Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. May 10, 2013 at 5:04 PM
    #1381
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    You shouldnt need spacers. The reason why some people need spacers on stock wheels is because they run wider tires than stock. Wider tires like 285+ will rub the UCA with the stock wheels, 255s should be fine, but if you want to double check ask the same question in this thread http://www.tacomaworld.com/forum/wheels-tires/155849-255-85-r16-owners-experience.html
  2. May 10, 2013 at 6:42 PM
    #1382
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    With 255/85/16 ? Not really
  3. May 10, 2013 at 6:51 PM
    #1383
    OZ-T
    Peter North
    British Columbia
    That's more prevalent with 285's , because of the width
  4. May 10, 2013 at 6:54 PM
    #1384
    quantum
    quantum Well-Known Member
    just curious (and this is probably the wrong place to ask, anyway :rolleyes: ), but is there a certain (minimum) wheel backspace you would need to run 285s and not do the cab mount chop?
  5. May 10, 2013 at 6:56 PM
    #1385
    OZ-T
    Peter North
    British Columbia
    I'm not too sure about wheel specs
  6. May 10, 2013 at 7:03 PM
    #1386
    quantum
    in theory, at full-lock, the additional bs will (maybe) give you that much additional clearance....maybe.....i don't f*cking know
  7. May 10, 2013 at 7:04 PM
    #1387
    evanmb31
    evan
    connecticut
    09 trd off road
    0 offset is probably your best bet but there are more factors to consider. Anything less and you might rub the UCA, the farther the tire sticks out more likely to need the CMC
  8. May 10, 2013 at 9:16 PM
    #1388
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    I can tell you I get just a little rub on the frame with 275s at full steer no compression, but only in reverse. I believe the BS is 0. My next set of tires will be a 265 because rubbing issues only get worse under compression on the trail.
  9. May 10, 2013 at 9:18 PM
    #1389
    OZ-T
    Peter North
    British Columbia
    You have Sport alloys ?
  10. May 11, 2013 at 9:08 AM
    #1390
    YOTA LOVER
    NH
    OZ, you're a walking encyclopedia. What's the thickness of the Toyotech spacer (in mm) that'll gain me about 3/4" lift? I need to know if I should theirs or OME.
  11. May 11, 2013 at 9:09 AM
    #1391
    YOTA LOVER
    NH
    I picked up some ProComps, not too expensive. Can't even remember what model.
  12. May 11, 2013 at 10:36 AM
    #1392
    evanmb31
    evan
    connecticut
    09 trd off road
    OME doesnt make top plate spacers, they just make the trim packer to corrcect taco lean.
    Here is toytecs spacer for 3/4" i dont know why the picture is wrong Heres all the top plate spacers wheelers offers, shows you thickness and aprox. Lift
  13. May 11, 2013 at 11:00 AM
    #1393
    YOTA LOVER
    NH
    Wait, you're not OZ ;) those were the spacers we were looking at from TT. I was looking at a kit from wheelers yesterday, there was a10mm good for about 1/2" and another good for 3/4". TT doesn't have the thickness anywhere, and I want the thickest I can get.
    There we go: I measured today, and my front end is 1.5" lower than the rear. I don't mind a little rake, but not that much!
    And now that I'm home looking at your link and my link side by side, what the hell is the difference?
  14. May 11, 2013 at 11:05 AM
    #1394
    4Wheelin4Banger
    4Wheelin4Banger [OP] Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    255s will work great on those wheels without spacers. The reasons I got 1st Gen TRDs (4.5" BS the equivalent of 3/4" spacers) were too good of a deal to pass up ($100 for 4) & at the time I had a 280 to 350 mile/week commute and could swap tires/wheels for commuting or off road.
  15. May 11, 2013 at 11:07 AM
    #1395
    4Wheelin4Banger
    Randy
    It can be done but it's a lot easier if you have someone else to slide the bolt in.
  16. May 11, 2013 at 11:32 AM
    #1396
    YOTA LOVER
    NH
    I think the worst was working the heavy spring in between the axle and the E-brake lines :eek:. I had the axle supported on two jack stands with a block under the pinion for stability, and the truck was set up by the frame on two other 5-ton jack stands. I was able to work the leaf pack onto the axle (carefully for balance) and bolt the front in first. Luckier than hell I had the axle close to the right height for the whole operation. :D Once both sides were done I did up the u-bolts and then used a jack under the diff to pivot the whole mess skyward until I could wrestle the rear ends into the shackles.
    The stupid things you do when you are young? :cool:
  17. May 11, 2013 at 11:46 AM
    #1397
    OZ-T
    Peter North
    British Columbia
    10mm
  18. May 11, 2013 at 11:50 AM
    #1398
    YOTA LOVER
    NH
    Soooooooooo, hands down I should get the Emu spacer and longer bolt kit? And why does OME carry a 10mm, 13mm, 1/4", and 1/2" spacers all listed separately?
  19. May 11, 2013 at 11:52 AM
    #1399
    OZ-T
    Peter North
    British Columbia
    OME doesn't make top plate spacers
  20. May 11, 2013 at 11:58 AM
    #1400
    OZ-T
    Peter North
    British Columbia
    Toytec top plate spacers , 3/4" of lift Wheelers top plate spacers are on this page
