Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Apr 11, 2013 at 11:41 AM
    #1161
    4Wheelin4Banger
    4Wheelin4Banger [OP] Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    Nice. My dirt withdrawl has gotten so bad I did donuts in the wet dirt on the way back from Lowes just to get some dirt on the truck. I'm too busy with 50 hr weeks @ work + relandscaping & remodeling the new house.
  2. Apr 15, 2013 at 7:40 PM
    #1162
    fouillard13
    fouillard13 Well-Known Member
    Riley
    Canadia
    1998 tacoma 4x4
    Can someone please help me. I dont have my truck here so i can not meassure. I need to know the proper u bolt size for my dakar leaf springs on my 98 tacoma 4x4. I need to know what length ill need and width. Are oem u bolts 1/2"? would 8" long by 2.5" wide and 1/2" thick work
  3. Apr 15, 2013 at 9:26 PM
    #1163
    DoorDing
    DoorDing Intentionally obtuse
    Bodie, CA
    2017 RC Off-Road 3.5WD
    yes
    Wheeler's Off-Road sells the correct U-bolts for those springs and MY Tacoma. Contact them for the specs, or just order a set.
  4. Apr 15, 2013 at 9:46 PM
    #1164
    fouillard13
    Riley
    Canadia
    1998 tacoma 4x4
    i am in Canada. I need them by Sunday. I am getting some built i need specs.
  5. Apr 15, 2013 at 10:01 PM
    #1165
    DoorDing
    Bodie, CA
    yes
    Here you go. If you call them tomorrow, I'll bet you can have them by the weekend.
  6. Apr 16, 2013 at 10:31 AM
    #1166
    hilux30
    hilux30 Well-Known Member
    PEI
    07 Tacoma SR5 4x4
    885s, no top spacers, Dakar's 285/75/16s on 1st gen Tundra steels (16x7 +15):
  7. Apr 16, 2013 at 12:52 PM
    #1167
    TRD6Speed
    TRD6Speed senior member
    Bill
    East Hartford, CT
    08 TRD Sport Access Cab
    885x with 5100s and top plate spacer for full 3", RCD extended 5100s in rear, dakars, flip kit, LR UCAs, tint, shorty antenna, in channel rain guards,BHLM, blacked out emblem, OEM side steps, weathertechs, debadged, rear diff breather
    What size tires? they looked stuffed as heck up in front. No cab mount chop?
  8. Apr 16, 2013 at 1:50 PM
    #1168
    hilux30
    PEI
    07 Tacoma SR5 4x4
    285/75 on 1st gen Taco/Tundra steelies ... I expected more lift in the front but happy the way it ended up.. handles the rough roads much better.. . No cab chop, but I do have 1st gen mud-flaps and the front flares are slightly trimmed.... no rub at all
  9. Apr 18, 2013 at 11:55 PM
    #1169
    shredgar1
    shredgar1 Well-Known Member
    Edgar
    Hacienda Heights, CA
    2011 PreRunner SR5 AC
    XD Addict 18", Bridgestone Dueler A/T RH-S 265/65/18, afe pro dry, spidertrax 1.25"
    for 2nd gens, can you still use the stock UCAs with an OME 3" lift kit?
    i keep hearing yes and no :confused:
    i dont go offroading at all. which is why im wondering if itll be ok to run stock UCAs atleast for a while til i get aftermarket ones.
  10. Apr 19, 2013 at 12:03 AM
    #1170
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Use , yes
    Get a good alignment , not as likey
  11. Apr 19, 2013 at 12:35 AM
    #1171
    shredgar1
    Edgar
    any aftermarket UCAs you would recommend for an OME lift kit? i was already looking at a pair of light racing ucas.
  12. Apr 19, 2013 at 4:36 AM
    #1172
    Sandman614
    Sandman614 LRGRNR
    Boone, NC\Garner, NC
    '06 SR5 Off Road
    Those! :thumbsup:
  13. Apr 19, 2013 at 5:16 AM
    #1173
    redcbs
    redcbs Well-Known Member
    Christopher
    Greenville, SC
    '11 4x4 Off-Road AT
    Full 3" OME Lift, Sport Shocks with top plate spacers and 885 coils, Light Racing UCA, Sport shocks and Dakar leaf springs, Avid Light bar, Avid Step rails, Grillcraft grille with 70's Land Cruiser emblem, custom vinyl stickers, window tint, selective debadging, fog light anytime mod
    I've read thru this whole thread and the thread about Toytec vs OME. I've decided to go OME but wanted to verify that I get everything I need and don't order unnecessary parts. I'd love suggestions on vendors, too.
