Old Man Emu setups on 1st gens
Discussion in '1st Gen. Tacomas (1995-2004)' started by kyle39, Feb 19, 2011.
  1. Apr 17, 2020 at 10:46 PM
    #4481
    Narty
    Narty Well-Known Member
    Orange County
    1998 Black Tacoma ext cab 4x4 A/T
    OME nitrochargers, Dakars+AAL, JBA UCA 285/75/16 Nitto Ridge Grapplers on TRD baja "beadlocks" Flippac
    got some dakars on offerup, considering going nitrochargers all around. a lot of the kits have greasable shackels, exhaust hanger relocation and brake line extensions and what not. seeing if all of that stuff is necessary or are shops just bundling it all in as a kit.
  2. Apr 18, 2020 at 8:02 AM
    #4482
    MedicMutt
    MedicMutt Purveyor of Useless Information
    Josh
    Baton Rouge, LA
    '03 DC PreRunner TRD OR; '06 Mercury Grand Marquis GS
    OME suspension, Whiteline bushings, Line-X'd Jason topper, GoRhino "Grille Guard", many more...
    Greasable shackles are a good idea. I wound up using an extended brake line and the exhaust bracket for my setup. Some folks argue that the bracket isn't absolutely necessary. I also added 3 degree shims and a BAMF brake proportioning valve bracket.
    Hamer95USA likes this.
  3. Apr 18, 2020 at 8:10 AM
    #4483
    Narty
    Orange County
    did you go with 0" shackle or 1/2" shackle? and I'm assuming those a 1/2" lift on top of the leaf pack too?
  4. Apr 18, 2020 at 8:32 AM
    #4484
    MedicMutt
    Josh
    Baton Rouge, LA
    I bought my setup from Wheeler's. Comes with the GS12 shackles. I wanted my truck leveled out with the 881 coils up front.
    ontarioyota likes this.
  5. Apr 18, 2020 at 10:01 AM
    #4485
    4r_out
    4r_out Well-Known Member
    4Runner
    If I install 883’s without a bumper will I need a diff drop? Control arms will also be replaced. I do plan on adding a trail gear front bumper in the next couple of months. Thanks
  6. Apr 27, 2020 at 11:47 PM
    #4486
    justin0994
    justin0994 Active Member
    Justin
    Sparks NV
    1998 Tacoma Limited
    I'm looking at the old man emu kit for my 1998 Tacoma Limited.
    I'm stuck on what option for the leaf springs:
    The single add a leaf, the progressive three leaf or the full Dakar pack.
    The truck is mostly going to be a daily, but I live in northern Nevada so there are a lot of trails to explore when the mood strikes. Any help would be appreciated.
    I've also been looking at the Fox coilovers too.
    once again thanks for any advice.
  7. Apr 28, 2020 at 8:23 AM
    #4487
    Narty
    Orange County
    if your stock leaf pack is still good then the AAL will be fine. if they're worn and you plan on loading the bed than i'd recommend getting the full dakar pack.
  8. Apr 30, 2020 at 11:54 AM
    #4488
    Palitaco510
    Palitaco510 Active Member
    2004 first gen 4x4
    2004 dc v6 4x4 5 speed extra cab. Worn out factor suspension(sagging rear leafs).
    5100 F+R
    882's
    Dakar leafs
    Im forced to replaced my rear leafs so I'm going with dakar springs. Don't plan on having front bumper or a fiberglass top in the rear. Looking for 2.5-3" lift and I want it to be fairly level. I'm torn between the 881's and the 882's. Hoping someone can weigh in on this.
  9. Apr 30, 2020 at 11:58 AM
    #4489
    49erfan
    49erfan Well-Known Member
    Kevin
    Dallas
    04 DC Prerunner Lunar Mist
    I went with 883’s. 04 DC V6 prerunner. I have a trail gear front bumper
  10. Apr 30, 2020 at 1:00 PM
    #4490
    MedicMutt
    Josh
    Baton Rouge, LA
    My PreRunner has 881s and sits level with about 2-2.5", but that's without the extra weight of the front diff and driveline components. Consider the extra lbs on your rig, for sure.
  11. Apr 30, 2020 at 1:34 PM
    #4491
    Logans2001
    Logans2001 What’s crackin’
    San Diego, CA
    2001 v6 4WD auto
    Are OME shocks considered linear or degressive?
  12. Apr 30, 2020 at 1:37 PM
    #4492
    Palitaco510
    2004 first gen 4x4
    So 882 would have about the same results?
  13. Apr 30, 2020 at 1:38 PM
    #4493
    Palitaco510
    2004 first gen 4x4
    Also do you dakar leafs in the back?
  14. Apr 30, 2020 at 2:51 PM
    #4494
    MedicMutt
    Josh
    Baton Rouge, LA
    I'm not entirely sure. I think I read that 882 are taller but have the same spring rate as 881, whereas 883 is the same height as 881, but higher spring rate.
    Yes. Installed without changing the number of leafs in the packs. Eventually, I need to get super bump stops.
  15. Apr 30, 2020 at 4:12 PM
    #4495
    Palitaco510
    2004 first gen 4x4
    so 882 or 881?
  16. Apr 30, 2020 at 4:30 PM
    #4496
    Narty
    Orange County
    email wheelers or marie at headstrong they'll lead you in the right direction. typically no weight then go with 881. if youre doing 5100's they're adjustable anyways even though its highly recommended AGAINST putting any other coil than stock on any of the notches for the 5100's although some people have with no issues. this will void warranty too so theres that.
    option 1a: 881 on the bottom clip and see if its enough lift for you
    option 1b: throw a spacer on
    option 1c: put the coil on one of the higher clips (you've been warn)
    option 2: 882 and the ride will most likely be be rough (wheelers recommends using 882 and 883 only if you have weight up front)
  17. Apr 30, 2020 at 4:39 PM
    #4497
    49erfan
    Kevin
    Dallas
    Wheelers recommended 883 for a dc v6 and that was with no added weight. Confused by your post, are you dc or extra cab?
  18. Apr 30, 2020 at 4:51 PM
    #4498
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Yeah no. DC 6cyl here and I'm on 881s paired with nitrochargers and ended up adding an ARB bumper (no winch). Fine with the ride, no issues. Dakars w/AAL and nitros in rear.
  19. Apr 30, 2020 at 5:13 PM
    #4499
    49erfan
    Kevin
    Dallas
    Question wasn’t directed to you
  20. Apr 30, 2020 at 5:39 PM
    #4500
    Area51Runner
    Ouch. Just adding in additional feedback but no worries. You enjoy now... :hattip:
