Old Man Emu setups on 1st gens
Discussion in '1st Gen. Tacomas (1995-2004)' started by kyle39, Feb 19, 2011.
  1. Apr 12, 2018 at 6:55 PM
    #3581
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    Mine are on the lowest setting...
  2. Apr 13, 2018 at 11:22 AM
    #3582
    MstrYota
    MstrYota Great balls of fire!
    Daniel
    Ventura County, CA
    2000 TRD 4x4 Prerunner/1998 TRD 4x4
    Too much but not enough!
    OME 885's on bilstein 5100 set at 0
  3. Apr 13, 2018 at 11:33 AM
    #3583
    MstrYota
    Daniel
    Ventura County, CA
    It can be done around $1500, but you should plan on $2000-$2500 to leave room for....complications......I did mine for around $1800 and did almost all the maintanence myself
  4. Apr 13, 2018 at 5:10 PM
    #3584
    HSmith_11
    HSmith_11 Tacoma Enthusiast
    Hunter
    Madison, Va
    2001 Ext Cab SR5 4x4 MT
    5100/OME 881s 1.5" Progressive AAL 33x12.50X15 KO2s
    I've been in this boat for at least 8 months. I think I'm leaning towards @YotaOverAll 's setup with the 10mm spacer.
    01GreenTacoma[QUOTED] likes this.
  5. Apr 13, 2018 at 6:10 PM
    #3585
    YotaOverAll
    Jessie
    Panama City, FL
    02 Prerunner SR5
    Doesn't ride rough to me with it...I did have 3" spacers on stock struts though lol but its a truck so I did t expect it to be the best
    01GreenTacoma likes this.
  6. Apr 13, 2018 at 10:13 PM
    #3586
    Adude
    Adude Well-Known Member
    Pnw
    04 Double cab
    Make sure the nut and extra threads don't touch or cut your cv boots at full compression.
  7. Apr 14, 2018 at 4:51 PM
    #3587
    hammertime40
    hammertime40 Member
    Jeff
    1995 Tacoma
    OK, I’m about to join the OME party next week.
    I have 881’s and Dakar’s going on a 95.5 extra cab V6.
    I have a question for you guys. I want the truck to sit close to level and don’t plan on putting much weight in the back. Should I remove a leaf from the pack prior to install? If so, Is it the one third up from the bottom?
    Thank you for the help,
    -Jeff
  8. Apr 14, 2018 at 5:23 PM
    #3588
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    From what I've read, you can remove the 3rd leaf from the top and/or the upper overload leaf. Each one is supposed to lower it about 1/2". This is just what I've read so maybe others can chime in with actual experience with this
  9. Apr 15, 2018 at 4:39 PM
    #3589
    hammertime40
    hammertime40 Member
    Jeff
    1995 Tacoma
    Thank you!
    Anyone Else?
  10. Apr 15, 2018 at 6:50 PM
    #3590
    boostedka
    James
    NM
  11. Apr 15, 2018 at 6:53 PM
    #3591
    YotaOverAll
    Jessie
    Panama City, FL
    02 Prerunner SR5
    Took my overloads out like 5 years ago cause my truck had rake. Don't haul anything and it still sits about the same height lol
  12. Apr 16, 2018 at 1:47 PM
    #3592
    chiago
    chiago Well-Known Member
    Chad
    NJ
    2001 Reg Cab Stepside 4x4
    That’s pretty much exactly what i did. 880s and Dakar leaf pack minus 3rd leaf.., but I went with 5100/5125..
    It’s exactly what I wanted.. Not much lift and improved ride... Note I have a reg cab 4cyl... if I had the 6cyl I might have gone with the 881s... slightly taller but same spring rate... as she sits now the rear is a bit higher that the front...
  13. Apr 16, 2018 at 3:53 PM
    #3593
    jjsul
    jjsul Well-Known Member
    James
    New Hampshire
    95.5 OME
    I have the same truck and took out of the main springs after I installed the whole thing. I forget exactly which one, but I wanted less lift than the full pack and I wanted a softer ride.
    They’re still stiff!
    Our year truck has shorter springs so I think they ride stiffer than the longer ones used for 98-04.
  14. Apr 16, 2018 at 3:56 PM
    #3594
    lukester78
    lukester78 Well-Known Member
    Luke
    97 Tacoma Single Cab 4x4
    Placed my order this morning!
    Area51Runner and JKU3000 like this.
  15. Apr 16, 2018 at 6:44 PM
    #3595
    hammertime40
    hammertime40 Member
    Jeff
    1995 Tacoma
    Alright, somebody tell me I’m crazy and talk me out of it.
    I’m thinking I’m going to take out the third leaf AND the Largest over load.
  16. Apr 16, 2018 at 7:59 PM
    #3596
    boostedka
    James
    NM
    I’m thinking about doing the exact same thing. Hopefully this week sometime
  17. Apr 16, 2018 at 9:45 PM
    #3597
    Jiveydude
    Jiveydude Well-Known Member
    Micah
    OH
    04Taco
    Stuff and things that make it better.
    Same as the 883's, 590 but 20mm taller :eek:
    m3bassman[QUOTED] likes this.
  18. Apr 16, 2018 at 10:21 PM
    #3598
    Adude
    Pnw
    04 Double cab
    I was shooting for that as well, but now read and got 886s. How are they working out?
  19. Apr 17, 2018 at 5:09 AM
    #3599
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    HSmith_11 likes this.
  20. Apr 17, 2018 at 8:30 AM
    #3600
    Fuergrissa
    Fuergrissa If you build it, trails will come.
    Devin
    San Jose
    2000 T4R Limited
