Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Aug 21, 2017 at 6:54 AM
    65skyturbo
    65skyturbo Well-Known Member
    Mesa, AZ
    06 Speedway Blue DCSB TRD Off Road
    I'm planning on the OME kit with the 90021's. They are the underdog since everybody here mostly runs the Bilstein 5100 if they are not going to the higher level stuff. To me, it appears people who have had both prefer the OME. I have found several threads where people were unhappy with the 5100 for whatever reason and switched to OME. It seems like the OME "clunk and dakar squeak" happened more with the older stuff. Maybe OME has addressed those concerns because people don't mention it as much as they once did. I'm hoping people with OME experience chime in and answer your questions since I haven't purchased yet.
    rnicholls[QUOTED] likes this.
  2. Aug 21, 2017 at 10:35 AM
    la0d0g
    running for the hills
    For crawling not hauling
    Dakar squeak has been addressed. OSBGC has not.
  3. Aug 22, 2017 at 12:10 AM
    nizzmont
    nizzmont Well-Known Member
    Brian
    S.E WA state
    2015 doublecab TRD sport
    in progress
    I had a full OME setup on my 08 DCSB and on my new 15 I'm thinking about going a diff route.wasnt bad but I'd hoped for a better feel in the end.im trying to research it now and I'll decide from there.
  4. Aug 22, 2017 at 1:56 PM
    PNWTacoma
    PNWTacoma Well-Known Member
    Paul
    PDX 3rd party OV Tuner
    2025 TRD Pro | Mudbath // 2017 Offroad DCLB OG
    PNW Adventures & PNW Tuning
    I have 90021's with 888 coils and the new dakars. I never experienced the speed bump clunk and there's no squeaks as experienced with the older springs. YMMV
    Age315 and nartmot like this.
  5. Aug 22, 2017 at 2:30 PM
    Age315
    Age315 Well-Known Member
    AJ
    Castle Rock, CO
    2016 BBP Yeti Mobile
    TRD Baja Kit with JBA UCA's 1/2 inch spacer on top, Medium Dakars with BAMF hangars and super bumps all around. 285/75/16 Cooper Discoverer AT3 XLT's on graphite TRD faux beadlock wheels. Pro skid powder coated black with Pelfreybilt aluminum mid skid and aluminum gas tank skid.
    That's good to hear because I've been thinking about that exact set up. How's the ride and do you know what your hub to fender measurements are?
  6. Aug 22, 2017 at 2:33 PM
    PNWTacoma
    Paul
    Ride is very similar to stock OR, but less floaty. It's a playful suspension but very capable offroad. Blitzing the forest roads is very comfortable and fun. Since I have a DCLB, I'm at 23" in the front and 24" in the rear.
    Age315 likes this.
  7. Aug 22, 2017 at 3:45 PM
    rnicholls
    rnicholls Well-Known Member
    2016 TRD OR DCLB
    See posts like this make me re think this kit. Also dclb and considering a shell. I imagine the weight helps in some way?
  8. Aug 22, 2017 at 3:58 PM
    PNWTacoma
    Paul
    What makes you rthink consider? The rake in the rear?
  9. Aug 22, 2017 at 4:00 PM
    rnicholls
    2016 TRD OR DCLB
    The ride quality and claims of no bump. I really am having trouble figuring out legitimate reasons to choose nitrochargers over 5100s when everyone is complaining that it sucks at anything above crawling speeds.
  10. Aug 22, 2017 at 4:04 PM
    saundern
    saundern Swerve for nothing
    Nick
    Simpsonville, SC
    2005 TRD Sport
    The more weight that is added in the rear helps the ride comfort.
  11. Aug 22, 2017 at 4:20 PM
    Age315
    AJ
    Castle Rock, CO
    Awesome thanks for letting me know. I really think this is the kit I'm going to get. I'm assuming you have the EL095R's in the rear? Did you use the CB drop or any shims in the rear?
  12. Aug 22, 2017 at 4:33 PM
    PNWTacoma
    Paul
    I love it and wouldn't change it for a thing. Yes I have the EL095R's and installed both the CB and DD (DD not needed IMO). No issues with alignment or vibrations but I believe that's vehicle dependent. I say go for it.
    Age315[QUOTED] likes this.
  13. Aug 22, 2017 at 8:19 PM
    Age315
    AJ
    Castle Rock, CO
    Thanks I really appreciate it! I know what set up I'm going to get now!
    PNWTacoma[QUOTED] likes this.
  14. Aug 23, 2017 at 5:12 PM
    tacoma guy
    tacoma guy Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    So I am thinking of getting the 90021 but I'm not clear on the clunk issue. Is that still an issue or did OME correct it? Any in put is much appreciated!
    nartmot likes this.
  15. Aug 23, 2017 at 7:34 PM
    65skyturbo
    Mesa, AZ
    I don't think they did. If you look at the extended length of the OME shock it is about 1 inch shorter than the Bilstein 5100. I'm sure that the OME would be good at a lower lift height but if you are at 2.5" - 3 inches of lift, then it may clunk coming off speedbumps and abrupt drop offs. Basically OME purposely made the shock the limiting factor so that brake lines, ball joints, CV joints, etc. are not over stressed. I was going to order the kit but once I saw the extended length I am not sure. Before I order OME, I will definitely crawl under my truck and see if the 21.5" extended length looks like it would be enough. At this point I'm still looking at all the options....
    nizzmont and BenTheMan like this.
  16. Aug 23, 2017 at 8:26 PM
    tacoma guy
    Joe
    Phoenix Az.
    Thank you for that explanation. Makes sense and I am starting to understand where the clunking is coming from. So from what your saying will it cluck if I am only going 1 1/2 to 1 3/4 ?
  17. Aug 23, 2017 at 8:56 PM
    65skyturbo
    Mesa, AZ
    Yeah, I think you would be safe at that height.
  18. Aug 23, 2017 at 9:13 PM
    65skyturbo
    Mesa, AZ
    OME shock length is 21.38 and the Bilstein 5100 is 22.56 inches. I couldn't find the exact number but I found a few posts that says the OME 90021 is 1" longer than stock. Stock Toyota shocks should be roughly 20.4".
  19. Aug 23, 2017 at 9:30 PM
    tundra2tacoma
    tundra2tacoma Well-Known Member
    Greg
    Pittsburgh
    '11 DCLB SR5
    ProComp 7089 16x8, Cooper Disco ST MAXX 255/85/16, Leer cap, ome 885 and nitros in front, Wheelers 3-leaf AAL and Bilstein 5100s in the rear, ImMrYo's rear-view mirror lift bracket, BAMF LCA Skids, 4-Low yellow wire mod
    I just put on ome 885 with the softer ride nitros, after 65000 miles on eibachs/5100s. Lost about 1/8-1/4 inch of lift, but the ride is much smoother. The difference in expansion joints and potholes is quite evident. I also removed the sway bars. Went on a weekend trip to west Virginia on some pretty gnarly goat paths with some boulder gardens and one very technical stretch and couldn't be happier. Haven't noticed any more "clunk" on fast extension than I did with the eibach/5100 setup, though it is there when riding with speed over rocky terrain. Seemed harsher with the old setup.
    BenTheMan likes this.
  20. Aug 23, 2017 at 9:38 PM
    65skyturbo
    Mesa, AZ
    Well that is good feedback. I want a smooth ride and I have often read that the OME is smoother than the Bilstein. I wish the OME shock had a little more extended length just as a precaution against the clunk. Is your truck 4x4 or Prerunner? How much lift did you get with the OME 885 and soft ride shocks?
