included in the assembly fee from headstrong.
  18. Jun 14, 2017 at 12:03 PM
    saundern
    Nick
    Simpsonville, SC
    2005 TRD Sport
    Replace the bushings for the leaf pack?
  19. Jun 14, 2017 at 12:11 PM
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    The strut top. It has a bushing in it. It can wear out. I meant to separate those sentences. The vibes usually occur at low speed/take off. The best advice is to put it all together and drive it. If you feel vibes check the working angles of your ujoints. They need to be close to 1degree of difference. At zero they don't work right and over 1-1.5 they vibrate/don't work right. The ujoint directly behind Trans needs to be .5-1 I believe. There is a video floating around that has all the tech spec in it and how to measure.
  20. Jun 14, 2017 at 12:22 PM
    Sna
    Alberta
    Once the front of my truck is figured out I may play with the CB spacer. It's in there now but the only vibes I'm getting is a very quick shudder when I start from a stop (5-8mph). Not sure that the CB drop would cause this though.
