Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Dec 7, 2017 at 2:20 PM
    TOP TACO
    TOP TACO Well-Known Member
    Marz
    Sacramento
    15 Tundra Crewmax
    Blackvue dash cam
    Good question...? I guess over 2"? Maybe
  2. Dec 7, 2017 at 2:23 PM
    TOP TACO
    Marz
    Sacramento
    15 Tundra Crewmax
    Blackvue dash cam
    I know that I will really only drop a 1/2" by removing it so...
  3. Dec 7, 2017 at 2:24 PM
    SoCOTaco
    SoCOTaco Well-Known Moron
    Mitchell
    Lakewood, CO
    2012 Tacoma TRD Off Road 4X4
    GFC, Fox 2.0's w/ Dakars, SCS BR6's, Fridge w/ Beer
    Leave it in. I took my 3rd leaf out and with my ~200lb constant load on my OME pack I got a bro lean. Granted I'm sitting on King's so my front lift numbers may be different.
  4. Dec 7, 2017 at 2:25 PM
    TOP TACO
    Marz
    Sacramento
    15 Tundra Crewmax
    Blackvue dash cam
    you said 3rd leaf, I'm talking 2nd overload. you got the 96 pack and removed the 3rd leaf effectively making it the 95?
  5. Dec 7, 2017 at 2:26 PM
    la0d0g
    running for the hills
    For crawling not hauling
    With a constant 500lbs you wont be over 2" difference front to back.
  6. Dec 7, 2017 at 2:29 PM
    TOP TACO
    Marz
    Sacramento
    15 Tundra Crewmax
    Blackvue dash cam
    So you're saying I should just run the whole 96 pack and not remove the 2nd overload correct?
  7. Dec 7, 2017 at 2:31 PM
    TOP TACO
    Marz
    Sacramento
    15 Tundra Crewmax
    Blackvue dash cam
    What would your answer be to this same question?
  8. Dec 7, 2017 at 2:38 PM
    RCRcer
    RCRcer Well-Known Member
    2015 OR DC
    So are you anticipating ~2" in the front? If so I would leave the 96 pack as is. With 500 lbs of constant weight the pack is not going to give you the advertised amount of lift and their going to settle as well.
    I just installed the 96's and this is what I experienced with 400 lbs or so and that's not counting loading it out for camping. I'm even considering adding a leaf in the future depending on how much more they settle after further break in. Just my honest opinion from what I'm experiencing with them on my truck.
  9. Dec 7, 2017 at 2:43 PM
    la0d0g
    Correct.
    I like some rake so it would need to be quite a bit before i gave it stinkbug status. Maybe 3.5-4" :notsure: :D
    RCRcer likes this.
  10. Dec 7, 2017 at 2:44 PM
    TOP TACO
    Marz
    Sacramento
    15 Tundra Crewmax
    Blackvue dash cam
    Ok, that is great feedback. I understand its a case by case basis, but figured someone would have real experience data. Thank you! What are you running in the front?
  11. Dec 7, 2017 at 2:46 PM
    RCRcer
    2015 OR DC
    I drank the cool aid. Icon with 2"s of lift.
    TOP TACO[QUOTED] likes this.
  12. Dec 7, 2017 at 2:46 PM
    TOP TACO
    Marz
    Sacramento
    15 Tundra Crewmax
    Blackvue dash cam
    Right. I'm fine with a little rake, just hear conflicting lift heights. especially in threads discussing new and old packs. Your feedback is much appreciated!
    la0d0g[QUOTED] likes this.
  13. Dec 7, 2017 at 2:51 PM
    TOP TACO
    Marz
    Sacramento
    15 Tundra Crewmax
    Blackvue dash cam
    So what was your hub to fender measurement on the rear?
  14. Dec 7, 2017 at 2:51 PM
    RCRcer
    2015 OR DC
    I like some rake as well. To me the Tacomas look bro leaning when level. Hell even with an 1" of rake they look bro to me. I'd be happy with a 2" rake when loaded. This is why I'm considering the AAL.
  15. Dec 7, 2017 at 3:08 PM
    RCRcer
    2015 OR DC
    I asked for "0's" on both packs and surprisingly they both measured the same height when installed and settled some. I ended up with 23 5/8" hub to fender (with 400 lbs) When I mounted my spare on the bumper (it sets more towards the left side) that pack is now setting about a 1/4" lower.
    So, I only got 2 1/8" over stock with the 400 lbs constant on the truck. Ended up ~1.5"s of rake and that's not loaded out.
  16. Dec 7, 2017 at 3:13 PM
    TOP TACO
    Marz
    Sacramento
    15 Tundra Crewmax
    Blackvue dash cam
    OK great, thanks man. Damn I love this place!
  17. Dec 7, 2017 at 4:56 PM
    SoCOTaco
    Mitchell
    Lakewood, CO
    I bought my pack before there were 2 options. I would say you won't have a massive rake, if any, with that kind of constant load.
  18. Dec 7, 2017 at 5:00 PM
    TOP TACO
    Marz
    Sacramento
    15 Tundra Crewmax
    Blackvue dash cam
    Sweet, thank you for the reassurance. Much appreciated!
    SoCOTaco[QUOTED] likes this.
  19. Dec 7, 2017 at 6:47 PM
    TOP TACO
    Marz
    Sacramento
    15 Tundra Crewmax
    Blackvue dash cam
    Did you experience vibrations post lift? Did you install shims or cb drop? I do plan to measure driveshaft angles before and after.
  20. Dec 7, 2017 at 7:04 PM
    RCRcer
    2015 OR DC
    Fortunately for me No vibes as of yet have ~350 miles since install. I had 3 leaf AAL with overload in before and no vibes there either.
    I can't believe it. I was totally expecting to have vibrations. I haven't taken post install angle measurements yet to learn the difference pre and post.
    If/when I take a 200lb RTT off that might change things though.
