Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. May 19, 2025 at 12:56 PM
    JDKred
    JDKred Well-Known Member
    JD
    16 MT KDMax Tuned
    I think I might just get the 6112 again but get 5125 for the rear, rather then the 5160 piggy backs...
    I have watched a few vids on the OME rears and it seems they can be a little UN-settled for offload use.
    Easy to install without a spring compressor (just use the lowering of the truck and the compressor) and done...
  2. May 19, 2025 at 1:07 PM
    TomHGZ
    TomHGZ Well-Known Member
    2014 TRD Frankensport 4x4 AC AT
    Partial list: Vagabond Drifter 3rd Gen OR rear axle 4.30 gears Bilstein 6112s and Tundra 5160s.
    If you regularly carry a decent amount of extra weight on your truck, consider getting rear shocks made for the previous generation Tundra. The heavier valving does a much better job controlling the truck. I moved from 5100’s made for Tacomas to 5160’s made for Tundras and was really pleased with the increase in performance, (but you don’t need to do the 5160’s to get the heavier Tundra valving). You will need to trim the lower eyes a little on each side with an angle grinder to make them fit. Just be careful not to buy a shock that is too long for your leaf pack, as the Tundra shocks are longer.
    mistermanny and JDKred[QUOTED] like this.
  3. May 19, 2025 at 1:15 PM
    JDKred
    JD
    16 MT KDMax Tuned
    What the ride stiff? I have a decked drawer system in the back. I think the 5125 for the taco should be okay. But you have me intrigued about the 5160 for the tundra... what years tundra 5160 would I be looking at?
  4. May 19, 2025 at 1:19 PM
    TomHGZ
    The ride was noticeably improved, but with armor and a camper, I have 5-600 lbs extra weight on the rear axle.
    2007-2021 Tundras
    JDKred[QUOTED] likes this.
  5. Jun 16, 2025 at 7:04 AM
    Got2ryde
    Got2ryde Well-Known Member
    Ryder
    Maryland
    AC OR 6spd silverstreak
    Off Road tow pac. GTCovers wetskinz seat covers, Direct wired Escort 9500xi, Leer 180 w/ARB awning, bed mat, extra d-rings, rear dif breather relocated, Weathertec mats, Elite front with Warn M8000-s and Rigid D2's, BAMF sliders, ABS killswitch, Kicker Hideaway sub, UltraGauge, ATO rear with flush mount duallys, FJ Trail Team black rims w/Duratracs.
    Got a link to the boot slide mod? That's my big complaint with the 886's is it seems to eat boots faster. Also it seems the oem half shafts are hard to find anymore. What aftermarkets are people putting on these days that hold up well. I have aftermarket UCA's. Also looking for the specs recommended for 886's with aftermarket uppers. Somebody had posted a set of guidelines for proper alignment that worked very well the last times I've gotten aligned but I can't find it now that I need to get things straightened out after doing some front end work.
    Thanks
  6. Jun 16, 2025 at 7:25 AM
    Got2ryde
    Ryder
    Maryland
    Any pics of a correctly oriented coil. I get the speed bump clunk too. 886's
  7. Jun 17, 2025 at 8:50 PM
    la0d0g
    running for the hills
    For crawling not hauling
    Unclamp the boot and slide it out until the fins don't touch and then tighten it back up.
    I have alignment numbers in my old build thread for 886s and TC UCAs if that helps.
  8. Jun 21, 2025 at 6:48 PM
    HoneyBadger153
    HoneyBadger153 Well-Known Member
    Lowcountry, SC
    2002 Lunar Mist Tacoma SR5 4WD
    ARB, Hella FF75, SoftTopper, Power Limited Seats, OME Suspension, Heated Mirrors
    Question regarding my '02:
    I have front OME 90004 w/ 883 coils & Dakar leafs with OME 60062 in the back. I've had a clunk in the back end when going over a driveway bump at an angle for quite a while (like the rear end is shifting), but have recently developed a relatively quiet clunk/popping sound in the front at low speeds and moving the wheel (think a parking lot). These parts were installed roughly 50k miles ago back in 2015 and I'm under the impression that all the bushings are simply worn out. Does this sound like a likely culprit or should I be looking at new shocks & coilovers at this point. I'll already be taking the steering rack out to do bushings for it and the sway bar so I figure I might as well do it all at the same time.
  9. Jun 22, 2025 at 3:05 AM
    Got2ryde
    Ryder
    Maryland
    Thanks.
    So I use to be fluent in the forum here years ago but again I came up empty handed when I went through your page to find that old build thread. Got a link? Sorry I’m worse at computers than I am at wrenching.
    Thanks for the help and the boot slide tip. I hadn’t heard that one.
