Old Man Emu setups on 1st gens
Discussion in '1st Gen. Tacomas (1995-2004)' started by kyle39, Feb 19, 2011.
  1. Nov 15, 2016 at 8:07 AM
    #2701
    STEVEO13016
    STEVEO13016 Well-Known Member
    STEVEO
    2000 Tacoma Prerunner V6 2WD
    5100 Billy's set at 0" with 881 coils
    I HAVE THE SAME ISSUE!! I had the 881 coils installed with 5100's and the ride quality is S*%$....
  2. Nov 15, 2016 at 8:31 AM
    #2702
    Tacotruck7
    Tacotruck7 Well-Known Member
    SoCal
    04 Prerunner Dbl Cab 2.7L
    I got a set of used nitros and 882 coils that I'm going to install this week.
    I plan to get dakars and nitros for the back from headstrong off-road later on.
  3. Nov 15, 2016 at 11:45 AM
    #2703
    T@codawg
    T@codawg Well-Known Member
    Mark
    Nashville
    99 TRD PreRunner Xtra Cab
    Full OME 881's w/nitros & Dakar leafs in rear
    Myride quality isn't that bad compared to spacers but just a little rougher than what I'd like
  4. Nov 15, 2016 at 1:15 PM
    #2704
    jjsul
    jjsul Well-Known Member
    James
    New Hampshire
    95.5 OME
    My truck has a full OME kit on w 881's and the ride is relatively rough. I have no armor / weight. I should note that this is the first time I've had a lifted truck. I like the truck even with the stiff ride.
    :burnrubber:
    T@codawg likes this.
  5. Nov 16, 2016 at 3:36 PM
    #2705
    Hektor
    Hektor Well-Known Member
    Texas
    04 Tacoma 4x4 TRD DC v6
    Really??? I had Hat set up in my previous taco and the ride was amazing!!!!
  6. Nov 16, 2016 at 8:38 PM
    #2706
    mjwood
    mjwood Member
    2001 Tacoma TRD Xtra Cab 4WD V6
    Pretty much stock
    Planning to get an OME kit on my stock 2001 Tacoma. If I'm not going for lots of lift, do I really top spacers? I don't want any rake either... Also, am I going to need to do anything with the exhaust or brake lines?
  7. Nov 17, 2016 at 7:16 AM
    #2707
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    If you don't want any rake but want an entirely new leaf pack, I'd suggest either getting Wheelers Offroad 5 leaf springs that give 1.5" of lift or if you get OME Dakar springs, remove the upper overload leaf as well as the 3rd leaf from the top of the pack to give you closer to 1.5-2.0" of lift. Either of these paired with 881's or 882's will be close to level, especially the 882's on a V6 4WD.
    You may want to get an extended rear brake line depending on how much lift you end up with in the rear; the front lines will be fine. With the OME leafs, some people have said that they need the exhaust hanger extension to prevent rubbing. Others just cut the tail pipe so that it dumps just behind the rear axle.
  8. Nov 18, 2016 at 5:55 AM
    #2708
    chaosrob
    chaosrob Well-Known Member
    Lot's of varying setups so far. I ordered the OME Kit for my 95.5 with 882 coils. What is the max tire size i can run without rubbing without hammering, no mods other than bolting them on? I am running 16" '99 4Runner wheels to clear the bigger brake calipers. TIA
  9. Nov 18, 2016 at 7:33 AM
    #2709
    boostedka
    James
    NM
    265/75/16
    255/85/16
  10. Nov 18, 2016 at 7:43 AM
    #2710
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Will not fit without some work.
  11. Nov 18, 2016 at 8:15 AM
    #2711
    boostedka
    James
    NM
    THanks for correcting me. I've never run them myself so I'm glad you fixed what I said
    rngr[QUOTED] likes this.
  12. Nov 18, 2016 at 9:41 AM
    #2712
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Do you plan to take it off road where you'll be flexing the suspension?
    Adding lift alone does not guarantee you'll be able to fit tires larger that 32" in diameter. And if you are only going to the mall (and avoiding the speed bumps) then you can run 32s without any lift.
    265/75r16 = 32s
    chaosrob[QUOTED] likes this.
  13. Nov 18, 2016 at 1:29 PM
    #2713
    chaosrob
    I mainly use my 70 Series Land Cruiser for off road use but I will most likely take it out a time or two. I understand what you are saying about flex and why I was hoping to hear from some of the uys actually running them and their experiences. Even without the true off road I will be hitting some rough construction sites and shooting/hunting areas with it.
    DeerHunter44 likes this.
  14. Nov 21, 2016 at 3:12 PM
    #2714
    STEVEO13016
    STEVEO
    Yeah, I am not sure why its so rough for me.... I understand I don't have any weight up front but DAMN its a rough ride....
    shawnster88 likes this.
  15. Nov 23, 2016 at 6:22 PM
    #2715
    LITacoQ
    LITacoQ Well-Known Member
    East Coast
    2003 SR5 Access Cab 2.7 5 speed lunar mist
    Will 235/85/16 work on stock Taco?
    MCObray likes this.
  16. Nov 23, 2016 at 6:26 PM
    #2716
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Yes.
    Will you have to do any trimming/beating? I have no clue. Maybe someone here can tell you more. It's a narrow tire, so I think it would be fine.
    LITacoQ[QUOTED] likes this.
  17. Nov 29, 2016 at 8:11 AM
    #2717
    Tacotruck7
    SoCal
    I just put nitros and 882's I got off a member on my truck. The lift is way higher than I thought. I will probably get a bumper (trail gear) a little down the road. My biggest concern is if I need new UCA's or not. The truck seems to ride fine other than being a little stiff and drive great.
  18. Nov 29, 2016 at 8:34 AM
    #2718
    boostedka
    James
    NM
    On one of my other trucks, I ran that same set up in the front with the stock UCA's for about 5 years before I sold it. I had no problems
  19. Nov 29, 2016 at 9:54 AM
    #2719
    Tacotruck7
    SoCal
    Good to know. I'll probably run the stock ones until I can afford other ones. Right now everything feels fine it doesn't pull or anything.
  20. Dec 2, 2016 at 6:06 AM
    #2720
    LITacoQ
    East Coast
    Can I use OME nitro rear shocks with stock leaf springs or will they bottom out? Wheelers seems to think my leaves are fine since they are still straight. Thanks again for the info