    I have a 2011 Double Cab Off-Road 4x4. I would like the full 3" lift and will be running 275/70R17 BFG T/A's on Black Rock 908Bs. No after-market bumper/winch, just an Avid light bar.
    Front:
    -885 Coils
    -OME 90000 NitroCharger Sport Front Struts
    -OME95PF5 5MM Trim Packer (to correct the lean)
    ****-10MM Lift Enhancer Kit or 13MM? I just want the full 3" in the front, again no full bumper, just a light bar
    Rear:
    -OME 60091 NitroCharger Sport Rear Shocks
    -OME CS047 Dakars with Bushings and Ubolts
    Other:
    -OME FK29 Driveline Carrier Bearing Drop (for vibration)
    ****-Front Differential drop? I've heard arguments for and against.
    -SBR-129 - Toytec sway bar relocates
    -Light Racing UCAs (FatBob's got the best price that I've found so far)
    ****-TT-RS - Toytec rear axle degree shims?
    -SS-FBL - Toytec extended front brake lines
    -SS-20-05 - Toytec extended rear brake lines
    Miss anything/Don't need something?
    Last is what vendor have y'all found to have the best pricing? Wheelers, Toytec, and Downsouth are the three I've heard. No sense in spending extra $$ when I don't have to...
    Thanks in advance...
    :bowdown:
    BTW, took a sawzall to the truck for the first time this weekend (replacing with grillcraft), after the panic of the first cut, something changed. The mod bug bit me and is here to stay. Byebye $$...
  14. Apr 19, 2013 at 5:26 AM
    #1174
    Large
    Large Red
    You have 2 cb drops on there, it would be a good measure to have 2 I guess, I used 2 and it cured the vibes almost completely. Use 1 at a time though, 1 might rid your vibes (if you even have any). Ditch the diff drop, it's useless, don't order the UCA's yet, you might could get away with proper alignment, if your caster is way out of whack, they yes get the UCAs, you don't need the extended brake lines, having them on the rear sure helps when installing a new leaf pack though, on the shims, you only need them if you are getting vibes, with the trim packers, get a 1/4" one (passenger) and a 1/2" one (driver side) and longer studs IIRC fat bobs sells them
  15. Apr 19, 2013 at 5:27 AM
    #1175
    jhodge83
    jhodge83 Any dog under 50# is a cat and cats are useless... Moderator
    SC
    09 Timberland Mica DC 4WD Sport
    wat?
    ^^i got the best price from DSM when i bought mine. looks like you have the carrier bearing drop on your list twice.
    EDIT: too slow on the CB drop.
  16. Apr 19, 2013 at 5:33 AM
    #1176
    redcbs
    Christopher
    Greenville, SC
    '11 4x4 Off-Road AT
    Edited. Good catch.
  17. Apr 19, 2013 at 5:35 AM
    #1177
    Large
    Large Red
    Like I said in my post.. it might be a good idea to have 2, if you only use 1 yo9u could always sell the other pretty quickly here..
  18. Apr 19, 2013 at 5:36 AM
    #1178
    jhodge83
    SC
    wat?
    i think i would buy one of the beefed taco CB drops before i went stacking other ones to piece together.
  19. Apr 19, 2013 at 5:38 AM
    #1179
    Large
    Large Red
    Yeah I thought the same thing, ordered a BTCB drop for the 5" and less rear lift and it didn't help at all, ordered another 1/2" spacer on top of the first 1/2" spacer, installed, and was almost vibe free (had a minor 55-60 mph)
  20. Apr 19, 2013 at 5:39 AM
    #1180
    Large
    Large Red
    Actually, if you want I would sell you mt BTCB drop, been sitting in my drawer for a year going to waste.
