Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Feb 20, 2018 at 2:15 PM
    BamaTaco56
    BamaTaco56 Well-Known Member
    Trey
    has anyone but 888 coils on a 2nd gen?
  2. Feb 20, 2018 at 8:36 PM
    la0d0g
    running for the hills
    For crawling not hauling
    Pretty sure a few have. There is this search thing where you can keep your results to a specific thread. That might help.
    saundern likes this.
  3. Feb 21, 2018 at 1:09 PM
    BamaTaco56
    Trey
    That search thing brings up lots of results for 3rd gen but have not seen any for 2nd gen.
  4. Feb 23, 2018 at 2:14 PM
    danbow
    danbow Member
    Daniel
    Texas
    18 F150 Crew 4x4
    This may be in this thread somewhere, but I can't seem to find it.
    I have an ARB and a 10k winch with synthetic line going one so I'm changing to 886's with 9000's (from 887/5100)
    I don't have a sway bar.
    Are there any issues to be expected running the additional 1/4in top plate spacer with 886's/9000's and no sway(UCA's already replaced)?
    My main concern is will this allow one side to droop to the point that it will cause a CV to bind and fail or will the shock reach it's limit before that happens?
  5. Feb 25, 2018 at 1:03 PM
    la0d0g
    You won't get that much drop. Good to go.
    danbow[QUOTED] likes this.
  6. Feb 26, 2018 at 8:25 AM
    BandanaBerg
    BandanaBerg Yotas Yotas Yotas Pocast
    Phoenix,AZ
    2010 DCLB SR5 4x4
    Up Front; Icon 2.5 Extended w/ Fox 600s, Icon Delta Joint UCAs, Poly Performance Taco Tabs, BAMF Hybrid Bumper, Pelfreybilt Legacy IFS Steel Skid, RCI Transfer Case Skid Out Back: Archive Garage Hammer Hangers w/ High Clearance Cross Bar, OME Dakar Expedition Pack, Icon 2.0 RR, All Pro U-Bolt Flip w/ Super Bumps, All Pro Extended Brake Lines, Trail Gear Rock Assault Bumper w Custom Swing Tire Carrier Wheels & Tires: Pro Comp 5001 Wheels 16" on some 285/75/16 BFG AT KO2, ARB Single Compressor Up Top & Around: RCI 5° Rock Sliders, CaliRaised LED Premium Roof Rack w/ CaliRaised LED Dual Function Light Bar, CaliRaised LED Amber Fogs in CaliRaised LED LED Fog Light Pod Replacement Brackets, Anytime Fog Mod, CaliRaised LED Ditchlight Fogs on CaliRaised LED Low Profile Ditch Light Brackets, Voswitch UV100 Switch Controler, Chineseum Chase Ambers & reverse/camping LEDs Misc Thangs: Tech Deck w Ram Ball Mounts, Expedition Essentials 2nd Gen Rail w/ Ram mounts...
    Quick question...
    I have OME Nitros up front.
    The eyelet where the shock mounts to the LCA has worn and there is some play on the up & down. Noticed it last time I was in there checking torques, the bolt was a little loose and noticed the play. Pulled the bolt and noticed some irregular wear where the eyelet has obviously been making contact in it’s play...
    My question is, can this eyelet be rebuilt?
    Is there a solution to this other than replacing?
  7. Feb 26, 2018 at 2:37 PM
    AKHawkeye
    AKHawkeye Well-Known Member
    Anchorage, AK
    15 AC Sport 4x4 6 Spd
    Locked as stock
    I'm looking at purchasing an ARB bumper with fog lights sans winch. I understand with this setup I'll need to upgrade my suspension to compensate for the added weight. I'm only looking at increasing the ride comfort with a slight lift as a byproduct. So I guess in total I'm looking for at max 2" lift. I'd rather avoid UCAs. The truck will be mainly used on gravel roads.
    With this said, is the 90000's with 886 up front going to give me more than 2"s and requiring me to install aftermarket UCAs? Basically looking at the OMETAC05HKSB kit which states only 2" of lift from ARB, but I'm not sure I believe that. I'd rather buy once, cry once, than dick around with spring weights. Shipping to AK is expensive. I might also just say YOLO and purchase the BP-51's. Any input?
  8. Feb 26, 2018 at 3:52 PM
    saundern
    saundern Swerve for nothing
    Nick
    Simpsonville, SC
    2005 TRD Sport
    I have the 886/90000 setup, with admirations of a bumper at some point. ARB specifically designed the 886s to settle under the weight of their bumper. From what I’ve seen before, you’re gonna get ~2.5 inches of lift after it settles, and the ride actually gets better when you have weight up front with these coilovers too.
    mcharfauros likes this.
  9. Feb 27, 2018 at 11:20 AM
    la0d0g
    I have about 300lbs up front and have about 2.25" from 886s.
  10. Feb 27, 2018 at 11:23 AM
    16Tacos
    16Tacos Well-Known Member
    Zach
    Boston
    08 Access Cab 4x4 V6 SR5
    OME Nitrochargers w/886s & Dakars, ARB Deluxe Bull Bar w/Warn winch, RCI sliders with kick out, IFS & Mid skids, BFF Hi-clearance rear bumper, Brushed Copper 17" SCS Ray10s w/285-70 KO2s, Black OEM 16" steelies w/255-85 KM2s, Leer contractor cap w/Smittybilt overlander xl RTT, Off-Grid Engineering dual battery kit and bed power panel, Blue sea aux fuse block, Wyntner 60L fridge freezer, ARB dual compressor, Pioneer 720BT head unit, CB radio, @Matt_Gecko bed and engine bay lights, @TacomaTruckParts Dirt bike tie down bar, color matched OEM grill, A-Pillar phone mount mod, @Docloco rear seat molle panel
    255/85/16 will get you to 33s and all I did was remove my front mudflaps.
