Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Jul 12, 2017 at 7:57 PM
    la0d0g
    running for the hills
    For crawling not hauling
    Tis true. I get why everyone is on headstrong's nuts, they serve our community well and try to help out all the time which is great. I just prefer to spend my tax dollars else where. It's like the walmart convo, oh well.
  2. Jul 21, 2017 at 9:05 PM
    Sil
    Sil Of the Earth
    Georgia
    2017 Tacoma SR MGM i4 5 speed 4x4 aka. Vulcan
    Pending..
    Long term question. Are any of you noticing a fair amount of rust on your OME components? I have seen some for sell(used) with a lot of rust on both spring and shock. It could have been surface rust, but just wanted to ask.
  3. Jul 22, 2017 at 9:56 PM
    raggedphoto
    raggedphoto Well-Known Member
    Oregon
    DCSB 07 Desert Sand Mica
    For long haul vs short crawl
    Mine after a year showed a lot of rust on the shock body but none on the springs. Mostly its where rocks get kicked up or the plastic dust boot scraps against the side, doesn't seem to effect much other then appearance.
    Sil[QUOTED] likes this.
  4. Jul 23, 2017 at 5:46 AM
    dziner
    dziner Well-Known Member
    Jonathan
    Harrisburg, Pennsylvania
    2014 Toyota Tacoma TRD Off-Road
    Bilstein 5100 (front) | OME 885 springs | Bilstein 5160 (rear) | OME Dakar medium leafpack | JBA UCA | Cooper S/T Maxx 265/75 R16 | ARE Z-Series topper | Renogy 100W solar panel | SnoMaster TR42 fridge | sleeping platform | Mobtown sliders | Custom Car Grills grill insert
    I'm struggling with choosing between the Light Duty and Heavy Duty Dakar leaf pack for me 2014 Tacoma. I have Bilstein 5100's and OME 885 up front which provides a nice amount of lift up front. But my Wheeler's AAL and 5100's in the back are not cutting it. I've calculated around 387 lbs. of weight in the bed with the following: ARE Z-series cap, Yakima bars and towers, fridge, tent, cot, skottle, camp chairs and sleeping bags. That gear is in my truck 95% of the time. Adding additional camp food and gear, I'd estimate a top weight of 487 lbs. And I haven't decided yet if I want to add a Mobtown rear plate bumper with swing out.
    I'm leaning towards the heavy duty and wondering if others would agree or disagree with that choice.
    I'm also pondering what shock would best match my needs. Leaning towards the Bilstein 5160 when comparing to the 5100 extended, Fox 2.0, and Icon 2.0 extended shocks.
  5. Jul 23, 2017 at 10:20 AM
    JWROSE4
    JWROSE4 Well-Known Member
    Jonny
    Virginia
    2013 DCSB SR5 4X4
    Work In Progress
    Dont know how soon your trying to make the swap, but I just ordered mine from @HeadStrong Off-Road the other day. This is what I ran into. I wanted the HD pack to make sure I am good and if I need more down the road I can just add the AAL and make it heavier duty. Then it turns out the ARB is behind and the HD packs are on backorder till August or September cant remember exactly, but here is what I finally figured out anf I kinda like it since I can just add as I go and need it. The HD pack is the LD pack with an AAL and then you have an HD pack. Then down the road I will just add another AAL to make it an heavier duty pack if needed. I thought they were just two different packs and down the road I would have to buy another set of packs to get the HD if I wanted them. Marie helped me understand that they were the same pack just adding AAL's is the difference. So the long winded answer order the LD and if its not cutting it add a AAL or do like I did order the LD and AAL from the get go and put it together yourself to make the HD so you dont have to wait for the backorder mess. Hope this helps.
  6. Jul 23, 2017 at 11:03 AM
    PNWTacoma
    PNWTacoma Well-Known Member
    Paul
    PDX 3rd party OV Tuner
    2025 TRD Pro | Mudbath // 2017 Offroad DCLB OG
    PNW Adventures & PNW Tuning
    Just ordered my LD Dakar pack today and can't wait to get them installed. I ordered their "Dakar package" but do you know if I need to buy anything else like U bolts, etc? TIA
    HeadStrong Off-Road likes this.
