Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Sep 14, 2017 at 9:13 AM
    Shralp
    Shralp Active Member
    So Cal
    2015 TRD Off-Road 4X4
    I love the looks of 33s but I don't want the extra maintenance. Also, some of the trips I do are pretty far drives so want to keep gas mileage somewhat in check. Are you talking about running an AAL on top of the dakars? If the front goes up 2 inches I'd like to keep the back similar with just a tiny bit of rake.
  2. Sep 14, 2017 at 9:14 AM
    la0d0g
    running for the hills
    For crawling not hauling
    I'm not familiar with the LD. I have the HD and like them but I would pull a leaf if pairing them with 884s.
  3. Sep 14, 2017 at 11:37 AM
    65skyturbo
    65skyturbo Well-Known Member
    Mesa, AZ
    06 Speedway Blue DCSB TRD Off Road
    I would do the heavy-duty pack. I bought the light-duty pack and my front is slightly taller than the back so now I'm looking at purchasing the OME additional add a leaf to make my light duty springs into heavy duty. If it turns out to be too much you can always remove a leaf from the heavy duty pack. It works out cheaper this way because now I'm looking at paying roughly $80 for the additional leaf.
  4. Sep 14, 2017 at 5:18 PM
    BLKTRD
    BLKTRD Well-Known Member
    2013 Baja T/X DCSB
    All-Pro Rear Bumper Leer 100XQ Prinsu Toprac Prinsu Cabrac Demello Sliders US Off Road Hidden Winch (planned) Smittybilt XRC Winch w/Synthetic Rope (planned) Lightning Racing UCAs 1" Coil Spring Spacer 1" Top Plate Spacer Old Man Emu CS047R Leaf Springs w/Add-A-Leaf 1" Rear Lift Blocks w/3 Degree Offset Extended Steel Brake Lines Transmission Drop Kit Differential Drop Kit Lucas Gear Oil (Diff, Trans) Cooper Discoverver S/T Maxx (285/75R16) Gorilla Lug Nuts Spidertrax 1" spacers Infinity Door Speakers w/Tweeters Powered 8" Kicker Subwoofer Alpine Amplifier 4 x 100w TRD Quickshift Brite-Box (Simultaneous Hi/Lo-Beam Adapter)
    +1. HD full pack. I think light duty version is not much better than just AAL. If you want, remove a leaf from the HD version. It may make the truck look more proportional with 265/75R16 tires if you remove a leaf. 265s are so close to stock, there is marginal increased maintenance/necessary aftermarket adjustment. Also, the speedo and odometer read more accurately with 265 tires.
    la0d0g[QUOTED] likes this.
  5. Sep 14, 2017 at 8:11 PM
    WSMFP
    WSMFP Well-Known Member
    Dylan
    2006 Tacoma 4x4 v6 6-speed
    Anybody on here got pictures of an Access cab with 886s bumper and winch?
  6. Sep 14, 2017 at 8:48 PM
    ABNFDC
    ABNFDC Well-Known Member
    Granite State
    2008 4WD Access Cab TRD OR "Rugged Trail"
    265/75/16 Wildpeaks, Dakar rear, HS 2.5" front coils
    Does anyone have the HD leaf pack in stock?
  7. Sep 14, 2017 at 11:18 PM
    ItsRichieRich
    ItsRichieRich Well-Known Member
    Richard
    Temecula, CA
    '13 Ford Raptor
    For the Dakar LD and HD leaf packs, are they squeaky? Missing piece to my puzzle is my rear leaf. Not sure if I want to go Dakar LD (only haul camping gear and street back once or twice a month. Other than that, it's unloaded) Or All-Pro std.
  8. Sep 15, 2017 at 4:24 AM
    JWROSE4
    JWROSE4 Well-Known Member
    Jonny
    Virginia
    2013 DCSB SR5 4X4
    Work In Progress
    Mine squeak...mainly after I go offroad, they seem to stop after hosing them out.
  9. Sep 17, 2017 at 8:59 AM
    ALwoodsman
    ALwoodsman Well-Known Member
    North Alabama
    2013 4x4 DCSB
    Baja Utility Rack, SOS Concepts sliders, Bilstien 5100, OME 884, Toytec AAL
    I have a 2013 DCSB 4x4. I am wanting to lift around 2" and keep cost down. I do some light off-roading and haul gear in the back or haul a small even or trailer with a atv. I am looking at 5100s with a 2" ALL. It sounds like I need 884s to keep my factory UCAs. Does this sound right? I have a Avid Off-road light bar and Baja flat rack. Not a lot of added weight.
  10. Sep 17, 2017 at 9:34 AM
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Reformed Taco driver in a GX460
    At 2.5" lift is when most folks run into alignment issues. 885's will get you in the2-2.5" range. (I got 1.75" out of mine).
  11. Sep 21, 2017 at 1:59 PM
    dsmdylan
    dsmdylan Well-Known Member
    Dallas, TX
    '17 DCSB OR Quicksand
  12. Sep 21, 2017 at 2:51 PM
    Jibber82
    Jibber82 Member
    Live Free or Die
    2017 MGM DCSB TRD OR
    Anyone have any input on these alignment numbers? I'm guessing not great?
    '17 DBSB OR
    Lift: OME 887, nitrochargers, Dakar leafs, stock UCA's
    285/70R17 tires on SEMA wheels
    Kit, wheels, and tires all installed today. No rubbing I can tell on road. Truck seems to drive great, no pulling or vibrations. Note that the Alignment report stated P265/60R18 tires which is incorrect, not sure if that matters.
    Catfish21 likes this.
  13. Sep 21, 2017 at 3:01 PM
    dsmdylan
    Dallas, TX
    Looks fine. Ideally you'd have 0 camber or slightly negative but +0.8 is within spec. The positive caster is good. It would be nice to see matching caster at 2.0 but it's close.
    Jibber82 likes this.
  14. Sep 26, 2017 at 8:12 AM
    KayakNTaco
    KayakNTaco Well-Known Member
    Sam
    2016 Tacoma TRD Off-Road
    Prinsu rack
    I have a 2016 TRD OR DCSB. Went with the OME BP-51 lift with replacement Dakar leaf pack and replaced the ucas. What maintenance should I do to the suspension? My front end is starting to sqeak, mainly when I hit a bump.
  15. Sep 26, 2017 at 9:39 AM
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    I have bp's and camburg uniballs. It squeaks like a mofo. Only thing if found the makes it stop is driving in the rain, or turning the stereo up.
    Borealis likes this.
  16. Sep 26, 2017 at 11:43 AM
    KayakNTaco
    Sam
    Prinsu rack
    That's upsetting to hear...as expensive as this suspension is it shouldn't squeak.
  17. Sep 26, 2017 at 11:45 AM
    la0d0g
    Teflon the heck out of it. Every brand of suspension needs maintenance if used as intended.
  18. Sep 26, 2017 at 12:51 PM
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    It goes well with my squeaky Dakars.
  19. Sep 26, 2017 at 7:12 PM
    09 Redneck
    09 Redneck Well-Known Member
    Ga
    Any 3rd gens with 884s? How much lift did you get with them?
  20. Sep 27, 2017 at 12:04 AM
    Catfish21
    Catfish21 Well-Known Member
    Stockton, Ca.
    Trd off road 4th Gen
    with your OME 887's what is your front height?? how much of a lift increase did you get? 2.5? 2.75?