  11. Feb 27, 2018 at 4:07 PM
    AKHawkeye
    Anchorage, AK
    Locked as stock
    So with about 150 lbs from a bumper alone I'll sit probably higher at (pulling number out of my ass) around 2.5-2.75" with 886? That brings me into upgraded UCA territory huh?
    Thanks.
    BandanaBerg likes this.
  12. Feb 27, 2018 at 4:50 PM
    BandanaBerg
    Phoenix,AZ
    2010 DCLB SR5 4x4
    Upgrade UCAs Anyways...:notsure::transformer:
  13. Feb 27, 2018 at 6:47 PM
    la0d0g
    Not necessarily. That's the territory of maybe you will, maybe you wont. An alignment will be one way to find out.
  14. Feb 28, 2018 at 6:11 AM
    saundern
    Nick
    Simpsonville, SC
    2005 TRD Sport
    I did not upgrade my UCAs with this setup. Haven’t had a problem
  15. Feb 28, 2018 at 6:56 AM
    mtmudrunner
    mtmudrunner Well-Known Member
    Wes
    Tomcreek corner, MT
    1985 Toyota 4x4 p/u
    Rust
    This is the exact same setup I am running with the hd Darkars in the rear, I have put about 350 miles on it and so far no problems. The ride is more firm but not bad at all. I also removed the sway bar and really can't tell much if any difference. I replaced the UCAs with lr spc.
    danbow[QUOTED] and saundern like this.
  16. Feb 28, 2018 at 9:10 AM
    tacoshin
    tacoshin Well-Known Member
    Brian
    the name of my truck, WA
    2008 Lexus IS250 AWD/2014 Tacoma SR5 4x4 short bed
    Smittybilt step bars, Toyota skid plate, All Pro bed rack w/ tonno pro retrofitted thanks to pushingcasket for helping, trd exhaust 14019 miles
    it depends I have a ARB bumper no winch and got the 886 coil and it sat 3.5 inch and wouldn't go down at all. luckily we have a ARB HQ here in WA in auburn and I explained to them about how my front is sitting too high after trying to break it in. and the guy I talked to saw my truck was like that's weird?? so I swapped out with 885 for free since it was in the 90 days I got it installed. the 885 is a lot lighter up front so I have more somewhat bounce I guess since its heavy up front. but I think if you have a winch and bumper then 886 would be a better bet but even the guy at ARB showed me his coworkers 1st gen tundra with winch and front bumper and he put 885 cause his 886 was too stiff and wasn't settling. right now with my bumper and 885 with 9000 shocks its sitting 2.5 so far like it except small squeaking when slowly going over speed bumps
    mtmudrunner likes this.
  17. Feb 28, 2018 at 10:41 AM
    Oldred92
    Oldred92 Well-Known Member
    Austin
    Boston, MA
    2003 White SR5 Double Cab Tacoma TRD 4x4
    Front Suspension: 882 w/ Nitrocharger Sport Rear Suspension: Dakar HD w/ Nitrocharger Sport ARB Front Bumper w/ winch Extruded aluminum roof rack Tires: Discoverer ST Maxx LT255/85/R16 on Tacoma Steelies Additional Fuse Box and Upgraded Wiring
    I am getting a clank from my newly installed on a 2003 double cab 4x4 Tacoma with
    ARB-OMETAC04HKS-ASM-2TP '98-2004 Toyota Tacoma Old Man Emu Suspension Kit, Heavy Load with Nitrocharger Sport Rear Shocks
    Here is a video where the clank happens serveral times. Im not sure where it is coming from but I suspect it is the shackles or the front leaf mount point. I plan on retorquing everything to make sure all attchment points fall in ft lb spec. Any other advice/recomendations are greatly appreciated.
  18. Feb 28, 2018 at 10:51 AM
    danbow
    danbow Member
    Daniel
    Texas
    18 F150 Crew 4x4
    Thanks for the update after install.
    I also have the LR UCA's. I only have a 1.5in wheelers single AAL in the rear though. I'm still on the fence on whether to go 886/9000's only or to add the 1/4 spacers.
    From what I gather the 1/4 spacers aren't going to be a problem for the mechanical limits of the CV axles. (I had a 1/4spacer on my L side only to compensate for lean with 887's/5100's that caused some problems which is why I was leery about adding spacers to a coil that already provides some lift)
    Now it's just a matter of it will the truck sit right. i.e. too much rake or get into bro-lean territory w/ spacers and 886s.
  19. Feb 28, 2018 at 11:04 AM
    mtmudrunner
    Wes
    Tomcreek corner, MT
    1985 Toyota 4x4 p/u
    Rust
    If I remember correctly I am almost 2" taller in the rear measuring the center of the hub to the fender but just looking at it being a long wheelbase you don't really notice it. One of the reasons I went with the 1/4" spacers was to minimize rake, also I have the trim packer on the drivers side and each side measures the same but it seems like all trucks are different. If you haven't already get ahold of Marie at Headstrongoffroad and she will point you in the right direction they helped me out and I have nothing but good things to say about them. :cheers:
  20. Mar 1, 2018 at 8:41 PM
    WSMFP
    WSMFP Well-Known Member
    Dylan
    2006 Tacoma 4x4 v6 6-speed
    Getting My full OME kit from Headstrong tomorrow! Lift day is in a week. Got the 887s with the heavy shock, light Dakars, SPC UCA's, ARB bumper "classic" style and XRC winch with synthetic line ready to rock. Ive got a raider truck cap on my access cab taco, if I add a plate rear bumper will I need to add another leaf to my Dakars?
    Will update with pics post lift!!!
    tacoshin likes this.