  7. Jul 23, 2017 at 12:04 PM
    JWROSE4
    Jonny
    Virginia
    2013 DCSB SR5 4X4
    Work In Progress
    You really should get new u bolts whenever swapping packs...technically i believe everytime you take them off your supposed to use new bolts
    PNWTacoma[QUOTED] likes this.
  8. Jul 23, 2017 at 3:26 PM
    dziner
    Jonathan
    Thanks. That kinda makes sense. I'll probably have to call HeadStrong anyway so I'll have them run me through the packages. What shocks are you going to run with the Dakars?
    JWROSE4[QUOTED] likes this.
  9. Jul 23, 2017 at 10:07 PM
    JWROSE4
    Jonny
    Virginia
    2013 DCSB SR5 4X4
    Work In Progress
    The 5100's
  10. Jul 24, 2017 at 3:32 AM
    dziner
    Jonathan
    I was told 5100's are not long enough for Dakars, unless they are the extended length 5100s.
  11. Jul 24, 2017 at 6:52 AM
    la0d0g
    They will limit droop. I have extenders on mine and they work alright.
    dziner[QUOTED] likes this.
  12. Jul 24, 2017 at 8:35 AM
    schnob
    schnob Well-Known Member
    Sebastian
    2005 Silver Tacoma, TRD Sport, Access Cab
    ARB bumper with fogs, OME heavy lift kit
    So I've had my OME "Heavy sport kit" with 886s, nitrochargers and dakars installed since March. It's been settling pretty nicely however I've noticed recently that my driver side rear distance from hub to fender is about two inches less than the distance on the passenger side. This is strange because the distances are basically the same between sides in the front and I keep most of my weight on the passenger side of the bed.
    Are there some basic things I should check for issues or is this just acceptable for settling? I did not do the installation myself but I haven't noticed any other strange suspension issues and it seems to ride great still.
  13. Jul 24, 2017 at 8:37 AM
    la0d0g
    Did you check the dakars for ++ or -- signs to ensure they're installed on the correct sides?
  14. Jul 24, 2017 at 9:54 AM
    JWROSE4
    Jonny
    Virginia
    2013 DCSB SR5 4X4
    Work In Progress
    I should have added that, they are the extended.
  15. Jul 24, 2017 at 9:06 PM
    WSMFP
    WSMFP Well-Known Member
    Dylan
    2006 Tacoma 4x4 v6 6-speed
    New to tacoma world and I have literally read every article regarding OME lifts and wanted to know whether to go with 885s or 886s?
    Here is what I will be ordering....
    LR upper control arms
    ARB bull bar or Relentless Fab front plate Bumper (still deciding on which one to get)
    OME 885 or 886 full suspension kit with Dakars in the rear
    rear bumper from relentless fab
    No winch for awhile
    I want 2.5 inches of lift. I know the springs will settle over time but wasn't sure if 886 is too much for an access cab for not having a winch or should I go 885.Was curious what others have done with this setup?
    Also I am currently running 265/75 hankook tires
    Thanks
  16. Jul 24, 2017 at 9:11 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    dziner, PNWTacoma and Juforrest like this.
  17. Jul 24, 2017 at 9:24 PM
    la0d0g
    886s. But even if you go with 885s and then get a winch, coils are relatively cheap and easy to swap so you could go up to 886s if they sag too much for you.
    WSMFP[QUOTED] and dziner like this.
  18. Jul 24, 2017 at 11:30 PM
    PNWTacoma
    Paul
    Sweet. Do you have extended shocks?
    dziner likes this.
  19. Jul 25, 2017 at 8:47 AM
    saundern
    saundern Swerve for nothing
    Nick
    Simpsonville, SC
    2005 TRD Sport
    The 886s were designed to handle the added front end weight of an aftermarket bumper. Remember, the ARB is made by OME too.
  20. Jul 25, 2017 at 8:57 AM
    anthony250f
    Anthony
    San Diego, CA
    Bilstein 5100 b110
    Extenders on regular 5100s wouldn't be enough
    dziner and PNWTacoma[QUOTED] like this.
