Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Oct 8, 2017 at 2:54 PM
    saundern
    saundern Swerve for nothing
    Nick
    Simpsonville, SC
    2005 TRD Sport
    I’ve got vibration at 45mpg but it seems like the new tires aren’t balanced right.
  2. Oct 8, 2017 at 3:02 PM
    Marbleyard
    Marbleyard Thread killer
    Virginia
    2019 4Runner Pro
    SOLD 2016 taco: premium technology and tow package. OV Tune 1.05; A.R.E. V Camper Shell; BRO grille & Tails; OEM bed mat; Xenon Depot HID headlight conversion; reflective gray tailgate letter inserts; GoPro session; Hondo radio knobs; K&N cold air intake, quicksand painted dash bezels, Subaru dash speakers, Kicker CS 6x9 fronts and 6.5 rear speakers; All LED interior lights and LED high-beam headlights. Redline elite hood shock props. prinsu cab and camper rack with rough country 30" light bar; (2) 8" rear facing “F.U.”rough country black LED lights; prinsu cargo basket kit, (2) prinsu load racks; roadshower 4; ARB 2500 awning and room kit; weather tech floor mats; carhart seat covers; ckma12 ARB air compressor under the hood; blue ridge overland gear air tools bag, tool bag, driver's seat molle. Rack mounted TRED 800 recovery treds and plano case. Rotopax water and fuelpax fuel canisters; Pelican cased first aid kit in bed. rockblokz mud flaps. ARB rear dif. breather. Stand alone fuse block. SSO bumper with 10k smittybilt synthetic line winch and factor55 ultrahook. Pro Eagle 2-Ton “The Beast” jack. OME lift kit: 90000 front shocks and 886 OME coils, Camburg 310078 UCA, 60091 rear shocks with light duty Dakar leafs. Good Year duratracs 285/75R16. Black vinyl inlays on factory OR wheels; RCI Steel Front/Trans/Trans Case/Rear Diff Skids, Alum A-Arm; Mobtown bolt-on sliders with scorpion bed coating; pelfreybilt aluminum fuel tank skid; Cali-Raised full length Molle storage LH & RH bed sides; Caliraised bedside reinforcements; HELLA sharptone horns; Optima blue-top battery with AJT machined red tiedown bracket. AJT quicksand key fob. Overland Bound member #6996
    My vibration is very low speeds, less than 15mph. Only noticeable in the steering wheel, nothing in the pedals or ride of the truck.
  3. Oct 8, 2017 at 7:06 PM
    la0d0g
    running for the hills
    For crawling not hauling
    Embrace the bushing install :)
  4. Oct 8, 2017 at 9:19 PM
    saundern
    Nick
    Simpsonville, SC
    2005 TRD Sport
    Exactly how mine is.
  5. Oct 9, 2017 at 1:26 AM
    Friedtacolover
    Friedtacolover Well-Known Member
    Travis
    Ontario, Ca
    2017 DCSB Off Road 4x4
    my build tread: https://www.tacomaworld.com/threads/socal-no-shame-poser-build.513084/
    All these darn stories make me not wanna lift
  6. Oct 9, 2017 at 3:32 AM
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    if it helps any, my only vibration is the tiniest of shudders right at takeoff, and if theres any road imperfections you dont even notice it.
  7. Oct 9, 2017 at 5:34 AM
    saundern
    Nick
    Simpsonville, SC
    2005 TRD Sport
    It’s an easy fix. Just annoying to my OCD self
  8. Oct 9, 2017 at 6:17 AM
    la0d0g
    The majority of people don't get vibes. Just be sure to take the right measurements prior to lifting so if you do get them you can address it more easily.
    You must not be too OCD if you still have them :p
  9. Oct 9, 2017 at 6:19 AM
    saundern
    Nick
    Simpsonville, SC
    2005 TRD Sport
    ‘Lazy’ OCD
  10. Oct 9, 2017 at 8:09 PM
    YotaBum
    YotaBum Not So Well-Known Member
    Alex
    North Georgia
    2015 TRD Sport DCSB
    Blacked Out-887-Dakars-LR UCA-FJ Trail Team wheels-285 BFG KO2
    Only vibes I ended up with are a slight shudder at takeoff... Probably would only require a leaf spring shim to correct, but it is so slight that I haven't bothered.
  11. Oct 10, 2017 at 2:23 AM
    Marbleyard
    Virginia
    2019 4Runner Pro
    Elaborate, I'm not familiar with this. Sounds easier than the ECGS bushing and I would truly hate to do the bushing to find out it did nothing... other than save me the problem of doing it later.
  12. Oct 10, 2017 at 3:28 AM
    la0d0g
    You shim between the axle perches and the leaf pack to correct the angle of the driveline to get it back within spec. This is why you record DL angles prior to lifting.
    Marbleyard[QUOTED] likes this.
  13. Oct 10, 2017 at 7:03 AM
    YotaBum
    Alex
    North Georgia
    2015 TRD Sport DCSB
    Good explanation above... Biggest thing is to know is that they address different vibes.
    If I'm not mistaken, I think you can try putting it in 4wd if/when you start getting vibes. If they go away in 4wd, it is a frontend vibe and the ECGS should take care of it. If not, it is most likely driveline and a combination of shims and/or a carrier bearing drop should work. But don't quote me on that haha!
  14. Oct 10, 2017 at 8:00 AM
    la0d0g
    QFT :D
    YotaBum[QUOTED] likes this.
  15. Oct 10, 2017 at 8:06 AM
    Kohan21n
    Kohan21n A caffeine dependent life form - IG @dizzy.trd
    Nazareth, PA
    2016 DCSB MGM 6MT
    Never measured DL angles before my lift on my 2006. Doing my 2016 tomorrow, best way to do it? Where exactly am I measuring?
  16. Oct 10, 2017 at 8:50 AM
    la0d0g
    You can get a fancy angle measurement tool or just use an old protractor. You want to measure the angle of the DL in relation to the 3rd. Like where the flange meets the ujoint. Doesn't really matter exactly where just that you're consistent with before/after and I would do it in the same place so the surface you're parked on doesn't influence it.
    Kohan21n[QUOTED] likes this.
  17. Oct 10, 2017 at 9:04 AM
    YotaBum
    Alex
    North Georgia
    2015 TRD Sport DCSB
    Here you go...
  18. Oct 10, 2017 at 9:35 AM
    Kohan21n
    Nazareth, PA
    2016 DCSB MGM 6MT
    Thanks guys!
  19. Oct 10, 2017 at 4:56 PM
    Kohan21n
    Nazareth, PA
    2016 DCSB MGM 6MT
    Quick question: 3rd gen kit ordered, didn't receive the bushings for the struts. They are supposed to come with this kit right? I don't remember ever having to buy them when I did this same kit on my 2006.
  20. Oct 10, 2017 at 6:47 PM
    la0d0g
    Yes, all the bushings and hardware should be included.
    Edit: did you get them preassembled?
