Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Mar 2, 2019 at 8:14 PM
    kasnerd
    kasnerd candied bacon
    SoCal Yokel
    '14 SC LT Mall Runner
    Mods? Yes, oh yes..
    Bastek[QUOTED] likes this.
  2. Mar 2, 2019 at 10:42 PM
    Guardian
    Guardian Well-Known Member
    Colorado
    3rd Gen DC TRDOR
    Are you running stock springs? I would say you need more than an AAL. I'd get a full set of HD Dakars. Also add a better progressive bumpstop from Wheelers.
    kasnerd and Bastek[QUOTED] like this.
  3. Mar 3, 2019 at 7:29 AM
    Bastek
    Bastek Average Member
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    That's the thing, those are OME EL095R with Timbren bump stops...
    I installed a bumper with a swingout and that's what happen.
    I do appreciate your feedback though
  4. Mar 3, 2019 at 7:48 AM
    kasnerd
    SoCal Yokel
    Mods? Yes, oh yes..
    I have timbren with OME/dakars and getting rid of them and icon hydrobumps go on Tuesday!! They are more for constant overload not dampening which the hydrobumps will take care of.
  5. Mar 3, 2019 at 7:59 AM
    Bastek
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
  6. Mar 3, 2019 at 9:18 AM
    Guardian
    Colorado
    3rd Gen DC TRDOR
    I think the HD is part # EL096R. Not 95. I say that because I was just confirming that to myself yesterday. So maybe an extra leaf in there will help out. At least you’re addressing the issue. I imagine if you left it you’ll end up have some real damage
  7. Mar 3, 2019 at 9:21 AM
    Dirtridercrf250
    Dirtridercrf250 Well-Known Member
    Correct the EL096R has double over load. You can order the extra load spring for the EL095R to make the 096R.
    Bastek and Guardian[QUOTED] like this.
  8. Mar 3, 2019 at 9:24 AM
    Dirtridercrf250
  9. Mar 3, 2019 at 9:33 AM
    Bastek
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    Yupp, that's exactly what it is. I didn't expect installing a bumper with a swing out that's why I got medium one.
    I was hoping they would work with the bumper/swingout option since it's not too heavy.. .the issue is not only weight itself, but also where it is located- huge leverage since it's outside of vehicle.
    I removed the swingout, ordered aal and some more things, and hopefully I'll be able to install all of it in a few weeks.
    I'm just concerned a bit of my Dakars being damaged already, and I would hate to do all the work installing aal onto bad leafs
  10. Mar 3, 2019 at 9:35 AM
    Bastek
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
  11. Mar 3, 2019 at 9:44 AM
    Dirtridercrf250
    Linked basic XHP,edited the like 462 Moly
  12. Mar 9, 2019 at 2:56 PM
    kasnerd
    SoCal Yokel
    Mods? Yes, oh yes..
    so this happened: new hangers, hydrobumps
    truck rides amazing. good bye flimsy pop-metal shackle hangars. 16 rivets later...
    work done by @Shmellmopwho
  13. Mar 9, 2019 at 5:06 PM
    Shmellmopwho
    Shmellmopwho Well-Known Member Vendor
    Lomita CA
    2013 White DCLB TRD sport
    Bunch of stuff
    That was fun :rolleyes: Jk it actually was fun hanging out and working on the truck all day!
    Bigdaddy4760 and kasnerd[QUOTED] like this.
  14. Mar 9, 2019 at 7:22 PM
    Gary86
    Gary86 IG: 2a_Aviator
    Gary
    Corpus Christi, TX
    2018 DCSB Cement TRD 4X4
    Did you go with Dakar medium pack in the rear?
  15. Mar 9, 2019 at 7:55 PM
    DLRIII
    DLRIII Well-Known Member
    David
    Baton Rouge
    2018 Quicksand SR5 DCSB V6
    No, I installed a Deaver AAL
    Gary86[QUOTED] likes this.
  16. Mar 17, 2019 at 8:52 PM
    xGRIMEYx
    xGRIMEYx Go follow #RheaTheGray on IG!
    RheaTheGray
    fort worth, tx
    17’ TRD PRO
    Fox 2.5s w/resi SSO slimline front bumper OVTune 1.05 SCS ray10s 285/75/17 KO2s JL Audio C5s Rigid Industries ditch lights & light bar Warn VR8-S gen II RCI rear bumper 5.29 nitro gears UpTopOverland roof rack TJM sliders ARB twin compressor bed mounted
    do the dakars medium pack settle at all from the initial install height with no weight in the bed???
  17. Mar 17, 2019 at 9:23 PM
    Redsyota
    Redsyota Well-Known Member
    Denver
    15' SPORT 6 SPEED ACLB MGM
    Some of the things...
    Yes. As with any spring. Mine did roughly a half inch in 10k miles empty. With weight they dropped an additional inch in another 10k.
    xGRIMEYx[QUOTED] likes this.
  18. Mar 18, 2019 at 1:26 PM
    BRaposo
    BRaposo New Member
    2019 Tacoma TRD OR
    Hi Everyone - First post on TW. Read this whole thread and I may be even more confused, Just want to know one simple question please. Will the Below package give me 2-2.25 inches all around keeping factory rake?
    2019 quicksand TRD OR double cab
    I don't plan on adding a bumper, and 85% of the time I don't have anything in the back. I like the factory ride quality and I actually like the feel of factory offroad. Just need bigger tires, more clearance, and more aggressive look.
    Thanks in advance!
  19. Mar 18, 2019 at 3:10 PM
    kasnerd
    SoCal Yokel
    Mods? Yes, oh yes..
    you can go more than 2.5" w/o getting into too many issues with geometries. although you should re-consider and get adjustable uca's that will make alignments easier.
    that setup will be stiffer than factory. most aftermarket off road is going to be stiffer over smaller stuff like bumps and cracks and more pliable with larger events which is not what you described as your typical use. I would stick to stock until they are worn out then upgrade. also 15% of the time when something is in the back, how much weight and over what terrain?
  20. Mar 18, 2019 at 6:59 PM
    BRaposo
    BRaposo New Member
    2019 Tacoma TRD OR
    Thanks Kasnerd- I would get UCA's if it meant I could get a better alignment. I only haul stuff over pavement house/landscaping, beach, tailgate. Road trips. I don't camp I drop my stuff off at the hotel room then hit trails, hike, bring my MT Bike etc.
    I wonder whats my best option for 2- 2.5in that gives me great value on and off road
